This thread is privately moderated by shoutchen, who may elect to delete unwanted replies.
Old Jan 04, 2010, 06:39 PM
shoutchen is offline
Find More Posts by shoutchen
mudville
Joined Nov 2002
micro electromagnetic servo/actuator
Here is my idea for a micro sized servo/actuator with optional feedback.
I think that of these can be built that would match the performance
of the available smallest servos, which at this time is a .65 gram
servo that has 6mm throw with 10 grams of force.
Here is a link to that servo..which is a work or art no doubt ...
http://www.microflierradio.com/Actuators.html
My idea uses no motor, but a couple of magnetic coils, aided
by using iron cores to make the magnetic fields larger for each coil.
The coils push against a pair of magnets to move the arm.
The arm has a magnet on one end which moves across the linear
hall effect sensors in a slide by technique. The hall effect sensors
are really tiny
A couple of centering springs keep it centered so it could be used
without feedback.
It could possibly be modified to use one coil/core/spring/magnet...
The second image is a microcontroller circuit for it that uses
an cpu, hbridge, and 3 hall effect sensors. This is variant of
the other servo/actuator circuit I posted on another project.
the CPU could also be a PIC chip as well...
I posted a schematic for a PIC too, with a lot of slide by sensors..
Here is a link to some pre-wound small coils that are availble...
http://www.microflight.com/Online-Ca...t-Actuator-Kit
The weight of those is .07 grams each and each one comes with two
1.5mm x .5 mm magnets. The ID of the coils is 3 mm
I have a picture of it below.
This link and one of the photos shows some very small springs
used in model trains, but here are used as the centering springs.
http://www.toysperiod.com/kadee-235-...new-p-323.html
The hall effect sensors are approximately 2 x 3 mm
The hbridge is approximately 3 x 3 mm
The cpu is approximately 3 x 3 mm
I will have to weight this stuff to see what it totals out to...
http://www.rcgroups.com/forums/showp...5&postcount=18
http://www.rcgroups.com/forums/showt...mg#post5783302
are both links to stuff with weights of smd chips
Resistor 0402=0.6mg 0603=2.5mg 0805=5.5mg 1206=10mg
Capacitor xxpF/0805=5mg xF/0402=1.4mg xF/0603=6mg 10F/0603=7mg 10
C8051F300 P 0.024gm ... this is a 3x3x1 mm QFN11 part, which is the size of an a3901 bridge.
C8051F336 P 0.041gm ... this ia a 4x4x1 mm QFN20 part. A pic 16f690 is a comparable
PIC chip sizewise..
So as a guestimate,
A a1391 2x3x.75mm hall effect sensor weighs 2/3 * .024 gm*.75 == .012gm
A a3901 3x3x1mm hbridge weighs 1 * .024 gm*.75 == .018 gm
A xxxxx 4x4x1mm cpu weighs 1 * .041 gm == .041 gm
A xxxxx SC70-3 2n3904 transistor weighs 1 * .007 gm == .010 gm
A xxxxx SC70-5 voltage regulator weighs 1 * .007 gm == .010 gm
A xxxxx 0603 .1 uF cap or resistor weighs t 1 * .006 gm == .006 gm
SO lets take a guess here..
A 10mm detection range needs 5 hall effect sensors stacked side by side
5 sensors == .060gm
1 hbridge == .018gm
1 cpu == .041gm
1 xistor == .007gm
1 vreg == .007gm
15 0603 == .090gm
total == .223gm
From this it seems tough the get a controller that will weight less than .223 gams, unless
doing the slide by technique is abandoned or the detection range is changed to 6mm
, saving from 2 to 4 sensors or about 024 to 048 mg
the min weight for a controller would be less than .200 grams in that case.
...Without a pcb...
Maybe the sensors can be epoxied together to become the "structure"
for the servo mechanics
shoutchen is offline Find More Posts by shoutchen
Old Jan 14, 2010, 07:58 PM
AleG is offline
Find More Posts by AleG
AleG's Avatar
Bangkok
Joined Oct 2007
Oops!, wrong thread.
One idea I had some time ago about making lighter servos is to use a single driver circuit for 2 or 3 servos, one microcontroller receiving the commands from the receiver and one H bridge that could be multiplexed (somehow) to drive 2 or 3 motors. That should save some weight...
AleG is offline Find More Posts by AleG
Old Sep 05, 2012, 11:24 PM
nemoskull is offline
Find More Posts by nemoskull
Pilot, Co-pilot, Navagator
nemoskull's Avatar
United States, AZ, Yuma
Joined Sep 2009
i know this is real old but...
ive been poking around this for a while, mostly as an alternitive to super small servos. i want coil acts on my HK DSM2 rx.
im looking at an A1301 hall effect, a MCP1640 step up VR, and a small h-bridge. all run by an tiny13 micro controller. im hoping for 1g AUW and can work to a 20 gram plane.....
nemoskull is offline Find More Posts by nemoskull
Question Micro RTF actuator planes Slider2732 Micro Ready-to-Fly 2 Jan 01, 2010 11:04 PM
Discussion How to replace the tail actuator with a servo ?? khaled_abobakr Ornithopters 6 Sep 10, 2009 08:51 AM
Discussion Micro Actuator Servo Chris T Scratchbuilt Indoor and Micro Models 83 Sep 03, 2009 06:52 PM
Video Micro Actuator Servo Chris T Electric Plane Talk 0 Feb 09, 2007 03:11 PM
Discussion Basic micro actuator/servo questions. spodius Electric Plane Talk 4 Mar 23, 2006 07:49 PM
