Old Jan 02, 2010, 10:34 AM
hunter7193 is offline
Find More Posts by hunter7193
MI
Joined Aug 2009
RCTimer 30A Programmable ESC
I recently purchased an RCTimer 30A Programmable ESC, and am a little confused. Does it only have one speed? It seems that when the throttle reaches the highest point, the motor turns on to one speed but won't go higher or lower. I need an ESC with completely variable speed. Did I waste my money?
hunter7193 is offline Find More Posts by hunter7193
Old Jan 02, 2010, 12:02 PM
eflightray is offline
Find More Posts by eflightray
An itch?. Scratch build.
eflightray's Avatar
South Wales U.K.
Joined Mar 2003
Just looked it up on ebay. It should be a normal brushless speed controller with a, quote - "Smooth, linear and precise throttle response."
Have you set it up ?, (programed it). It recommends connecting the negative to the battery first and then the positive, for correct arming.
But then it is rather cheap, sometimes that's Ok, sometimes ............
eflightray is offline Find More Posts by eflightray
Old Jan 02, 2010, 12:29 PM
MI
Joined Aug 2009
I set it up, just like it said in the manual. Which, by the way is the HobbyWing manual for their esc's since this is a HobbyWing rip off. I'm using a T connector so I can't just connect the negative first. As for programming, I've got the throttle set up correctly, I tried changing the startup mode and the Timing but neither of them changed anything either. At least it's supposed to work...
Old Jan 02, 2010, 12:48 PM
eflightray's Avatar
South Wales U.K.
Joined Mar 2003
Have you set it up for the throttle stick range ?
I don't know that ESC, but usually it involves throttle trim all the way down, throttle stick high, (max), then plug the battery in. (WARNING: Be very very careful if trying this, ensure the plane cannot move, just in case).
Once the ESC arms, then it's throttle stick to low.
This is so the ESC knows the full throttle range.
That's about the only thing I can think of to try.
Old Jan 02, 2010, 01:06 PM
rimshotcopter is online now
Find More Posts by rimshotcopter
rimshotcopter's Avatar
Joined Aug 2009
Maybe it is in governor mode. Do you have a programming card?
rimshotcopter is online now Find More Posts by rimshotcopter
Old Jan 02, 2010, 02:01 PM
MI
Joined Aug 2009
I don't have a programming card, but I didn't read anything about a governor mode in the manual. I'm assuming governor mode would be for gas helis, and the esc doesn't give me that option when I am in program mode.
Old Jan 02, 2010, 02:03 PM
Joined Aug 2009
Electric has a governor mode too. check it, that is what it sounds like to me.
Old Jan 02, 2010, 02:05 PM
Joined Aug 2009
Or the ESC is defective but if that was so, it would not function at all in my opinion.
Old Jan 02, 2010, 02:27 PM
MI
Joined Aug 2009
Nope I got it fixed. There was a problem with my receiver after all. I was a little quick to blame the new guy. It looks to me like a fantastic ESC, and it was cheap so time will tell. Sorry about the false alarm, thanks for your help.
Sold Kms 30a esc Mike Freas Aircraft - Electric - Power Systems (FS/W) 2 Dec 29, 2009 11:14 AM
Found Eflite 30A SB Brushless ESC AEMontoya Aircraft - Electric - Power Systems (FS/W) 1 Dec 22, 2009 10:37 AM
Question HK SS esc's, programmable vs non-programmable. Jimmy JFlyer Power Systems 2 Dec 14, 2009 08:20 PM
Sold Mystery Programmable 30A Brushless ESC Aobid Aircraft - Electric - Power Systems (FS/W) 3 Sep 08, 2008 02:29 PM
Discussion SuperSimple 30A ESC (card programmable) Berkie Power Systems 5 Aug 03, 2008 08:10 PM
