That's a pretty ambitious build as a first electric model.
There is a DH-88 thread, you may be able to entice more responses specific to that airframe there: http://www.rcgroups.com/forums/showthread.php?t=85770 I may be wrong but I suspect your Lipo will be much too heavy for that airframe. Maybe a 3s 1800mah, or 2s 3000 mah would be more appropriate. ======================== Rough estimates Even with a 300 W system (150W / per side), drawing a max of about 14A per side on a 3s Lipo, you would get about 7-8 minutes out of a single 3s 2100mah ... but I believe the recommended is more around 200-250W total. Suggested AUW = 32 oz = 2 lbs 2 lbs x 100W/lb = 200W So 100W per side should be more than sufficient as a starting point. Working with 200W on 3s, we get about 8 minutes out of a 3s 1800 mah. ==================== Working with your selected Scorpion motors ... scorpion 2208-30 Considering you can buy 7x5E normal and pusher prop (ie: rig for counter-rotating), you could look at 3s power which would give you about 9 a side, 18A total under full throtle giving you 27oz of thrust. That's roughly 8-10 A average for the entire flight. http://www.scorpionsystem.com/files/i389_data_chart.htm - 1800 mAh x 80% capacity = 1440 mah usable - 1.440 Ah / 9A x 60 min/h = 9.5 min So a 3s 1800mAh pack would give you about 9.5 minutes of sport flying discharging a single pack down to 80% of capacity. You are expecting roughly 35oz, so 193 Watts / 2.19 lbs = 88W / lb Personally, I would like increase the thrust a little bit, pitch speed and total power up a little bit from that number. What is the next usable counter rotating prop size that you could use? 100W / lb is a decent setup for sport flying. (if you can keep the efficiency of the power system above 70%) ... see Scorpion Calc for that. Also, another good rule of thumb is that the power system (motor, esc, lipo) should be about 1/4 to 1/3 of the total AUW... so in a 35 oz plane, expect the power system to weight about 9-12 oz. ============= Regarding cheap ESC ... you can have failures with cheap & expensive ESCs, but chances are you will have fewer failures with brand names. Is all the time you are going to put in this plane (and the good brushless motors) really worth saving $50 on ESCs? CC Phoenix 25A weights about 17 grams a piece (or Thunderbird 18A), otherwise the Turnigy Plush (HobbyWing Pentium) have good reviews, but are a bit heavier at 19 grams for 18A or 22 grams for 25A. One advantage of the CC Phoenix ESC is you can run them in parallel and not have to disable one of the BEC (red wire), because their BECs are all calibrated to the same voltage. This is usually not the case with cheaper ESCs. |
| Thread Tools | |
| Alert ALWAYS check here before you buy on line! | CactusJackSlade | Aerial Photography | 7 | Nov 21, 2007 11:53 AM |
| Iron Fence Gate. Reality Check Please. | Mr.RC-CAM | Life, The Universe, and Politics | 8 | Oct 27, 2004 01:55 PM |
| Yippee! Please check-out my setup before I purchase | Persistant | Micro Helis | 4 | Sep 07, 2004 07:26 PM |
| Sellers, please check your shipping box before using it ... | Peter Khor | Aircraft - Electric - Airplanes (FS/W) | 20 | Feb 21, 2004 06:39 PM |
