Old Dec 29, 2009, 11:46 PM
FlyAce is offline
Find More Posts by FlyAce
Joined Mar 2009
Help!
PZ BF-109 Flaps DX7 Setup
Can anyone help me setup flaps on the PZ BF-109 with a DX7? It comes with an AR500 with gear and aileron open. I can use the gear channel but that only gives me two positions. Is it possible to use the flap(system) three position switch with that receiver? If so, how?
Thanks.
FlyAce is offline Find More Posts by FlyAce
Old Dec 30, 2009, 01:32 AM
Xpress.. is offline
Find More Posts by Xpress..
Team Hitec, Customer Support
Xpress..'s Avatar
United States, CA, Poway
Joined Oct 2007
Thanks.
The AR500 is only a 5 channel receiver, which means the GEAR channel is setup to run on the GEAR channel in the radio. You need to slave the GEAR channel in the radio to your 3 position switch
Xpress.. is offline Find More Posts by Xpress..
Old Dec 30, 2009, 07:55 AM
powerlines is offline
Find More Posts by powerlines
I am ready for HHAEFI!!
powerlines's Avatar
United States, GA, Cochran
Joined Apr 2004
I would start by INH the gear.. Then setting a program for flaps to gear you can adjust the up and down by the travel adjust..
did you cut flaps in it.. or using flaperons..
powerlines is offline Find More Posts by powerlines
Old Dec 30, 2009, 10:23 AM
FlyAce is offline
Joined Mar 2009
It comes ready for flaps. Just need to add servos and make a cut between the aileron and the flap. Can you be more specific about programming?
Thanks.
Old Dec 30, 2009, 04:35 PM
FlyAce is offline
Joined Mar 2009
I got the programming all figured out.
Thanks!
Mix 4:
gear--gear
rate -100%
-100%
sw: on
offset 0
(this will shut off the gear switch
Mix 5
flap -- gear
rate-- + 100%
+ 100%
sw - on
offset 0
Old Jan 05, 2010, 08:12 AM
tubamike78 is offline
Find More Posts by tubamike78
tubamike78's Avatar
United States, OH, Monroeville
Joined Dec 2007
you may also want to programe some down elevator into that also, don't know how much until you try it, but you could do that on the next mix. flap--elevator.
tubamike78 is offline Find More Posts by tubamike78
Discussion Start Micro PZ size Spanish Civil War Bf-109 mtflyr Scratchbuilt Indoor and Micro Models 27 Jan 23, 2010 08:45 PM
Yippee! 1/72 Scale BF 109 Pic's + VIDEO !!!!!! epicdoom Scratchbuilt Indoor and Micro Models 44 Dec 28, 2009 06:02 AM
Sold Parkzone BF-109 Receiver Ready $175.00 shipped FieldofDreamsFlyer Aircraft - Electric - Airplanes (FS/W) 1 Dec 05, 2009 01:37 PM
Wanted kyosho bf-109 retracts drh024 Aircraft - General - Miscellaneous (FS/W) 0 Dec 05, 2009 01:02 AM
Sold Parkzone BF-109 RTF with Futaba System $400.00 shipped FieldofDreamsFlyer Aircraft - Electric - Airplanes (FS/W) 2 Dec 03, 2009 10:29 AM
