Old Oct 11, 2012, 12:41 PM
chevronflyer is offline
Find More Posts by chevronflyer
"Takeoffs are optional"
chevronflyer's Avatar
United States, FL, Middleburg
Joined Feb 2007
yup, positive
chevronflyer is offline Find More Posts by chevronflyer
Old Oct 18, 2012, 06:20 PM
dawhale is offline
Find More Posts by dawhale
USA, CA, Valencia
Joined Mar 2011
All righty then. Have my Revolver close to being ready to fly. Couple of questions. I installed a Rimfire 1.20. I ran a test today. 6S 5000, CC 100 amp ESC and a 16 X 8 prop. Showed 100 amps and 2219 watts. I see on this forum a 17 X 8 does the same thing. Kind of a newbie to this stuff. What can I do to bring the amps down to about 80?
dawhale is offline Find More Posts by dawhale
Old Oct 18, 2012, 07:02 PM
Fidelity101 is offline
Find More Posts by Fidelity101
Go fast, pull up.
Fidelity101's Avatar
United States, NY, Clarence Center
Joined Nov 2008
I am surprised that a 17x8 puts out the same amps as your 16x8. Unless he is running a lower timing, but even then, it seems odd. If you want to drop amps, you need to drop load. That means lower pitch or lower size. Pitch means more bite per revolution, which means more speed. Length generally gives me thrust.
If you want speed, go with a 14x8 or 15x8
If you want more thrust, usually for unlimited vertical, go 15x6 or 16x6
As for watts, 100-125 watts per pound should be a great starting point, unless you want a rocket plane or 3d flying plane.
Do a web search for "dc_calc" it's dc prop calc, which is a great program for helping you determine what power you will get with different configurations.
http://www.electrifly.com/motors/gpmg4505.html
According to the manufacturer, you should be at a 16x6 apc-e prop. Using a prop meant for nitro increases amp draw with minimal performance gain or loss. If you are really getting 100A on a 16x8, you might have an issue with timing being wrong on the esc or the motor is rubbing against something.
Fidelity101 is offline Find More Posts by Fidelity101
Old Oct 19, 2012, 02:08 PM
Bill Quantock is offline
Find More Posts by Bill Quantock
Wingnutz
Bill Quantock's Avatar
Canada, ON, Markham
Joined May 2009
Sweet maiden!
Finally maidened my Revolver 70 this morning after a nearly three year wait. (2009 Christmas present from my wife) Crosswind at about 15-20 km/h. (approx 10-13 mph) and she flew really well. Four clicks of down and we were hands-off except for gusts...handled these really well too.
Rimfire 80, ICE 100 (is this too much?) and 4500 mah 6s with 15x7 prop.
Worth the wait!
Bill
Bill Quantock is offline Find More Posts by Bill Quantock
Old Dec 12, 2012, 10:54 PM
DeadstickDuck is offline
Find More Posts by DeadstickDuck
Electric
United States, OR, Hillsboro
Joined Oct 2009
I have mine dialed in at 160oz running the Rimfire 1.20 and APC 14x10 on 7s5000 45C lipos. Clocked at 115mph level circuits and no wind.
82.5Amps at 26.7Volts 11100RPM for 2200Watts @89.9%eff. Motor is only warm after flights.
DeadstickDuck is offline Find More Posts by DeadstickDuck
Old Feb 28, 2013, 06:22 PM
P Farley is online now
Find More Posts by P Farley
P Farley's Avatar
United States, WA, Spokane
Joined Aug 2006
Canopy
Has anyone switched to magnets or modified the hold downs for the canopy?
P Farley is online now Find More Posts by P Farley
Old Feb 28, 2013, 07:19 PM
GassPasser is offline
Find More Posts by GassPasser
Pro Bro # 2398
GassPasser's Avatar
BoonVegas, Indiana
Joined Dec 2005
Worth the wait!
Bill
great to hear that Bill. i just started putting my together after a year of trying to fing the time.. post some pics if you can.
GassPasser is offline Find More Posts by GassPasser
Old Mar 01, 2013, 11:36 AM
P Farley's Avatar
Joined Aug 2006
Ice 100
I dont think you can over ESC, it will just run nice and cool!
Old Mar 02, 2013, 12:14 AM
nioa is offline
Find More Posts by nioa
More Motors, More Fun... :-)
nioa's Avatar
Phoenix, AZ
I use 2-56 rod and blind nut as shown in pics below. Works GREAT!
Nick
nioa is offline Find More Posts by nioa
Old Mar 02, 2013, 11:22 AM
P Farley's Avatar
Joined Aug 2006
Good idea. I want a tool-less fast way to get the canopy off rather than installing an arming plug.
Old Mar 03, 2013, 05:11 AM
Electric
Joined Oct 2009
I have a dozen flights with 7s5000 lipo and 14x10apce full throttle and have yet to have the motor, or battery more than warm. But, I have been flying in 60F weather.
Old Mar 03, 2013, 10:53 AM
P Farley's Avatar
Joined Aug 2006
What motor/ESC are you using? Thanks.
Old Mar 03, 2013, 10:54 AM
P Farley's Avatar
Joined Aug 2006
Never mind just scrolled up and saw your previous post.
Old Mar 09, 2013, 12:17 PM
P Farley's Avatar
Joined Aug 2006
5 Cell?
I just picked up 2 big 5cell 6000Mah Max Amps lipos at a swap meet that are like new and balance perfectly...for $5 each! New they were over $300 for the pair. I fly the Rimfire 80 and knowing that I dont fly wide open with my 6 cell TP's very much, any opinions on how these might fly the plane? Anyone flown this with 5 cells?
Old Mar 09, 2013, 04:15 PM
rcjetpilot is offline
Find More Posts by rcjetpilot
Bot's like to know where you live
Joined Sep 2003
I dunno about 5 cells, that would put the amps required, at around 70-80amps. IN my opinion this planes flies with authority at 1k-watts, 1.2k is even better. 6-8 cells fits fine.
My 8-cell setup can be viwed here:
http://www.rcgroups.com/forums/showp...3&postcount=79
rcjetpilot is offline Find More Posts by rcjetpilot
Reply With Quote  (Disabled)
Article Great Planes Revolver GP/EP Sport Aerobatic ARF Review kevin Sport Planes 776 Jun 13, 2016 11:16 AM
For Sale (slightly used...) Great Planes Revolver and Freestyle Rush. cargomaster Aircraft - Fuel - Airplanes (FS/W) 19 Oct 02, 2010 04:16 PM
For Sale Great Planes Revolver .46-.70 NIB - $140. ptuxbury Aircraft - Fuel - Airplanes (FS/W) 1 Dec 09, 2009 06:15 PM
Sold NIB Great Planes 70" Revolver ARF RCForever Aircraft - Fuel - Airplanes (FS/W) 1 Dec 09, 2009 03:35 PM
Sold Great Planes Revolver Fidelity101 Aircraft - Electric - Airplanes (FS/W) 3 Sep 13, 2009 07:05 PM
