Espritmodel.com Heli Air
Old Apr 21, 2012, 08:59 PM
Branford, Florida
Joined Jun 2010
Originally Posted by ludwig borg View Post
Hey there,
I have a webra speed 61 engine with tune pipe and am wondering if it would be appropriate for the revolver 70...it seems like some guys are putting pretty big engines in her....thanks.
I would have to say probably a bit small. This is a fairly large airframe for a .60 IMO
ACKopter is offline Find More Posts by ACKopter
Old Apr 22, 2012, 08:41 AM
Joined Apr 2012
Yea, that's what I thought......maybe the escapade 61 would be better suited for it.......it's a little cheaper too...
ludwig borg is offline Find More Posts by ludwig borg
Old Apr 23, 2012, 09:12 AM
P Farley's Avatar
United States, WA, Spokane
Joined Aug 2006
Maiden...sortof
Took mine out yesterday for the first tme, perfect no wind day. I drove it around a bit at a fast"ish" pace to see how it was on the ground, tracks perfectly. Then ramped up the throttle a few times and reached just the point of lift off...and chickened out. Never actually flew. Here's my question. I have recommended throws set in both high and low rates...but (at least visually) the low rates seem to very low. Can anybody comment on how the plane handles at the low rates? How responsive is the plane...? Thank you.
P Farley is offline Find More Posts by P Farley
Old Apr 23, 2012, 12:10 PM
Sandy Springs, GA
Joined Jul 2008
The plane handles very well on low rates. I always use low rates for takeoff and landing. Loops and rolls on low rates are fine. You really don't need high rates for sport flying.
Bruce
landeck is online now Find More Posts by landeck
Old Apr 23, 2012, 12:15 PM
More Motors, More Fun... :-)
nioa's Avatar
Phoenix, AZ
Low rates will give you a nice, easy to control, aircraft. High rates are very responsive. The stated throws in the manual are very good. BTW, I use high rates for most of my flying including the landing.
It's a wonderful plane, and a great flyer. You need to fly it to the ground, and be attentive to your speed, to keep it from bouncing, as it has a very slick airframe. Pay attention, and it will slow down nicely.
nioa is offline Find More Posts by nioa
Old Apr 23, 2012, 05:36 PM
United States, PA, Tunkhannock
Joined Dec 2011
any idea if 2000 watts will fly this bird?
garrettt04s is offline Find More Posts by garrettt04s
Old Apr 23, 2012, 09:07 PM
Bot's like to know where you live
Joined Sep 2003
Low rates worked fine... a bit soft but well within control. I also use the high rates for all my flights. I've settled on 8s 17*12 scropion 4035-250 / 9.5 lbs.... IMHO a perfect sport setup.
rcjetpilot is offline Find More Posts by rcjetpilot
Reply With Quote  (Disabled)
Old Apr 23, 2012, 09:08 PM
Joined Sep 2003
AUW is 9.5 - 10.5 pounds...
2000 watts would be more then enough, and then some
Old Apr 24, 2012, 07:33 AM
Joined Dec 2011
perfect thanks. Motor just looks small on such a large plane.
Old Apr 24, 2012, 11:15 AM
P Farley's Avatar
Joined Aug 2006
Re: Low rates
I was worried that even the low rates are touchy. I flew a Sukhoi not too long ago at the recommended low rates, and they were still too extreme for first flights.
Old Apr 24, 2012, 06:37 PM
Joined Sep 2003
The 4035 series is perfect! 8mm shaft as well. The collet has 4 slots and holds very well. 2000 watts would be crazy vertical
Old Apr 24, 2012, 07:54 PM
Joined Dec 2011
I went with the 50-50 580kv NTM series
Prop Test Data:
14x8 - 14.8V / 587W / 40.3A / 2.9kg thrust
14x8 - 18.5V / 1077W / 60.7A / 4.03kg thrust
14x8 - 22.2V / 1906W / 88.2A / 5.36kg thrust
15x8 - 14.8V / 626W / 43.6A / 3.3kg thrust
15x8 - 18.5V / 1165W / 64.2A / 4.85kg thrust
15x8 - 22.2V / 1961W / 88.8A / 6.15kg thrust
Old Apr 25, 2012, 12:32 PM
nioa's Avatar
Phoenix, AZ
Let us know how it works out for you Garrett.
I found the NTM Prop Drive 50-50 580KV / 2000W on the website, and I see the power figures you posted are HK's figures. I have not had very good luck confirming the numbers that HK issues for their motors. Perhaps, if you have time, you could share your test measurements with us.
Thanks in advance
Old Apr 25, 2012, 03:35 PM
Joined Dec 2011
Im really thinking about building a test stand and buying the wattmeter
Old May 14, 2012, 09:34 AM
P Farley's Avatar
Joined Aug 2006
Maiden!
Flew mine yesterday for the 1st time and then later on in the afternoon, twice more. I am so impressed with how well it flies. Low rates were perfect for the first flights. Landings were good too, a bit faster than what I am used to. I fly large sailplanes and I am used to bringing in planes low and from far away for landings.
I'm running the Rimfire 80, a 15x7 apc, and 6s 5000mah batteries and it seemed the last 1/3 or 1/4 throttle added nothing to the speed of the plane. It almost sounded like the prop was cavitating. Not a big deal for now though, I want a few more mellow flights under my belt.
Article Great Planes Revolver GP/EP Sport Aerobatic ARF Review kevin Sport Planes 595 Mar 26, 2013 12:10 AM
For Sale (slightly used...) Great Planes Revolver and Freestyle Rush. cargomaster Aircraft - Fuel - Airplanes (FS/W) 19 Oct 02, 2010 04:16 PM
For Sale Great Planes Revolver .46-.70 NIB - $140. ptuxbury Aircraft - Fuel - Airplanes (FS/W) 1 Dec 09, 2009 06:15 PM
Sold NIB Great Planes 70" Revolver ARF RCForever Aircraft - Fuel - Airplanes (FS/W) 1 Dec 09, 2009 03:35 PM
Sold Great Planes Revolver Fidelity101 Aircraft - Electric - Airplanes (FS/W) 3 Sep 13, 2009 07:05 PM
