4 axis screen for MACH 3
Here are a couple of screen shots of a screenset that I just finished for a 4 axis hot wire cutter.
![]() ![]() Here is the link to the screenset. http://odysseywood.us/profili/CNC%20Foam.zip Sam |
Eddie, MACH software will only allow you to see the XY axis and not the AB. That being said since MACH is only a control interface for the cutter only seeing the XY is not a big draw back. By the time you send your g-code to MACH you should have already run it through a simulation program to be sure your design will cut as you expect.
dpot, There are several programs available to write 4 axis g-code. The program I have been using is Profili Another program that looks very promising is CNCWorkbench which I have just started to work with. There is also LazyCAM which I have not tried yet but does have 2D and 3D foam capabilities. Here is a link to a program that will convert GMFC cut files to g-code. http://www.sokoll.net/doku.php/pasti...rsion_software Sam |
Maryland, USA
Joined May 2004
Sam, thanks for sharing your screen set. I was looking for a way to visualize the 4 axis hotwire cutting and found your screen set. Worked great. I was answering someone's questions today and got interested if you could manually edit g-code to use in a hotwire cutter. Here a quick video I made featuring your screen set. If you want to check it out: http://www.rcgroups.com/forums/showp...33&postcount=8
-Kwok |
sorry hope this is better
On the "Motor Outputs" screen you can enable and disable the axes. Place a checkmark in the X, Y, & Z "Enable" boxes, and apply the following pins: X-Step: 3 Y-Step: 5 Z-Step: 7 X-Direction: 2 Y-Direction: 4 Z-Direction: 6 Set the "Step" and "Dir" port as 1. If you want to reverse the directions of any of the axes, place a checkbox in the "Dir Low Active". |
| Thread Tools | |
| Discussion 3 axis Gyrobot 900 wing | Connexxion | UAV - Unmanned Aerial Vehicles | 15 | Jul 26, 2011 05:41 AM |
| New Product InvenSense 3-axis gyro single-chip <$3 | rimshotcopter | DIY Electronics | 17 | Sep 25, 2010 10:08 AM |
| New Product InvenSense 3-axis gyro single-chip <$3 | rimshotcopter | Coaxial Helicopters | 0 | Nov 23, 2009 06:20 PM |
| Discussion Cheapest DIY stepper controller for 3-4 axis? | Niggo | The Builders Workshop | 11 | Mar 08, 2007 10:27 AM |
| Idea Fast 3-axis magnetometer for microflight 3-axis HH-gyro? | Nils123 | Indoor and Micro Models | 5 | May 01, 2006 09:13 AM |
