Old Dec 25, 2009, 01:23 AM
Jevgeniy is offline
Find More Posts by Jevgeniy
Jevgeniy's Avatar
Joined Apr 2009
Help!
Hitec Aurora 9 reversed polarity damage
One guy here purchased Aurora 9 and imidiately installed lipo, but reversed polarity. Now he has found some electrician but they need part number. He sent me picture and is asking me to check out one part number, but I do not have my Aurora with me on holidays. I'm allmost sure thet that part (transistor probably) must have same part number as two other similar parts, but he want to know it for sure. If this part number is known to you or you are planing to open your A9, we will apriciate your help. And some one in future probably will find it useful too.
Thank you.
Jevgeniy is offline Find More Posts by Jevgeniy
Old Dec 25, 2009, 02:21 AM
guantamanera is offline
Find More Posts by guantamanera
I want to bark at the moon
guantamanera's Avatar
2 weeks in SoCal 2 weeks in WA
Joined Mar 2009
Thank you.
I burnt my too, but I have not replaced the burn capacitor yet. I just unshorted it by lifting the metal plate, and it works but I'll replace it as soon as the festivities pass and I have some time. I contacted hitec and the here is what they told me.
Tantalum capacitor (16V, 47uF, 20%).
guantamanera is offline Find More Posts by guantamanera
Old Dec 25, 2009, 02:26 AM
Jevgeniy is offline
Jevgeniy's Avatar
Joined Apr 2009
Thank you very much !
Old Dec 25, 2009, 09:08 AM
Rickochet is offline
Find More Posts by Rickochet
Card Carrying Old Fart
Rickochet's Avatar
Central Kentucky
Joined Oct 2006
I don't know where you are located but I did the same thing on an Optic 6. I sent it to Hitec in California. They received it on Friday, fixed it and sent it back on the next Monday and only charged me $23. It may be a different story if not located in the USA, but I would really consider sending it to a certified Hitec rpair shop regardless of location. What shorted was there to do just that to protect the rest of the radio. If the repairman is not 100% positive more damage could be done. Just my $.02 worth.
Rickochet is offline Find More Posts by Rickochet
Old Dec 25, 2009, 01:49 PM
4*60 is offline
Find More Posts by 4*60
most exalted one
Canada, BC, Blind Bay
Joined Aug 2002
That has to be one negative. You would think this could be guarded against in 2009 with modern components. That is one point of poor design. We better make sure there is good design in any mods to the power source with "T's" or other fool-proof connects.
4*60 is offline Find More Posts by 4*60
Old Dec 25, 2009, 02:01 PM
Rickochet's Avatar
Central Kentucky
Joined Oct 2006
Sorry but you can't take the "fool" out of foolproof. My Optic 6 has a polarized plug. I was making a new battery pack and ordered a non-hitec plug that looked just like the battery pack plug for the Optic 6. I plugged the plug in the tx to see if it would fit before attaching it to the battery pack. I soldered the pack to the plug and plugged it in. When turning on the TX I got the magic puff of smoke and Tx was inop. I compared the new plug to the old. Only then did I notice that the body of the plugs were identical but the OEM plug on my Hitec pack had the red wire on the left and the black on the right. The one I used had the red on the right and I didn't catch it in time. The problem was not the engineering, it was me, the fool. If someone did the same thing with an A9 how can you say that is an engineering negative?
Old Dec 26, 2009, 01:05 AM
4*60 is offline
most exalted one
Joined Aug 2002
Yes. I understand what you are saying but there are all sorts of RC devices that can be plugged in in error and survive. I think the equipment should have "forgiven" you your error. Coming from one who modified Eclipse, Prism 7, etc packs for years and was very careful. Then one day I had a brain fart and had to send an Eclipse in. The Aurora could have improved on that scenario. Just a 3 pin connection with one outside pin going nowhere would prevent the situation, would it not? Same as receivers? How simple is that?? Futaba uses a receiver plug in the 9C and I believe that solves the problem.
But hey I used to get paid to think outside the box(I know very overused phrase nowadays).
Old Dec 26, 2009, 02:44 AM
XJet is offline
Find More Posts by XJet
The reviewer
XJet's Avatar
Tokoroa
Joined Mar 2004
The reversed battery setup has killed many a Hitec O6/E7 (just search these forums for proof of that).
A better connector (such as the three-pin suggested by 4*60) would eliminate the chance of someone inserting the connector incorrectly but it won't help when someone wires up a battery wrongly.
A simple diode would solve that problem but it is yet another component which means more cost and something else to go wrong.
XJet is offline Find More Posts by XJet
Old Dec 26, 2009, 06:45 AM
ronwc is online now
Find More Posts by ronwc
Ron - AMA 1025
ronwc's Avatar
USA, FL, Largo
Joined Aug 2005
Amen to that - also that modifying a new tx will usually void any warranty. Still don't understand the whole changing to lipo in tx, my tx with standard pack will go well over 2 hours, which equates to about 8 flights a day - will beep if gets low which it never has -
ronwc is online now Find More Posts by ronwc
Old Dec 26, 2009, 01:27 PM
XJet is offline
The reviewer
XJet's Avatar
Tokoroa
Joined Mar 2004
Wow.. two hours?
On a good day, we'll put in about 4-5 hours flying (and I mean *flying*, not just standing around talking about flying ;-))
You could just get a decent field-charger and top-up your radio after every couple of flights -- that way you can fly all day, even on the stock pack.
Old Dec 26, 2009, 02:17 PM
Joined Mar 2009
not everybody flies on a airfield. I fly slope 100% of the, and many of the slopes require a long hike. I have a 2100mAh LSD NIMH which lasts more than 8 hours flying not just standing around and talking and it will probably go for another 4 hours. And if I had the stock battery I would have to go home early.
Old Jul 15, 2010, 07:39 PM
TheGreatBoo is offline
Find More Posts by TheGreatBoo
Joined Jun 2007
I have been charging my Aurora at the field with the battery in the Tx for a few months now ( yes I now know, bad bad, don't do it!! ) and I have now smoked it
Since warranty wont cover it I opened it up and looked it over, it looks similar to the reverse polarity damage up top. Not as much soot on the PCB but EC1 is definitely toasted... It was shorted but de-soldering it (will get new one later) does not fix the issue, the Aurora is still dead. Got a hint to look at the DC/DC converter below it (IC3). It is marked F150 does anyone know this type of converter?
TheGreatBoo is offline Find More Posts by TheGreatBoo
Old Jul 16, 2010, 10:20 AM
pilotpete2 is online now
Find More Posts by pilotpete2
pilotpete2's Avatar
The Northeast Kingdom, Vermont
Joined Jun 2004
Were you fast charging the stock battery, or charging a lipo in the transmitter
If you were using a lipo, how many cells
Pete
pilotpete2 is online now Find More Posts by pilotpete2
Old Jul 16, 2010, 06:10 PM
Joined Jun 2007
Pete
Stock NiMH battery at 120mA. Have been doing it for a few months so I thought it was OK but it was obviously NOT
Old Jul 16, 2010, 06:54 PM
pilotpete2's Avatar
Joined Jun 2004
Nothing wrong with charging the stock battery in the transmitter at that rate. Contact Hitec, I'm would think they'd take care of it.
Good luck,
Pete
Question Reverse Polarity Lipo mfboi Batteries and Chargers 6 Nov 27, 2015 10:27 AM
Discussion Reverse Polarity checker for Ground Station Cralis FPV Talk 20 Nov 11, 2009 04:40 PM
Discussion RTR Faster in reverse???? (Reverse Polarity?) xxtokerxx Electric Power Cars 10 Sep 21, 2007 05:58 PM
Discussion 1.2 GHz Wireless Video Polarity? Reverse-Polarity Protected? green66 Aerial Photography 2 Jul 30, 2006 10:33 PM
Idea Diode on controllers to prevent reverse polarity damage? Hogster Castle Creations 9 Jun 01, 2004 09:10 PM
