Old Jan 05, 2010, 04:35 AM
big bird is offline
Find More Posts by big bird
Belfast / Dublin
Joined May 2004
will Hyperion LBA10 work with Schulze isl 6-330
anyone know if the separate LBA10 balance unit from hyperion works with this older Schulze charger - my software is ok - version 8.51
i plan to use two of them for parallel pack charging...
cheers
bb
big bird is offline Find More Posts by big bird
Old Jan 05, 2010, 06:26 AM
JIM CALDWELLA is offline
Find More Posts by JIM CALDWELLA
United States, OH, Cleveland
Joined Aug 2002
works just fine, I have 2 sets of each.
JIM CALDWELLA is offline Find More Posts by JIM CALDWELLA
Old Jan 18, 2010, 05:51 AM
Aio_1 is offline
Find More Posts by Aio_1
Aio_1's Avatar
Ireland, Kildare, Leixlip
Joined May 2002
cheers
bb
Hello there, how are things?
This should work fine. As far as I know the stand-alone Hyperion balancers will work with any typical lipo charger. I've used the exact same combo of Schulze 330d isl6 and LBA10. No problems.
However if you don't have the balancers already it might be worth spending a little more and getting a new charger with built in balancing instead. I've just gotten an iCharger 106b+ to replace my Schulze - I've only used it a couple of times but I really like it so far. It's got lots of useful functionality like settable charge/discharge voltage limits, ability to cycle lipos, auto cell charge/discharge for storage, and lots of other stuff that'll get less use but might come in handy from time to time.
The integrated balancing function is much tidier and more convenient than a separate LBA10 and gives you more information and flexibility. Fewer cables and plugs in your charging area is also good especially if you're parallel charging.
My Schulze started worrying me a little. I noticed the two outputs were giving different voltage readings (~0.07V) for the same cells. I think it's something like 6 years old now and probably just needs re-calibration but I decided to get the iCharger instead of sending the Schulze in off for a service (can always do that later).
Aidan
Aio_1 is offline Find More Posts by Aio_1
For Sale Schulze isl 6-430d, upgraded for LiPos Jim Ryan Aircraft - Electric - Batteries & Chargers (FS/W) 1 Jan 09, 2010 03:11 PM
Help! Schulze Isl 6-330 d discharge programming flanker Batteries and Chargers 4 Aug 24, 2009 08:29 AM
Question Schulze ISL-6-330 charger Winsoft software - does it work on Windows 2000? mihe Batteries and Chargers 2 Feb 04, 2004 03:53 AM
Yippee! **FS: Schulze ISL 6-330 charger with v8.06 eprom ** KenSmith Aircraft - Fuel - Airplanes (FS/W) 2 Nov 26, 2003 10:06 AM
Question Charging Li-Poly's with Schulze ISL 6-330-D? Clive Henry Jones Batteries and Chargers 8 Jan 28, 2003 11:49 AM
