Old Jan 01, 2010, 06:03 AM
amigob is offline
Find More Posts by amigob
Netherlands
Joined May 2009
Flyfly mig 29 OVT ak MIG 35
Hi all
I am building a fly fly MIG 29 OVT and a lot af changes are needed to get this all to work.
The setup
1 x Flyfly MIG 29
2 x Wemotec midi fans
2 x 90mm RC lander TV's
2 x Turnigy B36-56-06 1800kv Inrunner
2 x Turnigy Plush 80A w/ UBEC Speed Controller
8 x HS-82MG servos
2 x 3S1P 5000 mAh Flight Max 30C
1 x AR7000
1 x on-board mixer for trust vectoring ( home made )
I started with the Tailrons, I made them a little bit stronger :-)
Bart,
amigob is offline Find More Posts by amigob
Old Jan 01, 2010, 06:08 AM
amigob is offline
Netherlands
Joined May 2009
Home made Wing servo mounts
Servo is glued to the cover.
big ailerons : the mig won't be a racer but a 3D EDF
Bart,
Old Jan 01, 2010, 06:19 AM
amigob is offline
Netherlands
Joined May 2009
When I tried everything out to get the Center of gravity correct. found out that the lipo had to go in to he nose.
After change the nose, so that the lipo will fit into it
Old Jan 01, 2010, 06:31 AM
amigob is offline
Netherlands
Joined May 2009
No I am try to get al the electronics in place and make sure tha every thing will work.
White are 8 servo's
Yellow are the two EDF's
Green the speed controllers
Pink AR7000 receiver
Red power Lipo
The question is what do I need to do to get this al working without any
problems. Because all servo wires are running beside the motor wires.
- ferrite coiling on the receiver side for all servo wires ?
- Twist motor wires, Do I need to twist or braiding ( don't no if this is the
correct name but I mean the take the outside wire en cross it over the middle wire ) ?
- something else ?
I never had a configuration like this and I hope to do it the first time wright.
Bart,
Old Jan 01, 2010, 08:19 AM
Chris True is offline
Find More Posts by Chris True
St. Mary, Maryland, United States
Joined Dec 1996
With 2.4 I do not think you'll have any problems.
Chris True is offline Find More Posts by Chris True
Old Jan 01, 2010, 12:46 PM
M.Huerta is offline
Find More Posts by M.Huerta
M.Huerta's Avatar
Gilbert, AZ
Joined Jun 2008
+1, only on 72 might you have problems
M.Huerta is offline Find More Posts by M.Huerta
Old Jan 10, 2010, 02:28 PM
amigob is offline
Netherlands
Joined May 2009
update
cables
Smoothing
Bart,
Old Jan 26, 2010, 02:09 AM
jofro is offline
Find More Posts by jofro
Joined Jan 2010
Mig29FlyFly
Hi Bart, Im also in proces building twin Mig, using Vemotecs/ARC/80amp,my will run on 2 six cell 4-5000 packs. I will use fixed l/gear to keep it simple also will install smaller Ail. Do you have intention to reduce those huge rear outlets?? Joe, Banana Coast/Aust.
jofro is offline Find More Posts by jofro
Old Mar 31, 2010, 08:43 AM
mikecopey is offline
Find More Posts by mikecopey
mikecopey's Avatar
United States, FL, Oviedo
Joined Dec 2008
Nice project !!!
any updates ?
Hoping you gave it a custom paint job.....
mikecopey is offline Find More Posts by mikecopey
Old Aug 24, 2010, 10:41 PM
takiss is offline
Find More Posts by takiss
Patras, Greece
Joined May 2007
Suscribed.
takiss is offline Find More Posts by takiss
Old Aug 26, 2010, 03:22 AM
jofro is offline
Joined Jan 2010
Bart, hows the 3D Mig29 going ? Love to hear to share some experience, Joe.
Old Oct 28, 2010, 12:22 PM
backman8571 is offline
Find More Posts by backman8571
Jet Foamy addict
Dallas Texas
Joined Feb 2005
Any new pictures, i just picked up the RC-Lander version which has many updates to the frame
http://www.rclander.com/default.aspx...f-a849a3be2de6
Per
backman8571 is offline Find More Posts by backman8571
Idea 18" WS Mig 29 and F-35 with plans - updated Fisticuffs! Pusher Prop Jet Models 44 Aug 26, 2011 07:36 AM
Discussion HET Mig-29 Vs FlyFly Mig 29 skydve76 Electric Ducted Fan Jet Talk 2 Oct 06, 2008 12:32 PM
Discussion P-180 powered Mig-29 OVT likai Jet Turbines 1 Jul 27, 2008 07:29 PM
Discussion Mig-29 OVT powered by single P-180 likai Fuel Jet Talk 0 Jul 17, 2008 09:45 AM
New Product Finally FlyFly Mig 29 will be available schumnig Foamy EDFs 18 Apr 29, 2008 07:33 PM
