Old Jan 19, 2010, 09:51 AM
HariEdo is offline
Find More Posts by HariEdo
Central Connecticut
Joined Jan 2010
I think I just worked out a four-input design on paper as well. I'm just missing the balance tuning for RSSI, for which I'd like to see your methodology. I found that once you're comparing four inputs, it's easy to put out digital "pan" and "tilt" signals, which a generic pan/tilt servo system could apply. In addition, with a final two-channel switch, the mono audio (black rca plugs) gets switched as well.
HariEdo is offline Find More Posts by HariEdo
Old Jan 19, 2010, 03:43 PM
JohnyGab is offline
Find More Posts by JohnyGab
Joined May 2008
I'm not sure i understand
HariEdo, are you planing about making an antenna tracket....based on Rssi?
JohnyGab is offline Find More Posts by JohnyGab
Old Jan 19, 2010, 04:03 PM
HariEdo is offline
Central Connecticut
Joined Jan 2010
Originally Posted by JohnyGab View Post
HariEdo, are you planing about making an antenna tracker....based on Rssi?
It's potentially possible. Way too early to see if it works well in practice. The 4-input diversity needs to figure out which RSSI is the best, so if you arrange your antennae in a natural up/left/right/down pattern, then you'll get "left is better than right" and "up is better than down" signals, which can go to a tracking controller.
Unfortunately, 900MHz directional antennae are large and bulky and not very cheap to go buying four systems to feed this thing, and the motors to haul the array would be beefy as well.
Old Jan 19, 2010, 04:57 PM
IBCrazy is offline
Find More Posts by IBCrazy
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
I got the idea from your circuit, HairEdo. You for some reason sent out the RSSI to a video switcher as well. If you build two of my diversity controllers and then send their outputs to a third channel diversity controller with the RSSI's of the winners such as in your design, then you now have a 4 input device. Each signal must pass through 2 switches, though. It will certainly work. I will make a block diagram for it later.
Right now I have a plane to fix. The transmitter ripped off the airplane in flight while I was on the maiden flight! I was able to get the coordinates from my OSD and found the airplane 150 feet away. No VTx, though I had to order another one. I will post the video, though as I had several channel switches on my diversity before the VTx fell off.
-Alex
IBCrazy is offline Find More Posts by IBCrazy
Old Jan 19, 2010, 07:33 PM
HariEdo is offline
Central Connecticut
Joined Jan 2010
Originally Posted by IBCrazy View Post
I got the idea from your circuit, HariEdo. You for some reason sent out the RSSI to a video switcher as well. If you build two of my diversity controllers and then send their outputs to a third channel diversity controller with the RSSI's of the winners such as in your design, then you now have a 4 input device.
"For some reason" like posts #31 #32 #33 in this thread. It was my intention to put the winning RSSI out for this purpose. But like you, I aim to make a one-board 4x version, with all comparators together.
Old Jan 20, 2010, 01:51 AM
renatoa is online now
Find More Posts by renatoa
Romania, Dolj, Craiova
Joined Sep 2007
Why not build a "pyramid" made of four 8dB standard patches?
They have 90 degrees coverage, so will close the circle pretty nice ? No more tracking mechanics complications.
The idea is not mine, was issued first time by a guy Dimitris76, or in one of his threads, as a "mushroom" antenna approach. But the term "pyramid" is mine, patented already
renatoa is online now Find More Posts by renatoa
Old Jan 20, 2010, 03:12 AM
Freakazoid is offline
Find More Posts by Freakazoid
Freakazoid's Avatar
Roosendaal, Netherlands
Joined Dec 2004
90' conus on 8db patches? You sure?
I always thought it was more along the lines of 45' ?
Freakazoid is offline Find More Posts by Freakazoid
Old Jan 20, 2010, 05:17 AM
Joined Sep 2007
You may be right, the one I use is 60' at -3dB
http://worldnet.ro/detail.php?id_pro...ory=14&lang=en
Old Jan 20, 2010, 05:34 AM
JohnyGab is offline
Joined May 2008
Thats exactly the point of having a multi chanel diversity, not tracking required, reduced possiblility of mecanical failure...ect...no osd dependency
Old Jan 20, 2010, 07:12 AM
Shikra is offline
Find More Posts by Shikra
SILURIA / UK
Shikra's Avatar
United Kingdom
Joined Jun 2009
For multiple antenna using static RSSI Xversity, Don't forget, there may be other sources of RF around.
i.e. say pick up signal from another source that is stronger and different direction, I would expect your video would then switch to that antenna - possibly losing your video from the plane totally until antenna switched back.
Downside of vs the GPS tracker.
Picking good receiver location and strong video signal would minimise impact. And using measuring video frame quality would improve further if that's a feature of designs.
Would like to see how well it works in real world testing though. Always wondered what it would be like.
Shikra is offline Find More Posts by Shikra
Old Jan 20, 2010, 09:29 AM
IBCrazy is offline
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
Shikra, this is exaclty the reason you need to test the base station BEFORE turning on your Tx. It is also the reaon I only use a two channel. A 3 channel with three directional antennas is perhaps the best over all.
A good set up would be three 8 db patches. Two on the outside mounted 60-75 degrees apart and then one in the middle turned 90 degrees for better reception when banking. This gives you nearly 180 degrees of coverage and will keep a strong signal in a bank.
With the two channel unit, I place my antennas 60 degrees apart in the same polarization. However if going for distance in a moderately straight line, I suggest two patches aimed in the same direction 90 degrees rotated from one another.
-Alex
Old Jan 20, 2010, 09:32 AM
IBCrazy is offline
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
Don't forget you can always turn your base station manually to get more coverage. Your foot is much more reliable as an antenna tracker than sny electircal drive, just maybe not as accurate... but that's what the diversity is for
-Alex
Old Jan 20, 2010, 11:33 AM
Shikra is offline
SILURIA / UK
Shikra's Avatar
United Kingdom
Joined Jun 2009
-Alex
Agreed - always do that. And pick take-off points carefully to minimise further.
Biggest issue I experience is if someone drives by and stops to see what I'm up to - pick up bluetooth / wifi or ignition iterference. That has been my single biggest problem.
Now I think about it, I can't remeber the last time I needed to change. If I see interference on one I usually find it on the others too.
Anyway - interested in this and range you guys get. I like the idea for near range to maximise quality.
Old Jan 20, 2010, 12:26 PM
IBCrazy is offline
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
Shikra, I never considered somebody with a blue tooth or WiFi showing up. That's a good point. opne of the many reasons to stay out of the 2.4 GHz band unless you are in the middle of nowhere.
The best way to test the base station is simply to turn it on and rotate it back and forth over the area you intend to fly and see if your diversity LEDs switch at any one particular point.
I don't know if this will increase range (perhaps some if you use oppositely polarized antennas), but it sure increases your area. It nearly doubled my flying area. I have no desire to go out more than 1.5 miles, which is the end of my Tx anyway. However I do like to fly around all over the place.
-Alex
Old Jan 22, 2010, 08:31 AM
HariEdo is offline
Central Connecticut
Joined Jan 2010
I've gotten my Digikey box of parts. Still waiting on a Sparkfun box that may arrive today, and the first PCBs will take another couple weeks. I've already made improvements in my design files for a "revision 2" with more RSSI inputs, better indicators, smaller power components, etc. Will update with the horror stories (or successes) as things progress.
Mini-HowTo Build your own TX antenna for FPV IBCrazy FPV Equipment 3072 Sep 08, 2016 07:20 PM
Discussion trex 600e build your own fuse. catbalu Large Electric Helis 10 Oct 27, 2009 12:10 AM
Sold Build your own brushless motor sale pending Douglas Cheatwo Aircraft - Electric - Power Systems (FS/W) 1 Oct 07, 2009 11:26 AM
New Product Build your own two channel servo tester for less than $15! W9GFO Product Announcements 0 Sep 29, 2009 07:19 PM
Question Build Your Own Parkzone Mustang Question Blue Jacket Electric Warbirds 8 Sep 13, 2009 08:49 PM
