This thread is privately moderated by feathermerchant, who may elect to delete unwanted replies.
Old Apr 17, 2011, 11:41 AM
feathermerchant is offline
Find More Posts by feathermerchant
Use the 4S Luke
feathermerchant's Avatar
USA, TX, Euless
Joined Aug 2003
You should be able to do that. Remember that the 1500W or so that you are drawing from your 12V outlet is about 1500/120=12.5A. Most household circuits are rated for 15A and may have several outlets/lights on them.
feathermerchant is offline Find More Posts by feathermerchant
Old Apr 17, 2011, 12:05 PM
Nicoflyer is offline
Find More Posts by Nicoflyer
Pushing the envelope
Nicoflyer's Avatar
Valatie, N.Y.
Joined Jan 2006
I'll be running this off a 2000 watt Honda generator.
So to do this is it alright to use 2 sets of your PS that are put in series and then put the two outputs in parallel?
Nicoflyer is offline Find More Posts by Nicoflyer
Old Apr 17, 2011, 02:04 PM
Use the 4S Luke
USA, TX, Euless
Joined Aug 2003
I think so. Make sure your 120V circuit can handle it. It may be different than the 240V circuit.
Old Apr 17, 2011, 03:09 PM
Nicoflyer's Avatar
Valatie, N.Y.
Joined Jan 2006
Have you tried putting 2 in parallel?
I know that you cant put 2 switching bec in parallel,because if they see each other they will not work and eventually burn up.
Do you think that I should put isolation diodes on the + line out from each PS?
Old Apr 18, 2011, 04:46 AM
Use the 4S Luke
USA, TX, Euless
Joined Aug 2003
No I have not but these are designed to work in parallel in a file server so they should work OK. I think others have.
Old Apr 23, 2011, 08:51 AM
sailr is offline
Find More Posts by sailr
Land O' Lakes, FL
Joined Aug 2003
I used the automotive connectors to wire up my power supplies but they would not hold well. Tried different brands. After much frustration, I used my hot glue gun to 'flood' the terminals with the connectors in place. No more problem!
sailr is offline Find More Posts by sailr
Old Apr 23, 2011, 08:58 AM
jj604 is offline
Find More Posts by jj604
ancora imparo
jj604's Avatar
Melbourne, Australia
Joined Jul 2005
You can also just squeeze them with pliers. The contact is made by the edge of the bent over bit and you can squeeze the gap narrower so they grip tightly.
jj604 is offline Find More Posts by jj604
Old Apr 23, 2011, 09:14 AM
sailr is offline
Land O' Lakes, FL
Joined Aug 2003
Tried squeezing them with pliers. No good. I have 10 guage wires to the connectors so there is a pretty good load on them. If you're using small wires, they would probably be OK.
Old Apr 23, 2011, 02:41 PM
Gregor99 is offline
Find More Posts by Gregor99
Revolectrix Ambassador
Seattle
Joined Sep 2007
Originally Posted by Nicoflyer View Post
I know I may be pushing it here, but I'd like to know if its possible to put 4 PS together to make a 24 volt @ 94 amps. The reason is the new PL-8 are good for 1344 watts and I'm charing 4- 6s 5000 in parallel and with the 2 PS put in series which makes them good for 1128 watts.
I can charge them a 30 amps max, I'd like to charge them at 40 amps which is 2c.
To get the full 1344 watts (40 amps) I'd need 1344 watts plus 20%.
Thanks, Angelo
The Powerlab8 wattage rating of 1344 is based on 8s. For a 6s pack the max wattage is 1008 at 40 amps. Add in charger efficiency of 90% and you need 1120 watts to max out the PL8 charing 6s@40 amps. The 47a supplies are good for 575 watts, each and I know if one person that has successully pushed it past that (but for how long,?????). So two 47a supplies will give you 1150 watts. Also remember that the wattage peaks occur near the end of the charge and don't last all that long. The charge will start at about 90% of peak wattage and granually increase as the cells reach 4.2v.
Gregor99 is offline Find More Posts by Gregor99
Old Apr 23, 2011, 06:43 PM
Use the 4S Luke
USA, TX, Euless
Joined Aug 2003
I've sold several pairs to those with Power Labs and so far I have not heard of any problems.
Old Apr 29, 2011, 01:24 AM
Brutikus is offline
Find More Posts by Brutikus
Pasadena, CA
Joined Mar 2007
is the 24v PSU still available?
how long will it take to ship to California?
Brutikus is offline Find More Posts by Brutikus
Old Apr 29, 2011, 04:51 AM
Use the 4S Luke
USA, TX, Euless
Joined Aug 2003
Yes. I have plenty of stock. I ship USPS priority so a couple of days.
Old May 14, 2011, 05:54 AM
wolven is offline
Find More Posts by wolven
Joined Jan 2011
Hi mate,
I've just sent you an email (as suggested on your website) to request a quote for a power supply to be shipped to Australia.
It is for a iCharger 3010b and I'm new to the whole charger / PS business.
Thanks in advance.
Rgds.
wolven is offline Find More Posts by wolven
Old May 14, 2011, 06:14 PM
dswitkin is offline
Find More Posts by dswitkin
dswitkin's Avatar
United States, CA, SF
Joined Sep 2007
I talked to two guys at a fun fly today who had figured out how to have two 12V supplies in series with both of them grounded, and able to touch each other. There's some trick with keeping the A/C side grounded while ungrounding the D/C from the cases. Is anyone familiar with this technique, or have a diagram of how/why it works?
Daniel
dswitkin is offline Find More Posts by dswitkin
Old May 14, 2011, 09:58 PM
jj604 is offline
ancora imparo
jj604's Avatar
Joined Jul 2005
There's a whole thread on it . Look here
http://www.rcgroups.com/forums/showthread.php?t=1369612
Also some more info in the 12V 100A supply thread in the most recent posts.
http://www.rcgroups.com/forums/showthread.php?t=1005309
Around post 678
Daniel
For Sale Used PC Power supplies converted for 12V DC chargers ddierking Aircraft - Electric - Batteries & Chargers (FS/W) 3 Jan 13, 2010 08:14 AM
Sold ***POWERFUL*** 12V 30 Amps Power Supply SLIM & LIGHT MJB9 Aircraft - Electric - Batteries & Chargers (FS/W) 3 Dec 07, 2009 11:39 AM
For Sale 12V Power supplies 30A $40 and 42A $50 for your chargers feathermerchant Aircraft - Electric - Batteries & Chargers (FS/W) 1 Sep 03, 2009 08:07 PM
Discussion 2x 12v chargers in series with a 24v Power Supply? cmacclel Batteries and Chargers 3 Jan 21, 2008 01:39 PM
Can I put two 12v bench power supplies in series = 24v? rakm Batteries and Chargers 7 Nov 24, 2003 11:15 PM
