Old Dec 31, 2009, 10:45 PM
Scaledown is offline
Find More Posts by Scaledown
It must have a machinegun
Scaledown's Avatar
Perth, Western Australia
Joined Sep 2004
Build Log
Lavochkin La-5FN
I've just started a build of a 1.2m span Lavochkin La-5FN. I intended starting it 12 months ago for the scale buildoff, but work got in the way. So the smell of balsa dust and CA is my Xmas present to myself.
Its going to have retracts and flaps. I've bought all the hardware:
Hacker A30-14L for power
3300 3S Zippy lipo
Spekrum AR7000 receiver
Hyperion mechanical retracts
I used 3-views from a russian website and drew it up with my trusty non-digital 0.3mm pencil. I also found some video from a Soviet training film which helped me get the shape right.
The target weight is 1150g which will give me 120 watts/pound and 14.4oz/sqft loading.
I've attached a picture of the colour scheme I propose. I'm going to attempt some scale weathering for the first time.
Scaledown is offline Find More Posts by Scaledown
Old Dec 31, 2009, 11:49 PM
Scaledown's Avatar
Joined Sep 2004
I started with the tail surfaces. Conventional built up construction to give a symetrical airfoil.
The wing is a classic D box structure. The pic shows the first panel assembled over the plan. Note the feet on every second rib, used to get the washout right. I'm using 2 degrees. Profili2 draws these feet for you. Most critical is having the washout right when you add the D box sheeting. Once that top sheet is glued on the washout is locked in for all eternity.
The airfoil is a Ritz 2-30-14 at the root and a 3-30-14 at the tip
Old Jan 01, 2010, 12:09 AM
baldguy is online now
Find More Posts by baldguy
I eat glue
Canada, NS, Yarmouth
Joined Jul 2006
Very nice. Does this bird have split flaps?
baldguy is online now Find More Posts by baldguy
Old Jan 01, 2010, 02:20 AM
Scaledown's Avatar
Joined Sep 2004
That's the plan. They will just be made from 3mm sheet. Nothing fancy.
Old Jan 01, 2010, 03:37 AM
CryHavoc is offline
Find More Posts by CryHavoc
UAS Pilot - FAA# *******HRK
CryHavoc's Avatar
United States, TX, Copperas Cove
Joined Apr 2000
The LA-5 and -7 are one of my, if not my most, favorite Warbird. As far a Russian birds go they just look the part, down and dirty knife fighters. So, I'm always on the look out for kits and such.
I've got the HET-RC LA-5 kit as well as a WarbirdsRC LA-7. But, they are both a tad small for what I like right now and neither one have landing gear which my field needs. So when I recently stumbled upon this one, I ordered it right away;
http://www.cloudmodels.com/lavochkin.html
It'll be shipped out monday after the holiday. I don't know if I'm going to add flaps but I am going to add retracts and convert it to electric.
Good luck on your build,
CryHavoc is offline Find More Posts by CryHavoc
Old Jan 01, 2010, 09:20 AM
I eat glue
Joined Jul 2006
Just let us know when this one's available.
Old Jan 02, 2010, 12:08 AM
Glong-flyer is offline
Find More Posts by Glong-flyer
Glong-flyer's Avatar
Ballarat, Australia
Joined Jan 2007
Scaledown I like your line of thought with the Russian aircraft.
Mike, big call picking a favorite Warbird. The list is so long and so many things to consider. I still love the I-153 Chaika but then the Mig-3 but what about the I-16 Rata. Love them all.
Great subject and good luck with the build. I will be following alone for sure.
Pete
Glong-flyer is offline Find More Posts by Glong-flyer
Old Jan 02, 2010, 08:23 AM
Scaledown's Avatar
Joined Sep 2004
Cryhavoc
My brother has a Cloud Models Mosquito. Its a heavy plane because its got a lot of plastic, but it flies really well.
Pete
I seem to be attracted to Russian planes too. I've got an I-153, an IL-2 and a Mig 3. Perhaps its because they've got real combat credentials but they aren't over-represented on the flying field.
Here's a few more pics. The wing is coming along nicely. I'm trying to get a lot done this weekend because when I go back to work on Monday this build will slow down.
Old Jan 03, 2010, 08:22 AM
Smokin' Beaver is offline
Find More Posts by Smokin' Beaver
Registerd Beaver
Smokin' Beaver's Avatar
Australia, WA, Warwick
Joined Jul 2003
Nice!
This will be a good one to watch.
I'd been wondering what your next one would be...
phil
Smokin' Beaver is offline Find More Posts by Smokin' Beaver
Old Jan 03, 2010, 11:28 PM
WTFLYR is offline
Find More Posts by WTFLYR
WTFLYR's Avatar
West Central PA
Joined Dec 2008
I've always wanted to build an LA5 or 7. I sold my Alfa LA7, back when I knew I'd kill it. That was the last plane I should have sold, as my 190 is the best "grab and go" I have. Still, at this point I'm not adding ARFs to the collection, so an LA 5 or 7 build would be an excellent addition. I have no Soviet planes. A Sturmovik would be nice too, but the LA5 is better looking.
Your 3-view computerized pencil is my favorite building method. I've always said that a good 3-view with formers is almost a plan.
WTFLYR is offline Find More Posts by WTFLYR
Old Jan 05, 2010, 03:19 AM
Scaledown's Avatar
Joined Sep 2004
The Sturmovik has a generous wing area, so you can make it into a parkflier, but its not the prettiest plane. The La-5 has the big ugly air scoop on the top, but its the ugly bits that add character to a fighter.
Most people tell me I'm mad for not learning CAD. I'm just too lazy I think.
The biggest boon to the scale modeller is the prevalence of photocopiers that enlarge to any scale. I just take my three view drawing to work, type in the scale factor and run off a set of A3 sheets before the boss notices what I'm doing. I tape the sheets together and slide it under the translucent drafting film then trace my design over it. I often make the wing 5% to 10% oversize to lower the wing loading a bit.
Old Jan 19, 2010, 07:27 AM
Scaledown's Avatar
Joined Sep 2004
I've done a bit more work on the wing. The flaps and ailerons are done including the servo installation. I bought a digital servo for the flaps which I programmed to operate slow. I won't know if the flaps operate at the exact same deflection until I glue the torque rods in after I cover the wing.
I'm installing the retracts now.
Old Jan 19, 2010, 03:03 PM
vampire67 is offline
Find More Posts by vampire67
Charged up and buzzing
vampire67's Avatar
Germany
Joined Aug 2005
Real nice contruction sheme.
Quite fast too
I had some doubts but it might work if the angle of the rods corresponds with the angle difference on the servo attachment.
CAD is only helpfull when you want to cut parts directly with CNC.
3D is mostly a lot slower when using only moderatly priced systems and with the low training level of a hobbyist.
You seems to do well and quickly without computer, so why bothering.
The only benefit would be to get plans for publishing your designs.
Peter
vampire67 is offline Find More Posts by vampire67
Old Jan 19, 2010, 03:10 PM
WTFLYR is offline
WTFLYR's Avatar
West Central PA
Joined Dec 2008
Not at all. I used Pro-E for a number of years in mechanical design, but haven't found the desire to use it for model design. Sure it would be a good design enhancement tool, but the problem is that I would lose interest in building, if I were to sit at the computer. I like to get right to the balsa. Also, after enough builds, many of us can readily transform a 3-view into a design, and then a subsequent build, without the need for CAD. If anything, it's the design experience gained from designing with CAD, that helped reduce the desire for me to use it as a model design too. With a good outline, we literally form the design in our heads. For me, just the time spent getting the desired enlargement, printing, and taping all the sheets together is almost enough time away from the building table to cause me to lose interest in the build.
Old Jan 20, 2010, 06:39 AM
Scaledown's Avatar
Joined Sep 2004
I certainly don't have the skill to build straight from a 3 view (unless its a profile foamy!). I quite enjoy drafting, but if say I decide late in the design to move the wing back 10mm, there's an awful lot of lines I need to rub out and redraw. I presume that would be easier in CAD.
Alfa Lavochkin LA-7 CUBANO8 Parkflyers 71 Jun 17, 2014 02:53 PM
Discussion New ESM Lavochkin La 7 -80"spanVQ Warbirds Ldm Fuel Warbirds 12 May 16, 2013 04:10 PM
Build Log big lavochkin la-5FN hawaiianspork226 Foamies (Scratchbuilt) 199 Mar 04, 2011 02:01 AM
Build Log Lavochkin La-7 build slopeiron Slope 93 May 15, 2004 07:55 PM
Lavochkin La-7 Landing gear a must!!! Son House Parkflyers 0 May 09, 2004 10:55 PM
