Old Jul 03, 2011, 09:09 PM
jwill84 is offline
Find More Posts by jwill84
United States, CA, Claremont
Joined Mar 2011
I just bought some 17x12 props to run on my 1.20. just wanted to make sure there were no issues with this setup.
jwill84 is offline Find More Posts by jwill84
Old Jul 03, 2011, 10:37 PM
TheRook76 is offline
Find More Posts by TheRook76
Got Adrenaline?
TheRook76's Avatar
Ruskin, FL
Joined Mar 2009
When I ran the 17x12 with the 120 it exceeded the amp draw for my CC Ice 100 esc.
TheRook76 is offline Find More Posts by TheRook76
Old Jul 04, 2011, 06:30 AM
jwill84 is offline
Joined Mar 2011
Ok, what's the best setup to keep the electronics cool, amps down and longer flight times? Not to worried about speed at this time.
Old Jul 04, 2011, 10:01 AM
Got Adrenaline?
TheRook76's Avatar
Ruskin, FL
Joined Mar 2009
When I ran the 17x12e prop the amps read 143. Then the esc shut off. With the 17x8e prop I get 94 amps and 2110 watts. I get a full 5min flight before attempting to land and only put 3750 mah back in a 6s 65c 5000mah Pack. It's fast and pulls vertical till u can't see it anymore. I like my setup but for the future I might go up to 8s with a different motor. Below is my setup
Rimfire 1.20
CC Ice 100
65c 6s 5000 mah pack
1500 nimah rx pack
17x8e prop
Changed control rods to 4-40 with sulivan c clip rod ends (less flex than 2-56)
Old Jul 05, 2011, 12:10 PM
jwill84 is offline
Joined Mar 2011
thanks for the info.
Old Jul 05, 2011, 12:32 PM
chevronflyer is offline
Find More Posts by chevronflyer
"Takeoffs are optional"
chevronflyer's Avatar
United States, FL, Middleburg
Joined Feb 2007
going to maiden mine tonight with a gens ace 6s 5300mah 30c lipo, 80 amp hobbywing esc, 12x7 xoar electric prop and rimfire .60 motor and castle bec. (no rx battery onboard)
i will let you know how it goes, watt meter shows 2000 watts at 80 amps full throttle.
plane is 9lbs giving me 222 watts per pound
chevronflyer is offline Find More Posts by chevronflyer
Old Jul 05, 2011, 05:34 PM
ACKopter is offline
Find More Posts by ACKopter
Branford, Florida
Joined Jun 2010
Make sure your carefull with the throttle on that set-up. Your well beyond the motors continious rating and very near its max burst. I suppose it will unload a bit once in the air but keep it in check and watch motor/esc/battery temps till you know your safe. Should be some pretty good performance otherwise so be sure to give a report on the maiden.
ACKopter is offline Find More Posts by ACKopter
Old Jul 05, 2011, 07:32 PM
Joined Feb 2007
planed flies well but my esc seems to be screwed up... when i throttle up slow no big deal, when i throttle up fast, past half throttle the motor decides to lock up then start sputtering and running backwards and forwards, like it cant decide. at first thought it was the timing, set the esc to low and then it seemed to fix it but then it started doing it randomly again... i am going to put a castle ice 100 on it tomorrow and see if the problem goes away, otherwise its the motor thats having issues
Old Jul 05, 2011, 07:34 PM
Joined Feb 2007
yeah , i am flying this setup in my mig 27 drone from carl goldberg only using an apc 12x8 and castle 100 ice esc. i can fly for 20 mins on a 6s 5300 lipo because the plane cruises around at 1/4 to half power
Old Jul 06, 2011, 05:26 AM
ACKopter is offline
Branford, Florida
Joined Jun 2010
It certainly sounds like a setting issue to me, however, I've been using a Rimfire .80 in a different plane with a Hobbywing 70A ESC. I left all settings in the default position and have had no issues. Hope you can get it sorted.
Old Jul 06, 2011, 06:30 AM
Joined Feb 2007
i tried switching the timing from low to mid then to high. no change
Old Jul 06, 2011, 10:03 AM
Got Adrenaline?
TheRook76's Avatar
Ruskin, FL
Joined Mar 2009
Have you tried with a different esc? could be the motor.
Old Jul 06, 2011, 10:22 AM
Joined Feb 2007
see post above
in about 30min i will know if switching the esc fixes it
Old Jul 06, 2011, 06:28 PM
rcjetpilot is offline
Find More Posts by rcjetpilot
Bot's like to know where you live
Joined Sep 2003
Check to see if your ESC setting for pole count is correct....
rcjetpilot is offline Find More Posts by rcjetpilot
Reply With Quote  (Disabled)
Old Jul 06, 2011, 07:17 PM
Joined Feb 2007
switched to a castle ice 100 and now the problem is solved. motor runs fine. not sure if the pentium 80 opto esc itself went bad or if there were some cold solder joints on the bullet connectors. i will look into the esc further to see if it can be salvaged before i just trash it
Article Great Planes Revolver GP/EP Sport Aerobatic ARF Review kevin Sport Planes 784 Sep 21, 2016 05:57 PM
For Sale (slightly used...) Great Planes Revolver and Freestyle Rush. cargomaster Aircraft - Fuel - Airplanes (FS/W) 19 Oct 02, 2010 04:16 PM
For Sale Great Planes Revolver .46-.70 NIB - $140. ptuxbury Aircraft - Fuel - Airplanes (FS/W) 1 Dec 09, 2009 06:15 PM
Sold NIB Great Planes 70" Revolver ARF RCForever Aircraft - Fuel - Airplanes (FS/W) 1 Dec 09, 2009 03:35 PM
Sold Great Planes Revolver Fidelity101 Aircraft - Electric - Airplanes (FS/W) 3 Sep 13, 2009 07:05 PM
