Old Dec 25, 2009, 05:55 PM
joliecoeur13 is offline
Find More Posts by joliecoeur13
joliecoeur13's Avatar
Canada, BC, Fernie
Joined Dec 2009
4 in 1 ext set up ?
I'm wondering what the best ajustment is on the EXT screw for a 4#3b, for beginers.... (I know what you thinking, it's not a biginner heli...I figured that out by now...)I messed with the EXT to see if it makes any difference ... I can now get it off the floor , wave left, right and crash !! how much difference does it make ? where should I set it? Oh and what's the extra battery plug for on the 4 in 1?
cheers
joliecoeur13 is offline Find More Posts by joliecoeur13
Old Dec 25, 2009, 08:40 PM
Xrayted is offline
Find More Posts by Xrayted
Closed Account
Joined Dec 2007
Originally Posted by joliecoeur13 View Post
I'm wondering what the best ajustment is on the EXT screw for a 4#3b, for beginers.... (I know what you thinking, it's not a biginner heli...I figured that you by now)I messed with it to see if it makes a difference ... I can now get it off the floor , wave left, right and crash !! how much difference does it make ? where should I set it? Oh and what's the extra battery plug for on the 4 in 1?
cheers
The EXT determines how far and fast the servos move. You can make the heli less sensitive with it. Its easiest to power up the heli and move the pot while moving the cyclic stick to see the change in real time.
The extra plug on the the RX is where the battery plugs in for the non brushless version where there is no seperate speed control. Ignore it.
Xrayted is offline Find More Posts by Xrayted
Discussion Polks Tracker III set up in sims Zagabond Simulators 2 Dec 20, 2009 05:40 PM
Sold Pull / Pull set up 4-40 and more dumbdidgits Aircraft - Fuel - Airplanes (FS/W) 0 Dec 11, 2009 12:50 PM
Discussion Set up system for 1/10 off road mav1970 Off-road Cars 6 Dec 03, 2009 10:35 PM
For Sale Align 2 in 1 Regulator set up as Ignite Only rz22g Aircraft - Fuel - Engines and Accessories (FS/W) 0 Sep 07, 2009 11:03 AM
Poll Honey Bee Cp2 4 In 1 Gain Set Up DOCKERS2190 Micro Helis 0 May 09, 2008 10:36 AM
