Old Dec 28, 2009, 07:47 PM
rhong is offline
Find More Posts by rhong
Joined Sep 2009
Settings for a DX6i for a Skyartec Wasp 3
Anyone using a Skyartec Wasp 3 with a DX6i & AR6000? What are your setting?
Check this Skyartec Wasp 3 with a DX6i:
Wasp V3 with Spektrum DX6i first test (0 min 50 sec)
Ron
rhong is offline Find More Posts by rhong
Old Jun 06, 2010, 03:39 PM
morgusmax is offline
Find More Posts by morgusmax
United States, NY, Putnam
Joined Jul 2007
i'm interested in this as well - i can't get the motor to come on! is there a particular order to plug the motor wires into the esc? the motor wires are red, blue, yellow, but the esc has no such designation!
morgusmax is offline Find More Posts by morgusmax
Old Jun 15, 2010, 10:24 PM
Parkflying is offline
Find More Posts by Parkflying
United States, MI, Auburn Hills
Joined Dec 2008
You have to reset the ESC for the Throttle end points. Also the motor wires do have a correct order to plug into the ESC
Try these:
Blue to A on ESC
Red to C on ESC
Yellow to B on ESC
To reset the ESC for the Throttle of your new receiver:
Connect your channel 3 of the receiver to the plug on the ESC
With the throttle at lowest setting plug in the battery to the ESC
The ESC should beep and then play a short tune; if the ESC beeps
contentiously for longer then 30 seconds follow the instructions below.
Sometimes when connecting a new ESC to a receiver,
we must reset the ESC so it knows the top end and bottom end
of the throttle control.
These steps are easy.
Leave the throttle trim tab at bottom like you normally use it.
Throttle range setting:
1. Switch on transmitter, move throttle stick to top
2. Connect battery pack to ESC, and wait for about 2 seconds
"Beep-Beep-" tone should be emitted, means throttle range highest point has been correctly confirmed
3. Move throttle stick to the bottom, several "beep-" tones should be emitted, presenting the number of battery cells
A long "Beep-" tone should be emitted, means throttle range lowest point has been correctly confirmed
4. You should be ready to test fly.
Hope this helps
Max
Parkflying is offline Find More Posts by Parkflying
Site Sponsor
Old Jun 21, 2010, 07:59 PM
r00x is offline
Find More Posts by r00x
Joined Jan 2010
Just a few extra things to consider:
- make sure your throttle curve is set to 100% at full stick before doing the above
- similarly, make sure your curve is set to 0% at bottom stick. Also since you're on a DX6i now, beware that if in the future you initialise the heli with throttle hold on, it will spool up when you flick it off if you haven't set your curves to match.
- The ESCs used by the Wasp seem to follow a similar configuration strategy to typical turnigy/other ESCs. After playing a funky tune, the ESCs will rattle out a series of beep codes spaced evenly apart, each sequence of beeps referring to the current setting of that particular configuration (i.e. soft start if it exists, motor timing, etc). While you don't have to care about this, if you ever want to change that configuration, you can access it by raising the throttle as above, waiting for the sequence you're interested in, then dropping the throttle... well, you get the idea. pop online for a list decoding all those beeps.
I use a DX6i with my Wasp v3 and an AR6110e. One of the first changes I made! Do keep a very close eye on the binding that happens with the head though, as the servos center differently and have a much bigger range on a Spektrum radio, compared to Skyartec's. You'll need to remove all the servo arms and reseat them, most likely.
On my radio:
DR:
AILE 0 75% 1 100%
ELEV 0 75% 1 100%
RUDD 0 48% 1 100%
Travel ADJ:
Everything 100% after servo horns adjusted
Gyro:
0: 34.5%
1: 62.0%
Throttle Curve for 7.4v (don't do 3D myself):
L: 0%
2: 70%
3: 75%
4: 85%
H 100%
Pitch curve:
L: 66.5%
2: 78.0%
3: 90.5%
4: 97.0%
5: 100%
Swash mix (this is where I've accomodated for the extra servo travel, allowing for big cyclic but smaller pitch adjustments):
AILE: -106%
ELEV: -84%
PITCH: -73%
Reverse:
THRO: N
ELEV: R
GYRO: N
AILE: N
RUDD: N
PITCH: R
Swash type: CCPM 120 deg
And that's what I use
r00x is offline Find More Posts by r00x
Old Dec 18, 2011, 06:59 AM
dav84 is offline
Find More Posts by dav84
Joined Dec 2011
Hi
It's been a while since you posted so this is a bit of a long shot, but did you leave the gain pot on the gyro in the twelve o'clock position?
Dave
dav84 is offline Find More Posts by dav84
Old Dec 20, 2011, 12:21 AM
Joined Dec 2008
Originally Posted by dav84 View Post
Hi
Dave
I would suggest starting with the Gyro's default settings; once you get the swashplate and linkages setup and do a initial hover, you may need to increase or decrease the Gyro sensitivity.
Max
www.parkrcmodels.com
Site Sponsor
Old Dec 27, 2011, 03:14 AM
dav84 is offline
Joined Dec 2011
Thanks Max
I have done that, i was just wondering whether it is best to leave the gain pot at its mid point and do all the adjustment via the DX6i or do all the adjustment on the gyro itself.
Dave
Old Dec 27, 2011, 08:11 AM
Joined Dec 2008
Thanks Max
Dave
change the gyro settings either place; totally up to you. Either way a little change goes a long way.
Max
Site Sponsor
Old Dec 27, 2011, 03:07 PM
dav84 is offline
Joined Dec 2011
Thanks for the help, i think i will leave the gyro and change the settings on the tx.
Dave
Discussion New Skyartec Wasp 3 no longer binds with the transmitter rhong Skyartec 9 Jan 24, 2010 12:58 PM
Discussion Skyartec Wasp V4 Belt 250 3D 6 channel RC helicopter Beemer444 Micro Helis 9 Dec 25, 2009 02:14 AM
Sold Skyartec Wasp V3 CP RTF CHEAP and Good to Fly! mygsx Aircraft - Electric - Helis (FS/W) 8 Nov 19, 2009 03:44 AM
For Sale SkyArtec Wasp V4 200 Helicopter - NIB - RTF! ptt81 Aircraft - Electric - Helis (FS/W) 0 Oct 23, 2009 03:51 PM
Discussion New Skyartec Wasp 3 does not bind rhong Beginner Training Area (Heli-Electric) 1 Oct 01, 2009 01:01 PM
