Old Mar 28, 2010, 10:51 PM
ropanach is offline
Find More Posts by ropanach
Dragon Slayer
ropanach's Avatar
Shelton,WA
Joined Nov 2004
I've got the stern worked in today, and have started working up the bow where it needs to be.
Oh by the way does any one need to clean out there spring clamp collection, I could use about 10 more, so this could go a little faster, lots of area to glue but not enough clamps.
ropanach is offline Find More Posts by ropanach
Old Apr 02, 2010, 12:29 PM
ropanach is offline
Dragon Slayer
ropanach's Avatar
Shelton,WA
Joined Nov 2004
I've got the bulkwalks set, dry fitting the bowsprit, makeing sure that all is good before I start fairing the hull out.
Old Apr 02, 2010, 06:35 PM
ropanach is offline
Dragon Slayer
ropanach's Avatar
Shelton,WA
Joined Nov 2004
Ordered some hardwear fore the Wawona today, from www.scalehardware.com/miniature-rivets-c-10
Hope there close to what I need, my metric's ant so good.
Old Apr 06, 2010, 08:11 PM
ropanach is offline
Dragon Slayer
ropanach's Avatar
Shelton,WA
Joined Nov 2004
so far I've got the bulkwalks on, got the hull faired out, need to start setting in some ballards, witch will go through the decks, need to set in recivers for the masts, need to, need to ,need toooooo. ETC. you know how it goe's
Old Apr 06, 2010, 08:42 PM
CPTGUY is offline
Find More Posts by CPTGUY
Thunder Bay Ontario Canada
Joined Jul 2007
Oh by the way does any one need to clean out there spring clamp collection, I could use about 10 more, so this could go a little faster, lots of area to glue but not enough clamps.[/QUOTE]
Haven't you heard? You will never have enough clamps - let alone too many
She's looking really great!
Cheers
CptGuy
CPTGUY is offline Find More Posts by CPTGUY
Old Apr 06, 2010, 08:43 PM
Schrott is offline
Find More Posts by Schrott
Dolores, Colorado
Joined Dec 2007
this is very,very nice
Schrott is offline Find More Posts by Schrott
Reply With Quote  (Disabled)
Old Apr 06, 2010, 08:55 PM
ropanach is offline
Dragon Slayer
ropanach's Avatar
Shelton,WA
Joined Nov 2004
CPTGUY:
you are sooo right, you never have enough clamps, and if you do you they are to small or to big
Schrott:
thanks. it's a lot of work, but a lot of fun
Old Apr 07, 2010, 12:40 AM
MILLERTIME is online now
Find More Posts by MILLERTIME
Taking care of the pond.
MILLERTIME's Avatar
United States, CA, Sanger
Joined Apr 2004
Looking good...
MILLERTIME is online now Find More Posts by MILLERTIME
Old Apr 07, 2010, 11:45 PM
Aerominded is offline
Find More Posts by Aerominded
Monterey Bay California
Joined Feb 2004
Hee hee, yep. this is about the time where I start semi-detail planning the next steps on paper... with so many little things to do before the deck goes on, sometimes it is hard to decide what to actually work on to keep the project moving.
"Build cards", index card checklists, basically, help when scratch building!
Aerominded is offline Find More Posts by Aerominded
Old Apr 08, 2010, 06:58 PM
ropanach is offline
Dragon Slayer
ropanach's Avatar
Shelton,WA
Joined Nov 2004
I tend to take the multipal items first, then move from bow to stern, checking and rechecking all that need to be in stalled, then i place the decking, and check agian, It helps to have a deck plan you can look stright down at, in scale so you don't miss any thing.
Old Apr 19, 2010, 07:54 PM
ropanach is offline
Dragon Slayer
ropanach's Avatar
Shelton,WA
Joined Nov 2004
I've done a dry fit of the mast sets, makeing sure all is were it should be, some how I got it right, I cut some mohogany blocks 2-1/4" x 2" x 2" and drilled them to fit the 3/4' mast stock bevaled the bottoms so they would fit snug into the hull, cut a 3/8" rabbitt joint into the bottoms to fit over the keel. It should hold quite well, I hope, the masts will be pulling on the keel,and deck on a side run, and they will be pushing into the ribs for a down wind run, I'll need to install some good rigging to hold it all, don't need to be snapping masts of at the deck line.
Old Apr 20, 2010, 12:38 AM
MILLERTIME's Avatar
Joined Apr 2004
Blocks look like they should do the job.
Old Apr 20, 2010, 06:38 PM
ropanach is offline
Dragon Slayer
ropanach's Avatar
Shelton,WA
Joined Nov 2004
Millertime:
Yes they should do the job, I hope, there will be alot of pressure from all directions, down is the one I fear the most, I built a Boston day sailor about 10 years ago that the mast punched through the bottom, I didn't think about the down pressure that was being apllied to the hull, all I worried about was side pressuer, I think these will give a good foot print on the hull, and the mast sets 1/8" above the keel, so it should work ( fingers crossed )
Old Apr 21, 2010, 12:50 AM
MILLERTIME's Avatar
Joined Apr 2004
Are the mast going to be removable? If so you might want to use brass sleeves, the wood will swell and be hard to remove.
Discussion 1968 Miss Bardahl (1:10 scratch build) Capt.Crash Racing Boats - Electric 158 Feb 29, 2016 08:10 AM
Discussion Build Log: Monogram "build'n fly" DHC-2 Beaver lw_hughes Scratchbuilt Indoor and Micro Models 9 Nov 17, 2009 08:01 PM
Question AMD Phoenix (Wingeron) Build Questions, Build, and Pics Greygoosegregg Slope 82 Sep 11, 2009 04:40 PM
Discussion Another one bites the dust: schooner Wawona patmat2350 Dock Talk 9 Mar 05, 2009 01:54 PM
