This thread is privately moderated by feathermerchant, who may elect to delete unwanted replies.
Old Dec 08, 2010, 12:42 PM
feathermerchant is offline
Find More Posts by feathermerchant
Use the 4S Luke
feathermerchant's Avatar
USA, TX, Euless
Joined Aug 2003
The answer from my experience is the case never gets warm so it does not rely much on it at all. Be sure to check the case temp though just in case. You can also check the exiting air temp.
feathermerchant is offline Find More Posts by feathermerchant
Old Dec 08, 2010, 12:48 PM
TheBum is offline
Find More Posts by TheBum
TheBum's Avatar
McKinney, TX
Joined May 2007
Thanks. It's the same story with my MeanWell, but not having any experience with these HP supplies, I wasn't sure.
TheBum is offline Find More Posts by TheBum
Old Dec 16, 2010, 10:58 PM
cpdude is offline
Find More Posts by cpdude
Designing something...
United States, CA, Cameron Park
Joined Jan 2004
I thought I'd post a picture of my 47A setup. It works great! The banana plugs and wire came from my local hobby shop. The black prototype box came from Radio Shack.
Thanks!
Brian
cpdude is offline Find More Posts by cpdude
Old Dec 18, 2010, 09:52 PM
losifanatic is offline
Find More Posts by losifanatic
Sippin the Koolaid!
losifanatic's Avatar
United States, NC, Hertford
Joined Oct 2007
Ok I just got my two 42amp power supplies. My new powerlab 8 is the 40amp output version (wow) So I am going use the amp limiting feature. But I need to connect the 2. All I have to do is keep the two charges from hiting each other b/c one now has 12 volts to the case and the other one is ground. OK I just need to diconnect the ground from one of the chargers and thats that. If so that sounds easy enough! Wish me luck!
EDIT: I found on the 42 amp version all you have to do to one of the supplies is undo one of the mounting screw and that ungrounds the case. Its the one that is at the end where yo hare soldering two and its the screw thats the closest to the edge of the cas. I pulle dout the tab that the screw threads into and placed a small peice of balsa there to keep it from grounding out. I will have to get a pic to show you all what Im talking about as im not that good at explaning things but it was very easy and I now dont have to worry about the two cases touching and blowing up my power supplies
losifanatic is offline Find More Posts by losifanatic
Old Dec 26, 2010, 11:13 PM
dougbo is offline
Find More Posts by dougbo
Proverbs 12:15
dougbo's Avatar
USA, WA, Richland
Joined Nov 2009
using automotive connectors on 42A
Currently I'm using the PS as a 12v supply but will tie them together for 24v soon.
I didn't want to solder directly to the PS so I went the auto connector route (with insulation removed).
Doug B.
dougbo is offline Find More Posts by dougbo
Old Dec 28, 2010, 01:11 PM
crzytxn is offline
Find More Posts by crzytxn
United States, TX, Waco
Joined Sep 2008
If I get the 12v 47a power source you are selling, will it be ok to hook my turnigy accucell6 that is rated for 12v 5a to. This is the only charger i have right now but i plan on buying a better charger in a few months and i know i am gonna need a good ps. So i am just wondering if this ps will damage my little charger.
Thanks, Chris
crzytxn is offline Find More Posts by crzytxn
Old Dec 28, 2010, 04:11 PM
Sippin the Koolaid!
Joined Oct 2007
yes there is no issues hooking up a 12V charger to a 12V power supply. The 5amp rating of the charger is what it will pull MAX the power supply is Rated to supply from less than 1 amp all the way to 47 amps. So if you needed you can hook up Multiple chargers to that power supply
Old Dec 28, 2010, 04:51 PM
crzytxn is offline
Joined Sep 2008
Thank You.....
Old Dec 28, 2010, 05:56 PM
Use the 4S Luke
USA, TX, Euless
Joined Aug 2003
Yup Thx Losi.
Old Dec 28, 2010, 08:37 PM
Sippin the Koolaid!
Joined Oct 2007
Feathermerchant, I put you power supplies to the test today. I put the powerlab8 up to 40amp charge to see what it could do. The power supplies handled it with no issues. They didnt even get hot! Great product and thank you!
Old Dec 28, 2010, 10:57 PM
Use the 4S Luke
USA, TX, Euless
Joined Aug 2003
Glad you likem and sorry to hear about yout (late) 330. I have mine ready to maiden. Prolly Thurs.
Old Dec 29, 2010, 06:32 AM
Sippin the Koolaid!
Joined Oct 2007
I will have another one hopefully late next week!
Old Jan 20, 2011, 09:13 PM
r/cmark is offline
Find More Posts by r/cmark
200 mph club
r/cmark's Avatar
United States, AZ, Fort Mohave
Joined Mar 2005
I just got my 42amp power supply. It works!!!
r/cmark is offline Find More Posts by r/cmark
Old Jan 23, 2011, 06:40 PM
philip frank is offline
Find More Posts by philip frank
ft. worth
Joined Jul 2004
how about some good photos of the wiring connection points where you solder/connect the power supplies together.
wanna make sure i connect it properly.
philip frank is offline Find More Posts by philip frank
Old Jan 23, 2011, 09:05 PM
Use the 4S Luke
USA, TX, Euless
Joined Aug 2003
Go hete:
http://www.rcgroups.com/forums/showthread.php?t=1051873
and see post #114. There are also other good pics.
For Sale Used PC Power supplies converted for 12V DC chargers ddierking Aircraft - Electric - Batteries & Chargers (FS/W) 3 Jan 13, 2010 08:14 AM
Sold ***POWERFUL*** 12V 30 Amps Power Supply SLIM & LIGHT MJB9 Aircraft - Electric - Batteries & Chargers (FS/W) 3 Dec 07, 2009 11:39 AM
For Sale 12V Power supplies 30A $40 and 42A $50 for your chargers feathermerchant Aircraft - Electric - Batteries & Chargers (FS/W) 1 Sep 03, 2009 08:07 PM
Discussion 2x 12v chargers in series with a 24v Power Supply? cmacclel Batteries and Chargers 3 Jan 21, 2008 01:39 PM
Can I put two 12v bench power supplies in series = 24v? rakm Batteries and Chargers 7 Nov 24, 2003 11:15 PM
