Old Dec 31, 2009, 05:07 PM
dissymmetry is offline
Find More Posts by dissymmetry
G=667x10^-8 cm^-3 gm^-1 sec^-2
dissymmetry's Avatar
Joined Nov 2009
"Worlds Lightest LiPo Batteries"
This site I found not geared towards r/c, but to batteries and related accessories claims quite a few interesting items, worlds smallest, and lightest lipos, and I thought that it was a worthy enough resource to share.
http://www.powerstream.com/
They seem to want to cater to wholesale buyers of larger quantities, but they sell most things individually. Start with "batteries and packs", and look around at what they have. Its very interesting.
dissymmetry is offline Find More Posts by dissymmetry
Old Jan 01, 2010, 05:11 AM
ggcrandall1 is offline
Find More Posts by ggcrandall1
ggcrandall1's Avatar
USA, GA, Marietta
Joined Aug 2005
All the batteries I looked at (3) have a max discharge rate of .2C. Not much use as primary power for electric planes.
Glen
ggcrandall1 is offline Find More Posts by ggcrandall1
Old Jan 01, 2010, 05:57 AM
jj604 is online now
Find More Posts by jj604
ancora imparo
jj604's Avatar
Melbourne, Australia
Joined Jul 2005
0.2C ???
dissymmetry's post was specifically about the "World's lightest" category
The ultra light weight 0.33-1.6g specs say:
These are great cells. They are designed for low current discharge, but the above curve shows what they do at high current discharge rates, up to 8C.
Note the following features:
  • At 80 mA (about 8C) you still get 78% of the rated capacity, terminating at 3 volts
I think the tiny-plane guys might well be interested.
Glen
jj604 is online now Find More Posts by jj604
Old Jan 01, 2010, 09:24 AM
earlwb is offline
Find More Posts by earlwb
earlwb's Avatar
USA, TX, Grapevine
Joined Dec 2008
The 10mah cell has some potential for sure. It looks like they left the foil outer support casing off to get the reduced weight of 0.33 grams.
Plantraco sells the 10mah cells with the foil backing support at 0.56 grams. A 20c discharge rating too.
http://www.microflight.com/Online-Catalog/Bare-Cells
But when you go ultra light or ultra small then every gram or fraction of a gram becomes significant.
earlwb is offline Find More Posts by earlwb
Old Jan 01, 2010, 10:37 AM
murph111 is offline
Find More Posts by murph111
Boston,MA
Joined Oct 2007
With any luck size will become the elec. RCers only problem, not the weight. 20 min. flight times wouldn't be to hard to swallow
murph111 is offline Find More Posts by murph111
Old Jan 01, 2010, 04:04 PM
jj604 is online now
ancora imparo
jj604's Avatar
Joined Jul 2005
In Engineering terms that's a 41% reduction in weight for no change in performance.
Pretty spectacular if it had happened to a "normal" flight battery!
Old Jan 06, 2010, 06:25 AM
Joined Nov 2009
Originally Posted by jj604 View Post
0.2C ???
Thats what I was thinking, or possibly higher performance in micro heli's, allbeit with much shorter flights. But that claim I thought deserved scrutiny, and that whole site was educational for me.
But you know what I liked most, and am going to buy a couple of, is the lipo 9v "transistor" batteries they have. They say that they have 10 times the life, and last a long time. Good for the smoke detector.
Id sure like to build a super micro planataco 4 channel heli, something smaller than a picco-z, I love what they have, they are a little pricey, is all, but now that I have the idea, I'll have to consider that concept.
Old Jan 06, 2010, 03:27 PM
jj604 is online now
ancora imparo
jj604's Avatar
Joined Jul 2005
Interesting find. At smoke detector currents these guys will probably outlive me!
Note however the licence with specs. On the Transistor battery page it's "9V nominal" on the Lithium Thional page the same product is "10.8V nominal". They are actually 3x 3.6 Lithium cells as you would expect. From the discharge curves they seem to be a bit above 9V at low currents.Still 1.2Ah capacity from one of these at 9V is pretty impressive when you think our original SubC NiCds were only that capacity at 1.2V and twice the size and weight.
Old Jan 06, 2010, 05:27 PM
earlwb is offline
earlwb's Avatar
USA, TX, Grapevine
Joined Dec 2008
I have been most impressed with the Plantraco planes I have, they can usually go 10 to 15 minutes off a 20mah single cell.
throttle and rudder, nothing fancy. But I have had them flying in a slow circle hands off for quite a few laps too. This is the little F4U or the Zero and even the tiny 1/72 scale Spitfire flies amazingly well for being so tiny.
Old Jan 06, 2010, 11:59 PM
Himalaya is offline
Find More Posts by Himalaya
Himalaya's Avatar
Joined May 2009
from what I saw by far, the light cells (or say high energy density cells) are all low C rated ones.
Himalaya is offline Find More Posts by Himalaya
Question Whats the worlds largest DLG? b36roxs Hand Launch 3 Dec 24, 2009 12:02 AM
For Sale Parkzone DC 3.7V LiPo Charger, 2 Parkzone 110mAH LiPo Batteries and 4 AA Batteries schwimmair Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 4 Nov 21, 2009 09:28 AM
For Sale Parkzone DC 3.7V LiPo Charger, 2 110mAH LiPo Batteries and 8 AA Batteries schwimmair Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 1 Nov 15, 2009 10:02 PM
Cap 232 Light, The Worlds lightest Kyosho Cap henke Sport Planes 2 May 18, 2004 12:33 AM
Lightest batteries for 35A draw (no lipoly) Mikerjf Batteries and Chargers 20 Jan 22, 2004 12:11 PM
