Old Apr 06, 2011, 11:38 AM
TheRook76 is offline
Find More Posts by TheRook76
Got Adrenaline?
TheRook76's Avatar
Ruskin, FL
Joined Mar 2009
Lhs doesn't have anything in 17 range. Ordered some and should be in by Friday. Just in time to maiden it this weekend.
TheRook76 is offline Find More Posts by TheRook76
Old Apr 06, 2011, 11:42 AM
gewiens is offline
Find More Posts by gewiens
Look Up!
gewiens's Avatar
Canada, MB, Niverville
Joined Apr 2008
You could go with an 18x6 and see how that goes also.
gewiens is offline Find More Posts by gewiens
Old Apr 06, 2011, 02:22 PM
emillard is offline
Find More Posts by emillard
USA, KY, Lexington
Joined Dec 2007
Have you tried adjusting the timing of the ESC? Moving the timing from low to medium or from medium to high may help. I've had that screeching before too and the problem was with my ESC timing. I've only used Turnigy ESCs though so your issue may be different.
emillard is offline Find More Posts by emillard
Old Apr 06, 2011, 02:42 PM
Got Adrenaline?
TheRook76's Avatar
Ruskin, FL
Joined Mar 2009
I'm waiting for the delivery today of the castle link and watt meter. will test the 17x12 that's on there now and see how many amps it's pulling and if it's exciting the ice 100 limits also will be able to see what timing is set at with the castle link. New props come in on friday.
Old Apr 06, 2011, 02:57 PM
gewiens is offline
Look Up!
gewiens's Avatar
Joined Apr 2008
If your hitting the limits on the 100 your flight times are going to suck on 6s.
Old Apr 07, 2011, 11:28 AM
Got Adrenaline?
TheRook76's Avatar
Ruskin, FL
Joined Mar 2009
Ok so ran the bench test with watts meter and the 17x12 prop and wow. At 3/4 throttle it was pulling 97A at full throttle for the second it ran before shutting off it read 143A
That prop seriously pulls.
I get the 17x8 and 17x10 tomorrow. My guess would be the 17x8 like early recommended by another member.
Would it go alot faster if I get a larger ESC and stay with the 17x12?
But will my flight times suck?
Rimfire 120
CC Ice 100
6s 65c 5000mah Lipo
1500mah rx nimah pack
Old Apr 07, 2011, 11:46 AM
gewiens is offline
Look Up!
gewiens's Avatar
Joined Apr 2008
I don't think it will go faster. Alot of the times higher rpm is better. I guess you don't have an RPM gauge do you? Forgot to mention. If you are pulling 97amps at 3/4 and continue to run it that way you will have shorter run times then you think. (BOOM!)
Old Apr 09, 2011, 11:38 AM
balistc1000 is offline
Find More Posts by balistc1000
balistc1000's Avatar
Chandler, AZ
Joined Nov 2008
Wow, that seems way off. I have the same size and kv motor (different brand) and with a 16x14 pattern prop, which is really big compared to a E-prop, I don't get anywhere near those amps. With a 6s 50c 5000mah lipo. Maybe the kv is off on the motor?
balistc1000 is offline Find More Posts by balistc1000
Old Apr 11, 2011, 09:16 PM
Got Adrenaline?
TheRook76's Avatar
Ruskin, FL
Joined Mar 2009
I haven't had much time to work on the model. But I did run the 17x8e prop and got 89 amps at full throttle. Going to run the 17x10e prop next. After I get all these things figured out and get better, I'll attempt the maiden. Been a little under the weather.
Old Apr 11, 2011, 10:01 PM
gewiens is offline
Look Up!
gewiens's Avatar
Joined Apr 2008
That sounds abit better.
Old Apr 14, 2011, 10:26 PM
gewiens is offline
Look Up!
gewiens's Avatar
Joined Apr 2008
No new maiden reports on this bird yet?
Old Apr 14, 2011, 11:42 PM
Superem is offline
Find More Posts by Superem
Superem's Avatar
Joined Apr 2008
I bit the bullet and bought one of these from Tower.
Using 5 S3004 Servos (2 for Elevators) with 6.0V Battery
Rimfire 1.20, Ice 100, Ball Links all around and Robarts for the elevator and rudder.
Still in the building process. Will have pics once she's ready.
Superem is offline Find More Posts by Superem
Old Apr 15, 2011, 06:41 AM
Got Adrenaline?
TheRook76's Avatar
Ruskin, FL
Joined Mar 2009
Sorry for nothing new posted. I got sick and it turned into a bad case of pneumnia. Ended up in the hospital this pass Sunday and still here this Friday morning. Looks I'm going to be discharged today. Going to run final test, snap pics of my setup, and trying to get my brother to film my maiden. Hopefully by Monday I should post up some pics, a vid, and a castle flight log from the esc.
Old Apr 15, 2011, 01:31 PM
misfire is offline
Find More Posts by misfire
Joined Aug 2007
Revolver vs. 3DHS model
Man that's hard! I've been there - last October, which has the best weather and is the most photogenic month here in the WV hills, I had a bunch of RC goals I was planning to tick. But on 10/2, my birthday no less, I went to the clinic about (what I thought was) a bad sinus infection I couldn't shake. But my pulse O2 was so low they sent me right to hospital #1. This obnoxious old doctor told everybody he thought I had pneumocystis(sp) pneumonia, which is associated with AIDS. They put me in isolation and informed me that - while I was there! - they were going to detox me off of the prescription pain meds I've needed and used successfully for a number of years. The staff was treating me like a street addict.
WV has its good and bad points...
I was able to transfer to a great hospital (in VA), where they determined it was some other type, I forget, but apparently I was bad off. I mostly remember these scary paranoid delusions I was having, from sedatives and not enough oxygen to the old gray matter. Anyway, they put me under full sedation for 3 days and pumped me full of high-powered antibiotics, and after 2 weeks plus in the hosp., I was so glad to finally get sprung. By the time I was strong enough to fly, it started snowing and didn't stop.
I never get sick, and there's no idea where it came from. Wierd!
Rook, I hope you get out soon! Push the docs and nursing staff for what you need/want. The squeaky wheel and all that!
Hey, gang, I do actually have a topical question. I've been looking hard at this plane. I'm about due for my fourth (first balsa/ply) plane. I want something sporty that I can get in the air within a few weeks, and keep the total budget as close to $500 as possible. Something fairly large that my aging eyes can follow (when I get in trouble these days, it always seems to be from losing orientation. Meanwhile, 3DHS has such great cred, and I could see spending a little more or sacrificing a little wingspan to get, say, an AJ Slick.
I could also see me crashing whatever I get. Oh well, gotta learn about repairing/covering wood sometime...
Any thoughts? Thanks.
misfire is offline Find More Posts by misfire
Old Apr 15, 2011, 06:10 PM
tlr-boise is offline
Find More Posts by tlr-boise
Boise, ID
Joined Dec 2008
misfire,
Check out the smaller Escapade. If one of your first three planes is fairly challenging, the Escapade might be a good next step. I have never flown one, but guys like it a lot.
The smaller Revolver is fun too, but landing gear is fragile unless you've mastered a 3-point landing, or tail-wheel-first landing. On that thread, you can read my saga with the LG of the smaller Revolver. Now that I've fixed it (a few times) I like the Revolver a lot.
I'd recommend the Great Planes Super Sportster too, as a first balsa plane, except it's landing gear stinks, and needs to be replaced by the red GP Electrostik landing gear that you can get from Tower Hobbies. They're fiberglass and very light and stiff. If you've got the drill press, you can drill two new holes in the bottom and replace the gear, no problem. The first time I flew that, it seemed SO FAST! If you search this forum for "GP Super Sportster" you'll find a very informative thread.
I just got a 46" Aspera from 3D Hobby Shop, and have flown it a few times. It's a super-easy landing plane (only weighs 3 lbs., same as my Super Sportster), yet it's bigger. I might have bought the last one, and it's soon to be replaced by a small Osiris, and that might be your next plane. Should be available in a few weeks.
That's my $.02.
tlr-boise is offline Find More Posts by tlr-boise
Article Great Planes Revolver GP/EP Sport Aerobatic ARF Review kevin Sport Planes 656 Yesterday 01:55 PM
For Sale (slightly used...) Great Planes Revolver and Freestyle Rush. cargomaster Aircraft - Fuel - Airplanes (FS/W) 19 Oct 02, 2010 05:16 PM
For Sale Great Planes Revolver .46-.70 NIB - $140. ptuxbury Aircraft - Fuel - Airplanes (FS/W) 1 Dec 09, 2009 07:15 PM
Sold NIB Great Planes 70" Revolver ARF RCForever Aircraft - Fuel - Airplanes (FS/W) 1 Dec 09, 2009 04:35 PM
Sold Great Planes Revolver Fidelity101 Aircraft - Electric - Airplanes (FS/W) 3 Sep 13, 2009 08:05 PM
