Old Mar 10, 2011, 06:28 PM
Dr Niceguy's Avatar
Joined Apr 2005
Ahh, that's clear now thanks for that Ian.
Unfortunatley that's a little beyond my hobby skills lol, I think a washer in the bottom mount would lift it enough, I just wondered if there were other ways (like grinding a little off the bottom plate).
Thanks though
Dr Niceguy is offline Find More Posts by Dr Niceguy
Old Mar 10, 2011, 06:42 PM
Melbourne, Australia
Joined Mar 2009
Grinding would be safer, as using washers will change your thrust angle which might cause some strange power-on handling
NinetySix is offline Find More Posts by NinetySix
Old Mar 11, 2011, 10:37 PM
Sydney
Joined Feb 2011
All complete,
It's running the following (before I start chopping it up and put the Turnigy 3648, 5cell):
Typhoon 2W 4.75 x 4.75
Turnigy 85A BEC
Flightmax 4 cell 2200 40c
Mr RC is offline Find More Posts by Mr RC
Old Mar 12, 2011, 11:53 PM
Joined Feb 2011
I was thinking about ordering batterys for my Skyfun (Im buying the plane a little later in the spring). And was woundering if this is a good battery to start with for a newbie like me, and will it fit in the cokpit of the Skyfun?
Motor im going to use: Turnigy2836 brushless Outrunner 2350kv
And Esc: Turningy Sentry 60amp Speed Controller
saufett is offline Find More Posts by saufett
Old Mar 13, 2011, 01:15 AM
cant leave things stock
jstoll's Avatar
USA, CA, Santa Cruz
Joined Feb 2007
no the 20C rating is really poor and you will puff the battery trying to make good power with it get something with a higher C rating
take care
JAK
jstoll is offline Find More Posts by jstoll
Old Mar 13, 2011, 03:15 AM
Joined Feb 2011
take care
JAK
Ok, but what is considered the minimun C rating for: 3s and 4s batteries then?
Also the dimensions in the battery picture in prev post....will it fit sizewise?
Old Mar 13, 2011, 03:31 AM
jstoll's Avatar
USA, CA, Santa Cruz
Joined Feb 2007
I dont know about the skyfun but Id go with a minimum 30C bat read up about batteries and what C rating is :-) its all here :-)
you just want to make sure you can pull enough amps to have fun with your skyfun
take care
JAK
Old Mar 13, 2011, 10:04 AM
Joined Feb 2011
It would be nice if you 4S users could post what C rating you are using
Old Mar 13, 2011, 05:37 PM
Joined Mar 2009
I used 40c 1800mah 4s, but 2200 would be better
Heck 45/90c nanotech would be awesome you can never have too much C rating, and they are all pretty cheap
Old Mar 13, 2011, 06:08 PM
Joined Jan 2009
sharp paint job, even if it is green and yellow
one thing that caught my eye, If that were mine, Id stick something in front of the battery to act as a stop.
if for some reason, failed esc or servos or whathave you occurs, that battery will destroy everything in its path, should the a collision cause everything to be forced forward. trust me. lol
inline300 is offline Find More Posts by inline300
Old Mar 15, 2011, 06:18 PM
Per Ardua ad Astra
Esprit 88's Avatar
London U.K.
Joined Jan 2005
[QUOTE=Mr RC;17657232]All complete,
Turnigy 85A BEC
Do you know how many amps this combination draws?
Esprit 88 is offline Find More Posts by Esprit 88
Old Mar 15, 2011, 06:26 PM
Joined Mar 2009
Made some changes to my motor mount so I can run the 36mm outrunner as an 'inboard' setup, which also allows the use of an inrunner later on. I used 50x50x3mm right angle aluminum screwed to 6mm ply with the carbon spars sandwiched between. Also cut the canopy down even more, glued it in and added a 3mm coro canopy/hatch and added a set of wipers over the finger holes. Makes it tricky to balance auw around 1280g, don't need ballast in the nose with the inboard motor.
Pix:
https://picasaweb.google.com/lh/phot...eat=directlink
There ain't nothing pretty about it
Old Mar 15, 2011, 07:23 PM
Ridgecrest Calif
Joined Nov 2010
Recommendations for an inexpensive HK motor that will work with the remaining RTF electronics? I would think the 25A ESC could run a bigger motor than the RTF, but I haven't found the RTF specs so I don't really know what I have.
Not looking for 100mph+ here...just a modest but worthwhile upgrade over stock.
WAM74 is offline Find More Posts by WAM74
Old Mar 15, 2011, 07:33 PM
Joined Mar 2009
You can't really go past a suppo style 2212 2200kv (aka 2826) but hk don't actually sell them or anything like it unfortunately. About 50g, pulls about 22-25a on 3s with 6x4e and good efficiency. Should take the skyfun to what it should be stock, which would be close to a stock stryker-c. $10 delivered from rctimer
Old Mar 15, 2011, 07:54 PM
Ridgecrest Calif
Joined Nov 2010
Thanx. So that would be this one?
http://www.rctimer.com/index.php?gOo...7&productname=
I note it calls for a 30A ESC. Is the SkyFun 25A up to the task?
All I've found on the original motor is it's 1800kv. I assume since it uses an 11V battery and 25A ESC, it might be about 200W. But from the complaints of lackluster performance, I wonder if it's really that high?
Discussion Vendo Rádio Hobby King 4ch + Receptor 6ch (2.4GHz) Amazon Brazil 0 Dec 02, 2009 07:52 AM
Discussion Hobby King 40mmx5mm folding spinners @ ~450 Watts? Owen Hedger Power Systems 3 Dec 01, 2009 02:46 PM
Discussion Hobby City/ Hobby King FPV setup- thoughts? Smokescreen38 Video Piloting (FPV/RPV) 6 Oct 23, 2009 04:27 AM
Discussion Hobby King Hobby City MIG 15 7car7 Foamy EDFs 5 Oct 15, 2009 06:43 PM
Question hobby king speed controller question? qtturner1 Power Systems 3 Jul 08, 2009 11:17 PM
