Old Jan 18, 2010, 09:40 PM
Teckos is offline
Find More Posts by Teckos
Teckos's Avatar
Joined Jan 2009
Originally Posted by foam and tape View Post
could the flybars still be attached to the rotors? if so, then you possibly won't need the gyros. Maybe exept just one for roll?
I planned on doing that at the beginning but then decided it wouldn't look scale... I hope I wasn't wrong lol
Not sure I can still attach them since the shafts are really short (the blades could hit the aluminium arms)
Teckos is offline Find More Posts by Teckos
Old Jan 18, 2010, 10:19 PM
foam and tape is offline
Find More Posts by foam and tape
Retardedly intelligent
foam and tape's Avatar
beavercreek,ohio
Joined Jan 2007
yup it would detract from the looks though
Looks awesome, alot better than mine
foam and tape is offline Find More Posts by foam and tape
Old Jan 19, 2010, 04:36 AM
fethi is offline
Find More Posts by fethi
Joined Jan 2010
hi Teckos,
good design for the fuselage, you did not think of introducing the fma copilot into your dual-rotor? if yes a small diagram of installation is wished, thank you
fethi is offline Find More Posts by fethi
Old Jan 19, 2010, 10:43 AM
LedKitty is offline
Find More Posts by LedKitty
I even seen a house fly!
LedKitty's Avatar
Montreal!
Joined Oct 2003
Teckos, you are going to make your templates available as a PDF, right?
That looks totally awesome!
I've got a lot of Depron and a Tracy Chacon action figure standing by...
Also, from what I read about the SA-2 online: http://james-camerons-avatar.wikia.c...le_SA-2_Samson
I believe the idea behind the co-ax rotors in the ducts was to give more lift while keeping rotor diameters down. I suppose you could always increase the pitch of the lower rotors to improve effectiveness...
Just thinking out loud
Kitty
LedKitty is offline Find More Posts by LedKitty
Old Jan 19, 2010, 06:29 PM
Boneswamped is offline
Find More Posts by Boneswamped
RC Group therapist
Boneswamped's Avatar
DeRidder LA.
Joined Nov 2008
Kitty
I agree with you 100% Kitty. In addition to a reduced rotor footprint, the coaxial setup would cancel motor torque on each side thus removing another unwanted input when torque varies between left and right sides. I believe an increase or decrease in torque(with single rotors) would otherwise require a more complex mixing system similar to a CH-47.
Didn't the SA-2 have a variable dihedral in the film? It does on the Video game.
I'm Loving this project keep up the great work!
Regards,
-Mike
Boneswamped is offline Find More Posts by Boneswamped
Old Jan 20, 2010, 12:03 PM
Teckos is offline
Teckos's Avatar
Joined Jan 2009
Very quick update: these are temporarily glued just for the pics
Need to work on the air intakes, exhausts and skids when I have time.
I should have time to tweak the mixes and test fly it this week end
Sorry LedKitty but I have no plan except a couple of miscut sheets of depron that can give an idea of the shapes. Anyway, most of the parts have been trimmed a lot so nothing will be accurate I'll shoot the only drawing I made tho.
Old Jan 20, 2010, 12:07 PM
Teckos is offline
Teckos's Avatar
Joined Jan 2009
Fethi, the idea behind that build was to create the Samson with materials I already have. Plus the FMA Copilot thingy sounds rather heavy... and expensive
Old Jan 20, 2010, 02:17 PM
teookie is offline
Find More Posts by teookie
Perfect 3pt inverted landing!
teookie's Avatar
USA, AL, Huntsville
Joined Oct 2008
I'm going to throw something out here cause I think this is a cool project. No, I don't really have any qualifications...
I believe the coaxial rotors are required to eliminate gyroscopic procession effects when tilting the ducts. I could be wrong, haven't thought about it to much yet.
teookie is offline Find More Posts by teookie
Old Jan 20, 2010, 04:02 PM
LedKitty is offline
LedKitty's Avatar
Montreal!
Joined Oct 2003
Which would certainly decrease the torque forces on the swivel mount wouldn't it? I believe that was an issue with the V-22, the torque involved in rotating those massive rotors... wasn't it?
K.
Old Jan 20, 2010, 04:51 PM
boredom.is.me is offline
Find More Posts by boredom.is.me
Micro Boat Forum Founder
boredom.is.me's Avatar
United States, GA, Buford
Joined Nov 2007
Ya but this is RC. The amount of torque on the mounts are not (or at least shouldn't be) anything to worry about. There isn't the same weight behind the torque as there is on the V22. It is like mounting a big 20 cylinder engine into a massive boat. That is way harder and has more forces than a scale boat of a smaller size.
BIM
boredom.is.me is offline Find More Posts by boredom.is.me
Old Jan 20, 2010, 05:37 PM
RC Group therapist
DeRidder LA.
Joined Nov 2008
Hi Teckos,
Looks incredible! When are you expecting to do the maiden flight? Keep up the posts, very impressive.
Old Jan 20, 2010, 08:32 PM
EDDIEGIGOWATTS is offline
Find More Posts by EDDIEGIGOWATTS
1.21 gigawatts
EDDIEGIGOWATTS's Avatar
Fort.lauderdale Florida
Joined Jul 2006
Looking awesome Teckos
may bee put smaller flybars so they don't stick out so much
they would add so much stability to your model
just like those little foam hellis
Eddie
EDDIEGIGOWATTS is offline Find More Posts by EDDIEGIGOWATTS
Old Jan 21, 2010, 09:34 AM
teookie is offline
teookie's Avatar
USA, AL, Huntsville
Joined Oct 2008
BIM
Yeah, but on a model that is so lite I'm wondering if it will induce unwanted control inputs. P-factor in airplanes is caused by the same phenomenon after all.
Old Jan 21, 2010, 09:46 AM
LedKitty is offline
LedKitty's Avatar
Montreal!
Joined Oct 2003
Regards,
-Mike
Mike, if James Cameron did his homework (and it sure looks like he did!) I believe the fans do indeed tilt as well as swivel.
If you watch the YouTube clip of the GressAero eVader that ran of the Discovery Channel, you'll see the the fans on their model do the same:
http://www.youtube.com/watch?v=uJLkKjuA5K4
Alas the sound is horrible on that clip, but them moving picture thingies show what I'm talking about It's all about increasing stability of course.
K.
Old Jan 22, 2010, 01:32 PM
Shedofdread is online now
Find More Posts by Shedofdread
Deniable plausibility
Shedofdread's Avatar
Derbyshire, UK
Joined Aug 2008
Just to prove there's 'nothing new under the sun' - the Nord 500
Best of luck and looking forward to seeing the first flying SA2,
S
Shedofdread is online now Find More Posts by Shedofdread
New Product Pitts Samson 2, the new biplane in the 70e-class from Hyperion G.Hanssmann Sport Planes 19 Jan 13, 2010 06:56 PM
Question Has anyone bought from Hobbyson? thannamhbfp Electric Heli Talk 11 Jan 01, 2010 09:42 PM
Question Has anyone built from Robin Andrew's plans through Traplet Publishers? flying jeep Electric Plane Talk 1 Dec 23, 2009 10:17 PM
Discussion Has anyone ordered lately from parkscalemodels.com? aranel The Builders Workshop 3 Dec 14, 2009 05:06 PM
Poll Has anyone built the Mini-Telemaster kit from Hobbylobby? flying jeep Electric Plane Talk 8 Dec 12, 2009 05:53 PM
