Old Dec 31, 2009, 08:01 AM
MelihK is offline
Find More Posts by MelihK
MelihK's Avatar
United Kingdom, England, Canterbury
Joined May 2008
New Product
Flight with Joystick!!! CompuFly USBtoPPM Converter Now avail on STOCK!
Hi Everyone,
This is last project of this year
I designed USB to PPM generator, this device generating PPM signals like TrainerBox for your Transmitter.
This mean, you can fly with your PC joystick or your own software based autopilot(if you can develope your software)
Features;
  • DirectX Based Joystick interface
  • 9 channel PPM generator with compatible all RC Transmitters
  • Cunfigurable PC based driver software for all joysticks or keyboard features.
  • Point of View stick suport for looking around without headtracker(like simulation games)
  • External plugin support for PC based autopilot applications
  • Compatible with all Windows versions
This is my test joystick
This is USB PPM generator device's inside
This is genrated 9 channel positive PPM signal(it can generate negative also)
And this is finished product's outside. It is similar size with USB stick and including 1.5 meter cable for your transmitter. I will sell it with compatible plugs for Futaba,Hitec, Jr, Multiplex, Sanwa, Airtronics, ESky.
I just finished that and i'm going to new year party,
Happy ney year!!!
Melih
MelihK is offline Find More Posts by MelihK
Site Sponsor
Old Dec 31, 2009, 08:05 AM
wedge98 is offline
Find More Posts by wedge98
wedge98's Avatar
East Hartford, CT
Joined Sep 2006
AWESOME!!!!!! I have a Saitek Cyborg evo and Logitech extreme 3D PRO. Will this software work for both of those joysticks?
wedge98 is offline Find More Posts by wedge98
Old Dec 31, 2009, 08:12 AM
chancesAU is offline
Find More Posts by chancesAU
chancesAU's Avatar
Australia
Joined Apr 2008
When is it on sale?
I want now!
chancesAU is offline Find More Posts by chancesAU
Old Dec 31, 2009, 08:17 AM
Bonafidepirate is offline
Find More Posts by Bonafidepirate
define("BEASTMODE", "1");
Bonafidepirate's Avatar
United States, LA, Moreauville
Joined Jan 2002
*Raises hand* I'll take one! How much?
Bonafidepirate is offline Find More Posts by Bonafidepirate
Old Dec 31, 2009, 08:30 AM
KristianS is offline
Find More Posts by KristianS
FPV addict
Giske, Norway
Joined Aug 2009
Will this be compatibel with a xbox360 controller?
KristianS is offline Find More Posts by KristianS
Old Dec 31, 2009, 08:45 AM
bignose13 is offline
Find More Posts by bignose13
Yeah Baby
bignose13's Avatar
Joined Apr 2006
Melihk
What your saying if I am correct is that I can use my Logitech force 3D Pro with your adapter to fly my plane outside instead of using the Transmitter
Sorry if this sound's a n0ob question
Simon
bignose13 is offline Find More Posts by bignose13
Old Dec 31, 2009, 08:57 AM
MelihK is offline
MelihK's Avatar
Joined May 2008
Hi Guys
I will answer your questions on same row.
USB-PPM generator compatible with all Joysticks because software using DirectX for connecting with your joystick. I bought a DirectX component for that, Just connect your joystick and configure it for channels. Rudder, x,y,z , point of view, button sand trottle, all options will work
Price will be under 100$ but i'm not sure how much. I'm waiting for Futaba Plugs from Japan.
@Simon, yes you will use your transmitters RF module only. Or you can connect RF Module on the directly this device and just give the power. It will work without your transmitter's body.
This is best option for making a ground station box without standart transmitter
Site Sponsor
Old Dec 31, 2009, 09:59 AM
renatoa is offline
Find More Posts by renatoa
Romania, Dolj, Craiova
Joined Sep 2007
What is the resolution, please? My current USB-PPM box has 8 bits and I find it a bit not enough...
renatoa is offline Find More Posts by renatoa
Old Dec 31, 2009, 10:11 AM
MelihK is offline
MelihK's Avatar
Joined May 2008
Maximum resolution is 16 bit 256 times higher than 8 bit but it is useless, i reduced it for 10 bit. It is default value of transmitters.
Have you any suggestion and info about your system? I'm planning to using it with external softwares like autopilot etc. I was designed computer based telemetry system, maybe someone use this 2 system for making pc based autopilot.
Site Sponsor
Old Dec 31, 2009, 10:16 AM
renatoa is offline
Joined Sep 2007
Not considered this aspect until now, my first goal was to fly as close to cockpit experience. Is me who must have fun, not the AP
Unfortunatelly not all of us can allocate so much time as you for the hobby. And deliver news in this incredible tempo.
Old Dec 31, 2009, 10:22 AM
trappy is offline
Find More Posts by trappy
trappy's Avatar
Austria
Joined Feb 2007
Ok, so let me wrap my head around this ... I buy a Joystick and a futaba PPM tx module and I'm ready to go? Would this also work with, say, a PS3 joypad? What about mixing? (e.g. elevons, flaps, crow)
trappy is offline Find More Posts by trappy
Old Dec 31, 2009, 10:44 AM
renatoa is offline
Joined Sep 2007
The mixing is done by the software between the joystick and the USB-PPM box.
In fact, mine, whose picture was posted in the other thread, emulates all the logic / programming of an Eclipse 7. Including trims, subtrims, models save/ load (unlimited), mixers (unlimited), everything, and of course, much more, any curve on any input / channel you want, sky is the limit, lol...
Old Dec 31, 2009, 11:04 AM
tty044 is offline
Find More Posts by tty044
tty044's Avatar
Joined Aug 2008
Please consider the price under 50 USD if you want to be competitive to some vendors.
tty044 is offline Find More Posts by tty044
Old Dec 31, 2009, 11:14 AM
renatoa is offline
Joined Sep 2007
Well, in this case, if you gave that hint, let the curtain drop
There is such box for long time, there are already projects posted here, it is called PCTx, and is what I am using in my project.
Its cost is posted by tty044 above, but... without absolutely no software ! You must write your own application to use it !
There is an app sold separately for $99, ServoCommander which is intended to map channels to the control widgets, whatever they are, not only joysticks, includes support for HT too, basic mixing, etc. So the combo price is $150 actually.
The problem is that this box doesn't issue the best quality PPM, and here Melihk I hope can make a difference.
Old Dec 31, 2009, 12:51 PM
trappy is offline
trappy's Avatar
Austria
Joined Feb 2007
... and the box requires a transmitter AND a PC to work.
Joystick => PC => PCTx => Tx
From what I understand:
Joystick => MelihK magic => Tx module
that would be awesome!
Discussion Pilot with a joystick from a computer jesus_taax DIY Electronics 4 Jan 05, 2010 10:30 PM
Discussion flight sim for mac computer dhighkeer Beginner Training Area (Heli-Electric) 4 Dec 29, 2009 04:39 AM
Discussion Pilot with a joystick from a computer jesus_taax FPV Talk 16 Apr 02, 2007 12:10 AM
Computer Joystick link to Futaba TX iiifly Radios 3 Sep 29, 2006 03:52 PM
Discussion Joystick, computer, tx, interface... TopCrest UAV - Unmanned Aerial Vehicles 3 Dec 27, 2005 11:09 PM
