Old Dec 29, 2009, 03:58 PM
Zirt57 is offline
Find More Posts by Zirt57
Zirt57's Avatar
Canada, ON, Cambridge
Joined Jan 2007
Xaircraft X600D Quad
As promised, here is the new thread on the Xaircraft X600D. http://www.cnchelicopter.com/servlet...ircraft/Detail or here: http://www.firstpersonview.co.uk/air...e7fc5dc21d7ab7 I was going to take it apart and do a build thread, however Simon at FirstPersonView has done such a good job of translating the manual and he also did some build videos of the X600D v.1.
I've attached three photos of the finished X600D. I will also post a Vimeo video of my testing when it finally uploads to Vimeo and converts it.
Zirt57 is offline Find More Posts by Zirt57
Old Dec 29, 2009, 04:06 PM
Zirt57 is offline
Zirt57's Avatar
Joined Jan 2007
OK, here is the video. Note how the props don't spin at the same speed.
Xaircraft X600D (4 min 7 sec)
- Jeff
Old Dec 29, 2009, 05:56 PM
G-unit is offline
Find More Posts by G-unit
WHEN IN DOUBT FLOOR IT!!!
G-unit's Avatar
AZ
Joined May 2006
Come on Jeff,were is the video
G-unit is offline Find More Posts by G-unit
Old Dec 29, 2009, 09:28 PM
karenycl is offline
Find More Posts by karenycl
karen
Joined Dec 2009
the pic is easy to understand
karenycl is offline Find More Posts by karenycl
Old Dec 29, 2009, 09:44 PM
Zirt57 is offline
Zirt57's Avatar
Joined Jan 2007
Originally Posted by karenycl View Post
Yes, the manual has lots of easy to understand pictures like the one you posted. Assembly is shown in step by step photos with English descriptions.
- Jeff
Old Dec 30, 2009, 06:12 AM
JUERGEN_ is offline
Find More Posts by JUERGEN_
xxxxxxxxxxxxx
JUERGEN_'s Avatar
Deutschland
Joined Nov 2009
- Jeff
where is a download for the English descriptions (DOC)?
jürgen
JUERGEN_ is offline Find More Posts by JUERGEN_
Old Dec 30, 2009, 09:56 AM
Zirt57 is offline
Zirt57's Avatar
Joined Jan 2007
jürgen
I can't upload it as it is too big. However here is the link to download it:
http://www.cnchelicopter.com/x600/x600d.rar
- Jeff
Old Dec 30, 2009, 01:13 PM
G-unit is offline
G-unit's Avatar
AZ
Joined May 2006
http://www.vimeo.com/8449169
- Jeff
Hey Jeff,
First u need to set all trims and sub trims to zero,
Then turn on the quad get the props spinning at a low speed,then apply the throttle slowly and see what side of the quad comes off the ground first,if it don't come off the ground evenly then u need to adjust the pots on the board,I don't know what pot does what on that board so u will need to figure that out,just move one just a little and see what the quad does,then do the other two and see what they do,use the pots to get the quad to come off the ground nice and smooth then u can use your Tx for the final adjustments.
Good luck.
Old Dec 30, 2009, 06:59 PM
Zirt57 is offline
Zirt57's Avatar
Joined Jan 2007
Originally Posted by G-unit View Post
Hey Jeff,
Good luck.
Thanks G. I'm just making a test stand for it. I'll feel safer with it on the stand. Then I can test to my hearts content.
- Jeff
Old Dec 30, 2009, 08:40 PM
SoMoney is offline
Find More Posts by SoMoney
SoMoney's Avatar
San Diego
Joined Nov 2002
Gotta tie that quad down! It looks like it has power to spare!
I see 3 pots on the control board for fine tuning, if there is any rime or reason to how they effect power to the 4 motors, be sure to let us know!
SoMoney is offline Find More Posts by SoMoney
Last edited by SoMoney; Dec 30, 2009 at 09:33 PM. Reason: attached picture of D600 control board.
Old Dec 30, 2009, 09:42 PM
G-unit is offline
G-unit's Avatar
AZ
Joined May 2006
They control the Pitch,Roll and Yaw
Old Dec 31, 2009, 07:49 PM
Zirt57 is offline
Zirt57's Avatar
Joined Jan 2007
I finally made my test stand. This allows me to check all my settings etc without worrying about crashing. In fact I found out that I had the channels plugged in wrong. I'll check them and post what I have setup. Anyway, here are some pictures of my stand and a video will be coming.
- Jeff
Old Dec 31, 2009, 07:53 PM
Zirt57 is offline
Zirt57's Avatar
Joined Jan 2007
OK, here is the video that I promised. Enjoy.
- Jeff
X600D Test Stand (0 min 35 sec)
Old Dec 31, 2009, 08:42 PM
mkmkmk13 is offline
Find More Posts by mkmkmk13
mkmkmk13's Avatar
United States, CA, Orange
Joined May 2007
subscribed!
mkmkmk13 is offline Find More Posts by mkmkmk13
Old Dec 31, 2009, 10:02 PM
Trackercal is offline
Find More Posts by Trackercal
Trackercal's Avatar
United States, OR, Bandon
Joined Apr 2007
- Jeff
Great set up Jeff. How did you make the swivel ball links?
Trackercal is offline Find More Posts by Trackercal
Discussion Quad brushless motors and quad ESC wiring whatala Power Systems 11 Dec 28, 2015 03:51 PM
New Product Xaircraft X500-D $300 ARF brushless quad from China SebastianJ Multirotor Talk 1097 May 31, 2010 10:06 AM
Discussion Programming quad flaps using Futaba 7C Matt Gunn Flying Wings 1 Aug 26, 2009 08:33 AM
New Product xaircraft mahui625 Your Plane Photos 0 May 05, 2009 02:33 AM
quad cdr quad esc how many poly cells? captinnitro Power Systems 2 Apr 04, 2005 08:37 PM
