Old Jan 04, 2010, 06:57 PM
c5eng is offline
Find More Posts by c5eng
Joined Jan 2010
Question
Blade mXC
Ok, I bought a blade mxc a couple weeks ago and I love it, but after an attempt at some stunt flying around obsticles I broke the little ball that the stablizer flybar linkage connects to on one of the top rotor blades. Now it only has one of the linkages so I swapped the blades because the other blade has the ball on it also. But now my helo fly's in little circles while hovering, not bad, just about 10". So is that little ball throwing things off? Or did I break something else? Also wanting to order some "spare" parts to have some spares what do you recommend? Hope someone can help!!
c5eng is offline Find More Posts by c5eng
Old Jan 05, 2010, 10:09 AM
sleb is offline
Find More Posts by sleb
Quads & Planes, cant beat them
sleb's Avatar
Cleveland, Ohio, United States
Joined Nov 2003
c5,
There is a ton of info on the mCX in the multi rotor section.
First the little circles are known as TBE, toilet bowl effect. Check the the flybar still moves freely. Should be very loose, that is a main cause of TBE. You may want to turn the connector around, when it came off you may have put the wrong side inwards. If that does not help, just order a new sret of blades. Remember to go check the numerous threads on the mCX over in the multi rotor section. A ton of good info to keep the bird flying well for a long time.
sleb is offline Find More Posts by sleb
For Sale E-Flight Blade MXC wlight1up Aircraft - Electric - Helis (FS/W) 2 Dec 17, 2008 10:47 PM
For Sale Trade E-Flight Blade MXC for spectrum receiver + wlight1up Aircraft - General - Radio Equipment (FS/W) 0 Dec 16, 2008 09:45 AM
Wanted Wanted E-Flight Blade MXC gbagley Aircraft - Electric - Helis (FS/W) 0 Dec 10, 2008 09:28 PM
Sold E-Flight Blade MXC wlight1up Aircraft - Electric - Helis (FS/W) 3 Dec 10, 2008 09:08 PM
For Sale Like new E-Flight Blade MXC wlight1up Aircraft - Electric - Helis (FS/W) 6 Nov 27, 2008 02:21 AM
