Old May 04, 2011, 07:25 PM
TheRook76 is offline
Find More Posts by TheRook76
Got Adrenaline?
TheRook76's Avatar
Ruskin, FL
Joined Mar 2009
Ouch, sorry to here that.
TheRook76 is offline Find More Posts by TheRook76
Old May 04, 2011, 10:24 PM
emillard is offline
Find More Posts by emillard
USA, KY, Lexington
Joined Dec 2007
Oh man! I just looked through all of your pictures on the Revolver. You had a really nice set-up. Sorry to hear about that. I see you have the 46 size Revolver too.
emillard is offline Find More Posts by emillard
Old May 04, 2011, 11:46 PM
Got Adrenaline?
TheRook76's Avatar
Ruskin, FL
Joined Mar 2009
Superem lost his revolver. Was not sure if you thought I lost mine.
I just replaced my aileron servos with HS 5085's metal gear. Will do some more flying this weekend.
Old May 05, 2011, 11:54 AM
Superem is offline
Find More Posts by Superem
Superem's Avatar
Joined Apr 2008
I had some 12 gauge wire lying around and made a series connector for 2x 3S 5000.
However the Zippy batteries come with 10 gauge.
Should I make the connector 10 gauge as well?
I bought a Castle Creations Series Connector for my 71 Slick and noticed that it too was 10 gauge.
Superem is offline Find More Posts by Superem
Old May 05, 2011, 12:18 PM
Got Adrenaline?
TheRook76's Avatar
Ruskin, FL
Joined Mar 2009
I would. I don't know much about electrics but common sense wise it makes sense to keep it the same gauge why choke it with smaller wires in the series connectors.
Old May 05, 2011, 02:35 PM
balistc1000 is offline
Find More Posts by balistc1000
balistc1000's Avatar
Chandler, AZ
Joined Nov 2008
Superem
Originally Posted by gewiens View Post
sorry to hear, that sucks!!
+1!!
balistc1000 is offline Find More Posts by balistc1000
Old May 06, 2011, 09:31 AM
bobo46 is offline
Find More Posts by bobo46
USA, MI, Lansing
Joined Oct 2008
trying out a xoar 15-7 on a satio 100 for my revolver going to make that 4 stoke go fast like a buel..
bobo46 is offline Find More Posts by bobo46
Old May 06, 2011, 09:53 PM
Superem is offline
Superem's Avatar
Joined Apr 2008
For build 2 I will try the 1/8 Robart Hinges. I think the 3/16 were too big.
Or should I just stick with the stock hinges?
Old May 07, 2011, 12:31 AM
Got Adrenaline?
TheRook76's Avatar
Ruskin, FL
Joined Mar 2009
The Stock ones are fine for me. I tend to fly my sport planes fast but smooth, no major g loads by hard pulls I have a 540 extra for that. I guess it will depend on your flying and what u want from your revolver.
Old May 07, 2011, 05:55 AM
Superem is offline
Superem's Avatar
Joined Apr 2008
The only problem I have with the CA hinges is after a while they become brittle and give especially on sport planes.
On my Pulse 25 , the rudder hinge decide to give at takeoff. I noticed it right away and aborted. It would've been and adventure if it took off.
I will try the 1/8 Robarts.
Old May 07, 2011, 09:36 AM
Got Adrenaline?
TheRook76's Avatar
Ruskin, FL
Joined Mar 2009
Learn something new everyday. I didn't know that about the CA hinges. Going to have to inspect my smaller revolver closer has she been in my hanger the longest.
Old May 12, 2011, 11:23 AM
gwebber is offline
Find More Posts by gwebber
United States, KS, Lawrence
Joined Aug 2007
This is my first electric greater than 4S. I plan to use a CC Phoenix 80 with a CC BEC. I understand the wiring diagram with one exception. The ESC with its red wire disabled plugs into the throttle port (CH3) on my receiver. Into which port does the BEC plug? I am using a Futaba R617FS receiver. CH1 is rt aileron, CH2 is elevator, CH3 is throttle, CH4 is rudder, CH 6 is left aileron, CH 5 and 7 are open.
Thanks!
gwebber is offline Find More Posts by gwebber
Old May 12, 2011, 11:31 AM
nioa is offline
Find More Posts by nioa
More Motors, More Fun... :-)
nioa's Avatar
Phoenix, AZ
You can put a plug on the BEC output and plug it into any open channel. In your case channel 5 or 7.
It doesn't matter because all the negative terminals are connected to each other, and all the positive terminals are connected to each other. The signal terminal is what is separate.
With a bird this big, I like a separate battery (receiver battery) instead of a BEC.
Nick
nioa is offline Find More Posts by nioa
Old May 12, 2011, 11:35 AM
gwebber is offline
Joined Aug 2007
Nick, what are your concerns? Running low on juice from the main packs? I would really like to avoid the extra weight.
Old May 12, 2011, 11:56 AM
nioa is offline
nioa's Avatar
Phoenix, AZ
I like to use a receiver battery separate from the power system. It makes testing of the control surfaces and electronics safer when you don't have the possibility of accidentally arming the power system as you might with BEC systems.
Some might also argue that the BEC is one more thing to fail. I have used 2S A123 cells with excellent results and I don't have to worry about the BEC trying to handle the 6S voltage being fed into it (increased power dissipation, etc.).
The additional weight of a small battery pack is insignificant for this plane. In my case, I need the small pack weight to balance the plane. See my blog on RCGroups for more info on my installation.
Article Great Planes Revolver GP/EP Sport Aerobatic ARF Review kevin Sport Planes 778 Jul 08, 2016 01:27 PM
For Sale (slightly used...) Great Planes Revolver and Freestyle Rush. cargomaster Aircraft - Fuel - Airplanes (FS/W) 19 Oct 02, 2010 04:16 PM
For Sale Great Planes Revolver .46-.70 NIB - $140. ptuxbury Aircraft - Fuel - Airplanes (FS/W) 1 Dec 09, 2009 06:15 PM
Sold NIB Great Planes 70" Revolver ARF RCForever Aircraft - Fuel - Airplanes (FS/W) 1 Dec 09, 2009 03:35 PM
Sold Great Planes Revolver Fidelity101 Aircraft - Electric - Airplanes (FS/W) 3 Sep 13, 2009 07:05 PM
