Where did you learn to speak Thai??? I lived there for about 3 years!!! Hope you don't damage your cowl, but no biggy, now you got a pattern!!! |
I'm still waiting on my stuff from HK! It's my fault I couldn't justify $25 EMS shipping on that small an order. I may make a fiberglass mold of my cowl this week.
I went to the LHS today(30 miles). He doesn't stock builder supplies just spare parts and RTFs. The guy is not too friendly. Kind of makes you feel like you're bothering him. I was trying to get some info from him about suppliers for my website and talk about flying, etc... I finally thanked him and left. I would think he could be a little more friendly and informative!!! Maybe he don't like clowns!!! |
@ryramz. If you make a plug, you are about 50% there. When you add in all the costs of shipping and materials, you are better off building a little vacuformer. It's ridiculously easy. any shop vac, upright or even canister vac will work. You can heat the plastic up in your oven. Look up Dr Crash - his user name here is drcrash and here's his web site/blog - http://www.vacuumformerplans.blogspot.com/ His design is far and away the simplest and it works really well.
The plug went ok. I added a thin layer of water putty to fill in all the holes and it's drying now. A good sanding and I'll be ready to give it a pull. I may need to get .04 styrene though (all I have is .03, a bit thin) though the AT-6 cowling was made with .02. I think it will come out ok but not insanely great. If you don't want to get into vacuforming, you could make a fiberglass mold of your cowling. grease up the plug and then lay down 3 or 4 layers of 1.5 oz cloth. Finish it and then pull it off. I use waterbased polyurethane and it works ok. glassing is pretty easy. Another approach that works is called lost foam - you make the cowling from foam (styro is good), glass it with a bunch of layers, completely finish it (paint an all) and then use a chemical to eat the foam away. MEK or acetone works really well. @radial - you weren't slapping down $129 for a parkzone so he wanted no part of you. short sighted money grubber. |
I guess you're right, phil! All I picked up was some solder on 2-56 x 1/16" wire couplers so i can use a better grade of clevis on the Texan, and a few props. I upgraded the wing bolt to a 10-32 nylon and added a 3/32" piece of plywood with a 10-32 blind nut. I saw in that thread where the wing bolt was pulling out the nut and a chunk of foam on their planes. I guess when mine goes it will either break the bolt or pull out a bigger chunk of foam. I picked up an airbrush today too. The silver paint didn't look too good brushed on. I've got a website. It's not much now, but I'm going to get it rolling this year. Check my profile for the link.
Robert. |
You'll love the airbrush. It makes a world of difference. I have almost zero airbrush skills and my stuff looks pretty good (to me anyway...).
My philosophy on wings is let 'em break free. Better to sacrifice a rubber band. Of course, you need to make sure the wing is going stay on in the air. damhikt |
I'm interested in seeing your guy's work.
It's funny, I've got a badger 350 (list $140, street 70-80), a harbor freight paasche clone ($15 on sale) and a single action HF "quick change" airbrush ($8 or ). I wind up using the cheapo single action HF brush the most because it's really easy to clean and does most jobs just fine. Funny*2 - I like the HF paasche clone better than the badger. go figure. |
Got my motor, ESC, and servos from HK, and my LiPos from ebay today. I had little trouble soldering on the bullet connectors. Two of the females had small holes all the way through. I just stuck a toothpick in and clipped the end off a little, and then the solder would stay in the cup. Decided to make a plywood motor mount. I just glued it to the stick so it will breakaway and not bend the motor shaft, if I'm lucky. I've still got to touchup the paint and paint the insignia. Then I'll start putting in the hardware. I also cut out the CA hinges on the rudder and elevator and put in real Dubro ones. The tail wheel needed some work too. It wasn't on the pivot point and was binding, so I cut some of the glue and set it correctly. I bent the piece of wire so the wheel tracks down the centerline of the plane. It's starting to take shape!!!
Check out the mock up!!! ![]()
| Thread Tools | |
| Wanted Robart retracts #618 for Top Flite AT-6 Texan | DieHard007 | Aircraft - General - Miscellaneous (FS/W) | 3 | Feb 24, 2010 07:06 PM |
| Sold LOWER PRICE Top Flite AT-6 Texan kit NIB with Robart retracts $180 Shipped USPS | be69ar | Aircraft - Fuel - Airplanes (FS/W) | 3 | Dec 28, 2009 02:17 PM |
| For Sale E-Flite AT-6 Texan with Retracts | TEC | Aircraft - Electric - Airplanes (FS/W) | 5 | Dec 15, 2009 03:09 PM |
| For Sale Lanier Texan AT-6 ARF | edkaye | Aircraft - Fuel - Airplanes (FS/W) | 3 | Dec 07, 2009 04:21 PM |
| Discussion Building a texan AT-6 help | fasstrc925 | Electric Plane Talk | 5 | Nov 30, 2009 07:00 PM |
