Old Jan 01, 2010, 01:03 AM
ORANATOR is offline
Find More Posts by ORANATOR
Slope Stud
ORANATOR's Avatar
United States, CA, Oceanside
Joined May 2001
Polyester glass different from Epoxy glass
I got some free glass and I was told there is a difference between glass made for polyester resin and glass made for epoxy resins...
I didn't know that.
How do you tell the difference???
Oranator
ORANATOR is offline Find More Posts by ORANATOR
Old Jan 01, 2010, 01:51 AM
tomahawkflier is offline
Find More Posts by tomahawkflier
Christchurch, New Zealand
Joined Dec 2004
Polyester glass has a chemical in it which makes the resin wet the mat out better. I've only struck this with Chopped Strand mat. In my experience any woven cloth should be good with either Poly or Epxoy.
tomahawkflier is offline Find More Posts by tomahawkflier
Old Jan 01, 2010, 07:06 AM
Pinecone is offline
Find More Posts by Pinecone
Will fly for food
Maryland
Joined Sep 2004
Actually chopped strand mat is made for polyester resin. The binder used to hold it together will solubilize/wet out with ester resins (polyester or vinyl ester) but not with epoxy. So you need a special mat for epoxy.
But cloths are typically all the same.
BTW the binder used in chopped strand mat is typically starch.
Pinecone is offline Find More Posts by Pinecone
Old Jan 01, 2010, 07:15 AM
The SKY MAN is offline
Find More Posts by The SKY MAN
The SKY MAN's Avatar
uk/england
Joined Jun 2008
Interesting!
are we saying chopped strand should not be used with epoxy?
Iain
The SKY MAN is offline Find More Posts by The SKY MAN
Old Jan 01, 2010, 08:08 AM
stevext is offline
Find More Posts by stevext
stevext's Avatar
Joined Jul 2005
Hi
I was always taught to keep chopped strand mat (csm) for use with polyester resins and wovens with epoxy due to the binder in it as stated in the other post.
cheers
stevext
stevext is offline Find More Posts by stevext
Old Jan 01, 2010, 10:31 AM
Alex.Schweig is offline
Find More Posts by Alex.Schweig
Composites Kid
Alex.Schweig's Avatar
Lima, Peru
Joined Jul 2008
Some mats do work with epoxy and polyester as well as vinylester.
Most chopped strand mats, however, work only with polyester and will not make a good chemical bond with epoxy.
Cloths always have a "finish" or "sizing". The purpose of the finish is to promote the bond between the fibers and the matrix, thus stabilizing the composite.
"Volan", the most common finish in fiberglass cloth, is compatible with epoxy, as well as polyester and vinylester. "Silane" finish is usually found in S-2 glass cloth, and compatible with epoxy. The last finish is F-16 finish.
Alex.Schweig is offline Find More Posts by Alex.Schweig
Old Jan 01, 2010, 10:37 AM
ORANATOR is offline
Slope Stud
ORANATOR's Avatar
Joined May 2001
That's great..
I got 2 huge rolls of fiberglass and now it looks like I will be able to use them..
Stuff I got for FREE today....
Oranator
Old Jan 01, 2010, 10:52 AM
Composites Kid
Lima, Peru
Joined Jul 2008
Hi Oran, have you any idea what the weaves are?
The second looks like a stitched double bias.
If they are 40oz cloths, then they are bound to be stitched with at least two layers
-Alex
Old Jan 03, 2010, 01:52 PM
stevext is offline
stevext's Avatar
Joined Jul 2005
I'll guess at the bottom cloth being a biaxial too but the top one reminds me of a uni-directional roll?
Old Jan 03, 2010, 03:10 PM
ak79 is online now
Find More Posts by ak79
ak79's Avatar
United States, CA, Torrance
Joined Apr 2006
Be careful, if you need to go around some complex shapes, the epoxy won't disolve the binder in glass that's supposed to be used with poly. So it ends up being a bear to work with. I've used that stuff with epoxy plenty of times to build mold thickness, but best suited for flat projects.
ak79 is online now Find More Posts by ak79
Question Polyester and Epoxy resins: telling the difference. Sensiblenick Slope 10 Dec 09, 2009 09:41 PM
Discussion Reinforce Polyester fuselage with Epoxy / glass ? Boo Composites Fabrication 8 Sep 23, 2007 01:50 PM
