Old Jan 28, 2011, 08:19 AM
Tatonka is offline
Find More Posts by Tatonka
Buffalos have wings
Tatonka's Avatar
Vancouver Washington
Joined Nov 2007
I got the motors I ordered from HK, they look to be almost exactly the same size as stock...Might even have the same size bearing that was bad in stock motor, maybe I'll try swapping the bearing and keeping the stock motor in there, I'll have to do some more checking to see if that would work.
Tatonka is offline Find More Posts by Tatonka
Old Jan 28, 2011, 08:47 AM
dude_109 is offline
Find More Posts by dude_109
dude_109's Avatar
Houston, TX
Was it the motor you linked in post #733? Is it a drop in fit?
Just in case I need to replace mine one day...
dude_109 is offline Find More Posts by dude_109
Old Jan 28, 2011, 09:04 PM
Tatonka is offline
Buffalos have wings
Tatonka's Avatar
Joined Nov 2007
Yes, that is it, it looks like it should drop right in , but I have not had a chance to try it yet,
Old Jan 29, 2011, 06:50 AM
FLOEY is offline
Find More Posts by FLOEY
Norway
Joined Dec 2007
Check shaft dia with a caliper. If above 3mm (~3.17) the bearings
will not fit (imperial units).
FLOEY is offline Find More Posts by FLOEY
Old Jan 30, 2011, 01:38 PM
Silverexpress is offline
Find More Posts by Silverexpress
Your customer
Silverexpress's Avatar
United States, MI, Berkley
Joined Dec 2009
Removed - Post outdated
Silverexpress is offline Find More Posts by Silverexpress
Old Jan 31, 2011, 12:40 AM
McMoron is offline
Find More Posts by McMoron
Joined Dec 2007
Originally Posted by Silverexpress View Post
Is anyone contemplating putting retracts on their Spitfire? I've recently added wire struts and foam wheels + a steerable tailwheel. No more gouges or broken props!
I bought some retracts (the smallest GWS from HK) the day I received my Emil, but haven't installed them because I don't have suitable landing strip in the local 'park' I'm flying the Emil. Otherwise, I'd have gone for it!
McMoron is offline Find More Posts by McMoron
Old Jan 31, 2011, 06:11 AM
FLOEY is offline
Norway
Joined Dec 2007
I've got a Alfa P-47 with fixed landing gear and one with retracts (not finished).
My experience with the fixed landing gear P-47 is that it's difficult to land without
nosing into the ground with a scale landing gear. I've increasedwheel size but still
problems. As McMoron I got no well suitable landing site either.
In my Spitifre I've replaced the heavy AF400 30gram brushless motor with a
light one (20 gram) with prop saver. So far I've not replaced any prop since
then. I get som dents and bruises but that would happen with a landing
gear too. Add to that the additional weight of the landing gear not to mention
a retract I do not believe this is the way to go (with my pilot skills at least)
Old Jan 31, 2011, 02:13 PM
minirips2 is offline
Find More Posts by minirips2
Chicago Northwest subs
Joined Jan 2007
Both the Spitfire and Emil have odd retracts of less than 85 degrees. If you did retracts, they'd probably end up looking very non-scale, which would be a shame on such faithfully reproduced models. I don't think the added weight would be well tolerated either. I've been flying mine for a while, and have the original prop still installed. Just lucky, I guess....
MR2
minirips2 is offline Find More Posts by minirips2
Old Feb 02, 2011, 02:17 AM
Abey is offline
Find More Posts by Abey
Bordighera
Joined Dec 2008
3B prop
Hi guys !
Do any of you tried this graupner 3B propeller ? http://www.hobby-lobby.com/8x6_prop_...e_394_prd1.htm
Cause the original is 7x6, this will fit even if we cut it a bit...
What do you think ?
Cheers !
Abey is offline Find More Posts by Abey
Old Feb 02, 2011, 03:47 AM
Abey is offline
Bordighera
Joined Dec 2008
We can find this one as well : http://www.valuehobby.com/product_de...44&item_id=438
Old Feb 02, 2011, 04:00 AM
Abey is offline
Bordighera
Joined Dec 2008
And what about a 7x4 prop such as http://h1071118.hobbyshopnow.com/pro...prod=MAS0740TP
I want a 3-b prop to preserve the scale look
Old Feb 02, 2011, 04:48 AM
Joined Jan 2007
Originally Posted by Abey View Post
Hi guys !
What do you think ?
Cheers !
Those Graupner props are big. The stock motor will not be capable of turning it. Maybe the 7X4 would work with a 3S battery. I haven't tried it. Experimenting with different props is much of the fun of flying models.
MR2
Old Feb 02, 2011, 05:23 AM
FLOEY is offline
Norway
Joined Dec 2007
I would look out for a 7x5 - 7x4 3 blade and rather go for 3S.
More RPM and less pitch better thrust. What You should look
is a (~7000RPM) prop (APC SF) not a high RPM prop like APC E.
Old Feb 02, 2011, 06:38 AM
Abey is offline
Bordighera
Joined Dec 2008
Thanks all for your replies, but i've only seen 2-b apc SF and not 3-B ?? can you confirm ?
Old Feb 02, 2011, 10:23 PM
Your customer
Joined Dec 2009
New Product New Kyosho DF55 models:F-22 and Panavia Tornado -PaX- Foamy EDFs 25 Oct 26, 2010 10:54 PM
Discussion New Goodies for your Ground Station from Range Video. Tarro FPV Talk 6 Dec 13, 2009 12:19 PM
Wanted 11.1V Lipos 25-35C rating..new or like new 2200mAh range rdr4evr69 Aircraft - Electric - Batteries & Chargers (FS/W) 3 Oct 04, 2009 11:28 PM
New Product New Kyosho Minium and Minium AD models fuji Scratchbuilt Indoor and Micro Models 98 Jul 09, 2009 06:46 AM
New Mega 16/25/3 in Kyosho or MiniFan nadt770 Electric Ducted Fan Jet Talk 49 Jan 08, 2004 06:28 PM
