Old Jan 06, 2010, 11:02 AM
Chinewalker's Avatar
1000 Islands, NY
Joined Dec 2009
Center of Gravity?
My next step is to seal the innards with epoxy, and after that it's decking time. BUT, before I put the decks on I wanted to get an idea of where to put the center of gravity? It'd be a lot easier to embed a heavy washer or three in the epoxy before I put the decks on. From what I can gather, it should be at, or just behind the sponsons. Am I correct in that assessment?
Thanks!
Chinewalker is offline Find More Posts by Chinewalker
Old Jan 06, 2010, 02:53 PM
GILL
GILL RC's Avatar
United States, NJ, Hopatcong
Joined Aug 2005
Looking good. The CG on my hydro's are all right at the back of the sponsons.
GILL RC is offline Find More Posts by GILL RC
Old Jan 06, 2010, 04:21 PM
1000 Islands, NY
Joined Dec 2009
Thanks John. You confirmed what I already thought...
- Scott
Old Jan 06, 2010, 06:09 PM
mxz70017's Avatar
Joined May 2006
chinewalker
Hey no Problem On the painter's tape tip!!!Its not my Idea...I learned It from the vacu-tug Site!!!Also several other kits Ive built suggested useing that tape to hold thing's.An found It work's very well!!!An now use alot of It.
One thing I did find out however ok..Dont use the manilla colored or the tan masking tape...It leaves a lousy annoying amount of adhesive. In the wood grain.Really a pain to clean up.Also found It tares an doesn't hold near as well as the blue!!!!
mxz70017 is offline Find More Posts by mxz70017
Old Jan 06, 2010, 08:09 PM
"day ain't over yet-"
der kapitan's Avatar
Western N.Y. winemaking country
Joined Jun 2005
Chinewalker, gotta say that was a quick build.
Tidy too---.
der kapitan is offline Find More Posts by der kapitan
Old Jan 07, 2010, 08:28 AM
1000 Islands, NY
Joined Dec 2009
1/5 Scale Mock-up
I didn't get into the shop last night, but I did print off my 1:8 scale plans at 160% to give me 1:5 scale plans. I laid the GTX 650 on the profile view and it looks pretty good. The boat will measure in at a hair under 24-inches at this scale. Does that sound about right for this motor? I can scale it to pretty much anything, but I figure it'll be somewhere in the 1:4 (28-1/2") to 1:5 (23.8") range
Old Jan 07, 2010, 02:32 PM
mxz70017's Avatar
Joined May 2006
Hey chinewalker
My Miss Elam Brushless I converted from a Nitro Is 27".With a SV 27 Set Up In It.My Miss Bud Conversion Im doing Is the Old style Hull that had the solid straight shaft.It too Is also 27 Inchs.So Im thinking you would be right On with the 1/4 SCALE AT 28"!!!
Old Jan 07, 2010, 02:50 PM
GILL
GILL RC's Avatar
Joined Aug 2005
You know what you have to do with that motor. Strip it down, make a cover that looks like a cyl-block add a couple of tuned pipes. Lets face it we would take a 10 hp Johnson strip it to lighten it re-work the cyl. & pistons bigger carbs and tuned pipes = almost 50hp with lots of speed.
Old Jan 07, 2010, 04:13 PM
1000 Islands, NY
Joined Dec 2009
Yeah, I'd actually thought of that - making a dummy cover to make it look a little more scale. It'd be fairly easy to make it look like a Yamato 102 with the orange beak...
Old Jan 07, 2010, 04:15 PM
1000 Islands, NY
Joined Dec 2009
1:4 scale it is! Thank you!!
Old Jan 08, 2010, 02:26 PM
GILL
GILL RC's Avatar
Joined Aug 2005
Personaly I think it would look great. One of these days I'll have to dig out a little kneedown pickle fork I built a about 24 years ago. I had a foot from a Allen Sea Fury, drilled it out and ran a shaft with a coupling to it. I had a 540 motor with a 1.5:1 over drive and a 1 inch re-pitched prop. On 10 cells it ran very well, but with a brushless I could get rid of the gears and run Lipos. That would save alot of weight. I had a Ken doll in a bathing suite with his chest cut out over the motor and gear box. The top end of the out board looked like one of the engines we ran, including the megafones.
Old Jan 08, 2010, 02:52 PM
1000 Islands, NY
Joined Dec 2009
John - that would be VERY cool to see! I'd actually thought about converting a Sea Fury to electric as I have a spare lower unit housing. It would look pretty good on my 1:8 scale hydro...
Old Jan 11, 2010, 03:52 AM
1000 Islands, NY
Joined Dec 2009
Decking
I was able to work a bit more on the boat this weekend. Got the inside sealed with West System and installed the foredeck. I used the blue tape idea to help hold the side decking down. Worked great!
Old Jan 11, 2010, 07:25 AM
1000 Islands, NY
Joined Dec 2009
Structure DONE!
The hull is now completely skinned and faired in! I'm calling this stage done! Now to come up with a good looking paint/varnish job. The mahogany bits will be natural, but I will probably paint most of the birch ply areas.... Maybe not.
Next step is to make up some hardware. I remember seeing some dollhouse handles that look pretty close to the grab handles on the transom. The steering wheel and throttle I'll have to fabricate.
Old Jan 11, 2010, 09:06 AM
Joined Jun 2005
John, way back, about 50 years ago, I did it with a 12 HP Champion, running on an alcohol/castor oil mix---.
For Sale K&B 11cc Outboard Engines getnoff Boats (FS/W) 2 Dec 16, 2009 01:05 PM
Discussion rc nitro 7.5 k&b outboard 1428 Racing Boats - Internal Combustion 12 Oct 27, 2009 10:51 PM
Sold K&B outboard parts. warrgy69 Boats (FS/W) 0 Oct 08, 2009 05:38 PM
Sold Outboard Marine Engine K&B 3.5 clif Boats (FS/W) 0 Sep 29, 2009 09:25 PM
Discussion K&B 7.5cc outboard tmattusa Racing Boats - Internal Combustion 8 Sep 05, 2009 11:17 PM
