Old Jan 04, 2010, 05:52 PM
ty_horn is offline
Find More Posts by ty_horn
Philippians 4:13
Seward, NE
Joined Nov 2006
Help!
HobbyCity replacement for non-VXL motor and esc (Rustler)
I have an older model of the Traxxas Rustler and have been having troubles somewhere along the lines of the motor/esc/nimh battery. Everything gets very hot very quickly and I can't run it for more than about 2 minutes where I used to get 10 or so out of it. I replaced the motor with the stock motor with no results. I am thinking that it might be the battery... I would like to replace all three with something from hobbycity if someone knows a good set up with about the same power and speed as the stock Rustler (non-VXL) Thanks for any suggestions.
ty_horn is offline Find More Posts by ty_horn
Old Jan 04, 2010, 08:13 PM
veggieslinger is offline
Find More Posts by veggieslinger
bashing on vancouver island
veggieslinger's Avatar
Joined Sep 2008
how bout this for a setup?:
http://www.hobbycity.com/hobbycity/s...shless_Car_ESC
and this for a motor?:
http://www.hobbycity.com/hobbycity/s...Motor_w/sensor
im planning on using this same setup in a few vintage buggies, and can also use the esc in my emaxx
veggieslinger is offline Find More Posts by veggieslinger
Old Jan 04, 2010, 08:20 PM
kistner is offline
Find More Posts by kistner
Registered Basher
kistner's Avatar
United States, PA, Beaver
Joined May 2008
hobbycity has brushless 35amp setups that would provide similar power. the ezrun, I think there might be a turnigy also.
you could also check at swanghobby.com and nitrorcx.com similar stores and prices but some different combos/variety.
kistner is offline Find More Posts by kistner
Old Jan 05, 2010, 10:13 AM
ty_horn is offline
Philippians 4:13
Seward, NE
Joined Nov 2006
That is great but I really want something cheaper than the stock (non-vxl) esc. It sounds like that set up would be nice though. Especially with the $15 motor!
Old Jan 05, 2010, 10:31 AM
kistner is offline
Registered Basher
kistner's Avatar
Joined May 2008
esc at hobbycity:
http://www.hobbycity.com/hobbycity/s...idProduct=7186 OR for a couple more
http://www.hobbycity.com/hobbycity/s...idProduct=7188
and a decent motor (I have one of these): http://www.hobbycity.com/hobbycity/s...idproduct=6530 and you might want to add the program card that is included in the below combos
http://www.hobbycity.com/hobbycity/s...idProduct=7187
at swang (their pricees include shipping):
http://www.swanghobby.com/hobbywing-...-1-pr-707.html OR a little faster
http://www.swanghobby.com/hobbywing-...-1-pr-146.html
or at nitrorcx:
http://www.nitrorcx.com/ezrun-brushl...--35a-esc.html
my personal favorite of that bunch would be the 60amp esc with the motor and program card from hobbycity. 2nd would be the 9t combo from swang or nitrorcx, which ever comes out cheaper.
Old Jan 05, 2010, 10:38 AM
ty_horn is offline
Philippians 4:13
Seward, NE
Joined Nov 2006
what can you compare the power to on that hobby city motor so I can get an idea of what it will run like?
Old Jan 05, 2010, 10:42 AM
kistner is offline
Registered Basher
kistner's Avatar
Joined May 2008
I find it similar to my traxxas vxl motor (good torque) but noticeably a little slower. I have run it in a rustler and also in my 4wd hpi rs4mt; ran great in both with big and little pinions. never hot.
Old Jan 05, 2010, 10:48 AM
ty_horn is offline
Philippians 4:13
Seward, NE
Joined Nov 2006
oh, cool. This one is the one that my 6 year old son drives so I don't want a lot of speed anyway. I have a Stampede VXL for myself :-)
How many cells did you run with this motor? I might only run 2 for my son if I pick this one up? Any suggestions on the pinion gear for what I need? Thanks so much for all of the info.
Old Jan 05, 2010, 10:55 AM
kistner is offline
Registered Basher
kistner's Avatar
Joined May 2008
note, that motor needs 5mm pinions, a little hard to find. I use a 15 tooth on the rustler that my kid drives, keeps the speed in check, keeps it all real cool too. I recently purchased the parts to switch to 32pitch gears, easier to find 5mm pinions in that size and they are beefier. I have not switched anything yet though. I bought the biggest 32p traxxas spur I could find, think it was a 70something tooth, made for a nitro rustler, and some 14 tooth 32p 5mm pinions, made by traxxas, might have been for a summit. if you can find a smaller pinion it would be better still.
the alternative is to just drill out a 3mm pinion to 5mm. I plan to do that for a tamiya I have that uses 32p metric. I can't find any 5mm in that size.
Old Jan 05, 2010, 11:01 AM
kistner is offline
Registered Basher
kistner's Avatar
Joined May 2008
after typing all that I realize it might be easier to get a motor with a 3mm pinion shaft. I'll see if hobbycity has any cheap ones
well the price jumps up a bit: http://www.hobbycity.com/hobbycity/s...tor_10T_3900Kv plus I am not as crazy about the ezrun motors, they are actually 380 size in a finned can. but saves you from any other work. If you are handy cheapest route is to bore out a pinion yourself. Those 5mm 48pitch ones are really hard to find anymore.
I looked at the motor veggieslinger linked and when running with sensorless a few people reported cogging. the ezrun/turnigy esc is sensorless and that motor is designed for sensored operation. BUT it is a 540 motor with a 3mm pinion shaft.
Old Jan 05, 2010, 08:09 PM
Joined Sep 2008
its a shame hobbycity doesnt have a cheeper sensored car esc to go with the $15.00 motors. im gonna splurge and buy the $75.00 sensored esc so i can use it in multiple vehicles. should work good in my emaxx 3906
Old Jan 05, 2010, 08:49 PM
scorpion1 is offline
Find More Posts by scorpion1
I feel the need for speed!
scorpion1's Avatar
Southern U.S.
Joined Jun 2008
Kistner.....good call on the 60 amp esc and the turnigy motor.............i have a couple of those motors...........freakin gonzo torque..............
scorpion1 is offline Find More Posts by scorpion1
Old Jan 05, 2010, 09:36 PM
kistner is offline
Registered Basher
kistner's Avatar
Joined May 2008
I am a little jealous, when I bought one it was $25, now it's down to $16.
Old Jan 05, 2010, 10:03 PM
ty_horn is offline
Philippians 4:13
Seward, NE
Joined Nov 2006
which motor are you talking about? He has listed a couple from hobbycity
Old Jan 05, 2010, 10:47 PM
kistner is offline
Registered Basher
kistner's Avatar
Joined May 2008
this one
Help! Fried motor on my Rustler replacement options??? planebldr Off-road Cars 28 Dec 13, 2009 04:50 PM
Help! battery/engine set up for rustler vxl.... swabii Off-road Cars 2 Oct 21, 2009 11:46 AM
Discussion rustler vxl esc problem jbird1996 Electric Power Cars 2 Sep 20, 2009 10:52 AM
Sold Velineon Brushless Traxxas Rustler Stampede VXL ESC and Motor smaerd58 Cars - Trucks and Parts (FS/W) 2 Aug 23, 2009 06:02 PM
Sold Rustler VXL tires on New Rustler VXL wheels sdstick Cars - Trucks and Parts (FS/W) 3 Jul 21, 2009 11:53 PM
