Old Jan 22, 2010, 02:58 PM
boredom.is.me is offline
Find More Posts by boredom.is.me
Micro Boat Forum Founder
boredom.is.me's Avatar
United States, GA, Buford
Joined Nov 2007
Originally Posted by teookie View Post
Yeah, but on a model that is so lite I'm wondering if it will induce unwanted control inputs. P-factor in airplanes is caused by the same phenomenon after all.
Hurry up and fly the thing. We will have an answer after that.
boredom.is.me is offline Find More Posts by boredom.is.me
Old Jan 23, 2010, 08:52 PM
Teckos is offline
Find More Posts by Teckos
Teckos's Avatar
Joined Jan 2009
Exhausts completed!!
Will make the skids tomorrow and hopefully do some flights with the test fuselage.
Teckos is offline Find More Posts by Teckos
Old Jan 24, 2010, 07:30 AM
RCvertt is offline
Find More Posts by RCvertt
RCvertt's Avatar
Joined Aug 2007
Does anyone recognize what gyros and ESC's these are?
RCvertt is offline Find More Posts by RCvertt
Old Jan 24, 2010, 11:35 AM
hoverman is offline
Find More Posts by hoverman
hoverman's Avatar
Netherlands
Joined Sep 2006
Hey RCVertt, maybe this site helps, it has some quite detailed pictures of the same model
http://www.oldcake.net/redirect.php?...&goto=lastpost
It also shows his preliminary test model.
There is another video of the same model on Youtube which shows his controll movements.
Ultraman Matjyro VTOL RC model ラジコン マットジャイロ (1 min 19 sec)
BTW, the gyro's look like some kind off GY401 remakes..i guess.
Marijn
hoverman is offline Find More Posts by hoverman
Old Jan 24, 2010, 12:27 PM
Teckos is offline
Teckos's Avatar
Joined Jan 2009
Done with the fuselage.
Old Jan 24, 2010, 07:14 PM
RCvertt is offline
RCvertt's Avatar
Joined Aug 2007
Originally Posted by hoverman View Post
Hey RCVertt, maybe this site helps, it has some quite detailed pictures of the same model...
Cool. Thanks for the info! I agree with the 401 clone idea. It looks a little jittery when it lands and at some places in flight like v22chap showed in his gyro tests.
@Teckos- Nice job. Looks like it's ready for flight testing.
Old Jan 25, 2010, 02:50 AM
meatbomber is offline
Find More Posts by meatbomber
Square-rigger
meatbomber's Avatar
Klatovy, Czech Republic
Joined Mar 2004
Teckos your fuselage is fantastic !
If someonme is iterested there is a nice card model (could easily built in foam too) of the skorpion from Avatar that can be downloaded here: http://myhobbycraft.blogspot.com/
meatbomber is offline Find More Posts by meatbomber
Old Jan 26, 2010, 05:14 AM
elossam is offline
Find More Posts by elossam
Joined Feb 2006
No idea about the ESCs but the front gyro seems to be a GY401 as it only has one input wire and one output one, due to its placement it must control roll axis. The lateral one has a red label and two output wires. It looks like a GY352 (discontinued FUTABA two axis gyro in a single box made in two versions: for heli control and for fixed wing control) it should control the other two axis. GY352 is basically aTWO GY401 in a single box plus the possibility of inner V mixer between both channels, remote gain, AVCS...
elossam is offline Find More Posts by elossam
Old Jan 26, 2010, 11:52 AM
grumman5277 is offline
Find More Posts by grumman5277
grumman5277's Avatar
Troy ,OH
Joined Jan 2004
You guy's read my mind. Probably the coolest vehicle in the movie.The counter rotating blades took me by surprise as someone knew what they were doing when they created the concept for the movie.
I think I may design one after the actual drive they used.Should not be to difficult using bevel gears.
grumman5277 is offline Find More Posts by grumman5277
Old Jan 26, 2010, 02:20 PM
Boneswamped is offline
Find More Posts by Boneswamped
RC Group therapist
Boneswamped's Avatar
DeRidder LA.
Joined Nov 2008
Great work Tecos! When do you expect to do the maiden? Please get some video of your project for us.
Regards,
-Mike
Boneswamped is offline Find More Posts by Boneswamped
Old Jan 26, 2010, 09:39 PM
b-29er is offline
Find More Posts by b-29er
Buzz Run Extraordinare!
b-29er's Avatar
USA, MI, Sanford
Joined Jul 2006
If you get that running, you'll have to make a version of the hornet from halo 3.
b-29er is offline Find More Posts by b-29er
Old Jan 26, 2010, 11:49 PM
Rodan is offline
Find More Posts by Rodan
Rotor madness!
Rodan's Avatar
Northern AZ
Joined Oct 2006
Has anyone run any calculations for a larger scale version?
I did some (really) rough numbers for a 1/8 scale, and came up with a 2 meter model, which would put the 'rotor' span at ~ 600mm. This is about the same as a TRex 450, which runs 315-335mm blades. A while back, I built a scale TRex 450 that weighed a bit under 1.5kg, and it was marginal. A 2m model is going to weigh something like 7-9kg, and I don't think scale sized rotors of this design would have a prayer of getting it off the ground. Even with doubled rotors (contra-rotating) on each side (which would be a mechanical nightmare), I don't think it would be efficient enough to have any reasonable flight performance...
Any thoughts?
Rodan is offline Find More Posts by Rodan
Old Jan 26, 2010, 11:55 PM
b-29er is offline
b-29er's Avatar
USA, MI, Sanford
Joined Jul 2006
You could try more blades...
Old Jan 27, 2010, 12:19 AM
Rodan is offline
Rotor madness!
Rodan's Avatar
Northern AZ
Joined Oct 2006
That only works to a certain point... lift generated is not going to increase in direct proportion to the number of blades. If we bump the rpm up that may work, but at this size, it would take the equivalent of a 50cc gas engine to turn them 6000-7000rpm (each side).
A good design example is the V-22 Osprey... look at the size of the props necessary (in relation to the size of the a/c) to generate sufficient lift. The SA-2 as depicted in the movie has nowhere near the prop area in proportion to the size of the a/c.
New Product Pitts Samson 2, the new biplane in the 70e-class from Hyperion G.Hanssmann Sport Planes 19 Jan 13, 2010 06:56 PM
Question Has anyone bought from Hobbyson? thannamhbfp Electric Heli Talk 11 Jan 01, 2010 09:42 PM
Question Has anyone built from Robin Andrew's plans through Traplet Publishers? flying jeep Electric Plane Talk 1 Dec 23, 2009 10:17 PM
Discussion Has anyone ordered lately from parkscalemodels.com? aranel The Builders Workshop 3 Dec 14, 2009 05:06 PM
Poll Has anyone built the Mini-Telemaster kit from Hobbylobby? flying jeep Electric Plane Talk 8 Dec 12, 2009 05:53 PM
