Romania, Dolj, Craiova
Joined Sep 2007
Read again what I wrote, I meant a 6dB OMNI, same class as your helix, but far easier to DIY.
Latest blog entry: JRSky - birth of a dream radio
![]() -dave |
Circular polarized antennas do not perform nearly as well as linear polarized units on a diversity controller. In fact, many truly circular polarized antennas have two inputs and need a special RX to use.
The diversity controller in this thread on a properly designed system will outperform a circular polarized antenna station for most FPV purposes. However, the circular will certainly perform better for an aerobatic aircraft flying fairly close range. |
Latest blog entry: Project Covert Ops: Long range ground...
Canada, ON
Joined Jan 2009
Don't know if you guys saw this yet. So I thought I would post it here. An explanation of Circular polarization.
http://www.frccorp.com/pdf/Why%20Cir...%20Antenna.pdf |
-dave |
NJ
Joined Sep 2006
Another question LM358 has two independent o-amps, is there a reason not to use one of them instead of two where the RSSI cmes in? |
No. I use one as the buffer for both RSSI's. I just drew the circuit as separate entities when in fact they are on the same chip.
Many of the circular polarized antennas are not truly circularly polarized. However, when you get into expensive right hand and left hand polarized systems, then yes these are truly high performers. Unfortunately these are rare and expensive. The difference between two on a diversity system an a single circular is that there are two antennas on the diversity system. The dual antennas work based on the signal to noise ratio. Thus if one antenna receives a lot of noise, a diversity system will continue to select the opposing signal. You do not get that capability with one antenna. This is truly an excellent discussion. I am happy to have a disagreement with another of your caliber. After all, our opinions are based on our experiences. And if we all agreed, then there would be little point to these forums. |
IB,
I apologize for derailing your thread. FYI, L-Com, (previously hyperlink technologies) has LHCP and RHCP patches for $14 http://www.l-com.com/item.aspx?id=21759 As far as building your own antenna and it outperforming commercial designs, it is very difficult to do without some type of antenna analyzer. Attached is a pic of one I have access to. I am all for experimentation but if you are not measuring, you are just guessing. At microwave frequencies a millimeter of difference can change your SWR immensly. I would love to test your circuit and compare to my current amateur diversity systems. I currently use one designed by Matt Klarich for Black Widow and a beta unit from RC-CAM before it became DPCAV's Oracle. Old, but reliable. Perhaps you could design a COFDM video transmitter and reciever? That would take this hobby to a whole new level! Thanks for your time. -dave |
Central Connecticut
Joined Jan 2010
I think the discussions on what works best, and what might be an issue, are not derailing the thread. That's just my opinion though.
I'm still working on my own designs. The first design (heavily cribbing from IBCrazy's) which I posted earlier worked okay, but I had some issues with part dimensions. I also wanted to go the next step and support four inputs, audio outputs, and lights. I'm using a common pre-packaged microcontroller to do the logic part. I've got this PCB in the fab house now.
Awesome! You'll have to send me one for a demo. I'll reimburse you the parts and shipping expense.
NJ
Joined Sep 2006
I feel so dumb, I finished building the controller, now I went to find RSSI pins on my RXs and it doesn't look good. I got 2 RXs one from RangeVideo and the other from DPCAV, both are racewood units, both look identical inside, both have exactly same looking RX unit. On the DPCAV one I found a pin which is 2.2v with no signal and 1.8v with signal and the rangevideo one I cannot find anything... This is very frustrating.
The RV version will have one. Perhaps you haven't checked all of the pins?
In a pinch, you can buy a new module for $20 or so. However, once you do find the RSSI pin on the other RX, you are going to have to scale them identically. This is done with the potentiometer on the buffer and adjusting the gain on one (or both) LM358 units in the buffer. Let me know what your RSSI values are and I'll tell you how to set it up. -Alex |
| Thread Tools | |
| Mini-HowTo Build your own TX antenna for FPV | IBCrazy | Video Piloting (FPV/RPV) | 2535 | May 10, 2013 02:09 PM |
| Discussion trex 600e build your own fuse. | catbalu | Large Electric Helis | 10 | Oct 27, 2009 12:10 AM |
| Sold Build your own brushless motor sale pending | Douglas Cheatwo | Aircraft - Electric - Power Systems (FS/W) | 1 | Oct 07, 2009 11:26 AM |
| New Product Build your own two channel servo tester for less than $15! | W9GFO | Product Announcements | 0 | Sep 29, 2009 07:19 PM |
| Question Build Your Own Parkzone Mustang Question | Blue Jacket | Electric Warbirds | 8 | Sep 13, 2009 08:49 PM |
