| View Poll Results: What type of glider provides the best experience | |||
| Pusher prop - The prop and nose hinder the otherwise excellent view |
9 | 25.71% |
| Tractor prop - It's a glider. Fly it like you were actually inside the plane. |
12 | 34.29% |
| Pusher prop with nose visible - It's great to have the nose in view, but the prop is irritating. |
14 | 40.00% |
| Voters: 35. You may not vote on this poll | |||
| Thread Tools |
The best FPV glider experience
I have a general question regarding FPV with a powered glider. I am considering two designs for a 60-72" wingspane scratchbuild glider for FPV.
The two ideas I'm tossing around are: 1. A twin boom center pusher motor design - This would allow unhindered view in the front and allow a tilt (which I occasionally use). Unfortunately this would also increase drag and make it a bit harder to load into my tiny compact car. I have an OSD which puts a target on screen for centering the flight. 2. Conventional glider with tractor motor - This would be a more typical type of glider, although I'll probably have the wings swept forward to help control stalls and I will certainly have ailerons. This would not allow for the tilt and would place the prop right in the field of vision, but it would be folded up most of the time anyway. So my question is, which would provide a better FPV experience? I have sucessfully built several gliders of both types before and they perform well. My question is does seeing the prop and the nose of the plane improve the flying experience or should I just put the camera right in the nose and relocate the motor like I usually do? |
Latest blog entry: Project Covert Ops: Long range ground...
It's a matter of personal taste I think... All options will work well to an extent, it comes down to what you prefer. Watch some videos of different planes and see what you think you'd like best and go for it. Personally I've only flown a glider via FPV in the traditional tractor setup with a folding prop on the nose. The prop didn't bother me at all, and when I shut the motor off and started gliding, the prop was barely even visible.
My pan/tilt was mounted between the canopy and leading edge of the wing, so it was up high enough to still have plenty of view when looking down, especially on either side of the fuselage.
tractor. if you really build a GLIDER, you will find you will use the engine for 20 - 30 seconds per flight on above flight I used 3 bursts of 10-12 seconds of engine. the rest of the flight was done inside upwinds.
Romania, Dolj, Craiova
Joined Sep 2007
Latest blog entry: JRSky - birth of a dream radio
Dos Hermanas (Sevilla)
Joined Dec 2007
Nice video and music......but, the music is from "Lisa Gerrard" - Gladiator, not from Enya as you say at the end of the video. .Regards Patrick |
Joined Sep 2007
![]() Do you have kangaroos around your location ?
| Thread Tools | |
| Build Log Easy Fly Glider ST330 (Easy Glider Clone) FPV Build Thread | SoMoney | Video Piloting (FPV/RPV) | 493 | Nov 12, 2012 03:08 PM |
| Discussion Best Servos for Easy Fly/Easy Glider | Grunta | Beginner Training Area (Aircraft-Electric) | 13 | Jan 01, 2010 03:30 PM |
| Build Log Easy Glider Pro FPV build | markeydoo | Video Piloting (FPV/RPV) | 56 | Dec 27, 2009 08:01 PM |
| Discussion my first day glider experience | apriliamille | Sailplane Talk | 7 | Oct 26, 2009 09:43 AM |
| Poll The Best Generic Brand 2.4 Module Upgrade For FM vote only if you have experience | garrcass | Radios | 16 | Aug 30, 2009 04:28 PM |
