Old Jan 02, 2013, 11:38 AM
cjbucher is offline
Find More Posts by cjbucher
cjbucher's Avatar
Raleigh, NC
Joined Sep 2004
Not sure that vibration would cause that. It would have to be violent vibration like the plane literally shaking in your hand to cause control issues.
Sounds like maybe you were tail heavy or maybe pulling up before it had enough airflow over the control surfaces.
Ducted fans don't have the same amount of thrust as a prop does so your plane might have been struggling to get on step. If you pulled up even a little, it would have been stalling causing the wild out of control flight you had.
cjbucher is offline Find More Posts by cjbucher
Old Jan 03, 2013, 02:22 PM
ecworks is offline
Find More Posts by ecworks
Marshall Islands, Enewetak Atoll
Joined Sep 2011
FY-30a flashing light vibration issues with ducted fan
The problem is definitely vibrations. Put the Skyfun back together after the crash and performed a bench test. As I approached wide open throttle the red light flashed and then went solid and then the elevons started to go full left and right and then switch back again erratically. When I throttled down the elevons went back to their normal positions.
Then I installed the vibration system that comes with the FY-30 with no improvement.
Then I used some Zeal foam to isolate the FY-30 and now the red light only flashes intermittently during wide open throttle but the elevons do not behave badly anymore. Wonder if this means it is safe to fly?
In the manual it says if the red light is solid then the vibrations are too much but it doesn’t say what it means with the light is flashing.
Any observations about this?
ecworks
ecworks is offline Find More Posts by ecworks
Old Jan 03, 2013, 02:43 PM
TheCure is offline
Find More Posts by TheCure
Wats the worst that can happen
TheCure's Avatar
Canada, BC, Surrey
Joined Jan 2009
Maybe the solution is to minimize the vibrations, rather than treating the symptoms.
Are you running a quality motor with good bearings and low tolerances?
Is your propellor balanced well?
ecworks
TheCure is offline Find More Posts by TheCure
Old Jan 03, 2013, 07:13 PM
ecworks is offline
Joined Sep 2011
Eflight 80mm ducted fan. Quality stuff. Never balanced a ducted fan blade.
Old Jan 03, 2013, 09:12 PM
TheCure is offline
TheCure's Avatar
Canada, BC, Surrey
Joined Jan 2009
Sounds to me like you are experiencing high speed vibrations.
You should give dynamic balancing a try. There's at least a few threads around here on it.
What about including a (better) vibration dampening fan mount?
Old Jan 03, 2013, 09:36 PM
cjbucher is offline
cjbucher's Avatar
Raleigh, NC
Joined Sep 2004
Never heard of vibrations causing the elevons to glitch like that. Are you sure it's not a receiver issue? Maybe a receiver brown out issue caused by the BEC not keeping up the voltage under high load from the motor?
If it's not receiver brown out then maybe the vibration could be shaking the servo connections loose?
In any case high vibration is bad for the motor and plane. When motor/blades are vibrating a lot, the motor will actually draw more power which might be pushing the limits of your ESC and/or battery. Also it will eventually kill the motor bearings.
Old Jan 03, 2013, 11:46 PM
ecworks is offline
Joined Sep 2011
Using a Castle 10amp bec
Too late (for now) to dampen the EDF motor mount. Hot glued it in.
Managed to control the jitters by using Zeal padding in layers on top and bottom and then tuning down the gain on the FY-30. It flashes slowly but no eratic elevon movement so far.
Old Jan 04, 2013, 12:10 AM
Cathay Stray is offline
Find More Posts by Cathay Stray
Flying Zayin
Cathay Stray's Avatar
China, Guangdong, Guangzhou
Joined May 2012
Rubber o-rings work miracles when you put them between motor and motor mount.
Tested on more than one plane.
Cathay Stray is offline Find More Posts by Cathay Stray
Old Jan 04, 2013, 11:03 AM
ecworks is offline
Joined Sep 2011
Finally got the FY-30 to play nice with the Skyfun ducted fan.
Used a variation of the Milti-mod (see below) and lowering the gain on the FY-30.
Now it just blinks slowly when throttling up but no more erratic elevon movement.
Old Jan 04, 2013, 11:09 AM
ecworks is offline
Joined Sep 2011
Skyfun ducted fan project
Here are the pics. Remember the maiden flight lasted 5.5 seconds and ended badly because of the vibration problem with the FY-30a so it required a lot of plastic (styro) surgery. If this all works I'll probably get another Skyfun and transfer everything over clean. I'll likely cut in two rails on the back as motor mounts and attach the EDF with some sort of rubber o-rings or Zeal material to isolate it from the frame as much as possible.
Currently it weighs in (with a 2800 mah 4 cell batt) at 2lb 11 oz. Max thrust on the bench with the 4s is 2lb 8 oz.
The Eflight ducted fan is set up to run 4 to 6 cells. Should pickup another 1 1/2 lbs of thrust with the 6 cell batt.
2nd maiden flight (?) this weekend to see how it actually flies.
And yes, that is a slotted spoon protecting the 80 amp Eflight ESC.
Old Jan 04, 2013, 12:19 PM
soundguy63 is offline
Find More Posts by soundguy63
Joined Aug 2010
Looks like an interesting EDF mod! Where does your CG end up being in relation to the finger launching holes underneath the plane? That's a pretty heavy all-up-weight, my SkyFun is very light at about 20 oz. with a 1800 3S battery.
soundguy63 is offline Find More Posts by soundguy63
Old Jan 04, 2013, 12:43 PM
ecworks is offline
Joined Sep 2011
It ain't heavy, it's my Skyfun!
My other Skyfun (Twin motor/prop with landing gear) was heavier and flew great.
All of these planes I've been working on (Twin Raptor, Twin Skyfun, Tri Skyfun) have been proof of concept projects that do get heavy as I try out different things. I guess once I figure these ideas out I'll start from scratch with a new kit and transfer everything over clean and apply all the lessons learned, including weight saving strategies.
For the ducted fan Skyfun a friend and fellow flyer had this Eflight 80mm EDF laying around and loaned it to me to see what could be done with the Skyfun so I'm giving it a try.
Regarding CG, with the 2800 mah batt near the nose it balances out per normal using the finger holes.
Old Jan 04, 2013, 06:43 PM
ecworks is offline
Joined Sep 2011
Bench tested the Skyfun ducted fan project with a 6 cell (40c) and the Skyfun definitely gained some weight. It is now tipping the scales at 3 lbs 5 oz!
The ducted fan now produces 4 lbs 6oz of thrust with a significant weight penalty.
I think 5 cell will be the sweet spot weight vs thrust wise.
Old Jan 06, 2013, 06:23 PM
Joined Aug 2010
Very cool experimentation! How will you launch this EDF SkyFun? At least there is less risk to fingers with EDF, but will it need a catapult or landing gear?
Old Jan 08, 2013, 12:00 AM
ecworks is offline
Joined Sep 2011
2nd maiden flight yesterday if there is such a thing, 1st flight crashed within 5 seconds because the vibrations scared the FY-30a.
Yesterdays flights went fantastic. Pretty stiff wind (15 mph+) but the Skyfun always loves that. 1st flight flew with a 2800 mah 4 cell (30c) and as I've been hearing the EDF's lack a lot of static thrust when stationary so when it was thrown (a friend threw it for me) it seemed like it might stall but then the EDF started to get "on step" or "on the pipe" and then it gained speed quickly. Seemed to be going 70 -80 mph easily.
It was heavy (2lbs 8 oz) but flew great. Landings were even better. I usually turn in to land at a pretty high altitude and dive steeply with throttle off, flare, and then try to stay in ground effect and float along within a foot or two of the grass until the speed scrubs off. This worked perfectly with a heavy Skyfun and eventually it slowed enough to perform a final flare and then it plopped down and slid maybe 5 feet. A little grass in the EDF but it blew off with a couple blips of the throttle.
The 4000 mah 6 cell seemed too heavy (1.5 lbs by itself) so I'll wait and see what that feels like.
All in all I have to say that the Skyfun + EDF is a great combination. Side benefit: no worries about finger strikes or hitting the prop when landing.
I'll try to record the next flight and post later.
Discussion Vendo Rádio Hobby King 4ch + Receptor 6ch (2.4GHz) Amazon Brazil 0 Dec 02, 2009 07:52 AM
Discussion Hobby King 40mmx5mm folding spinners @ ~450 Watts? Owen Hedger Power Systems 3 Dec 01, 2009 02:46 PM
Discussion Hobby City/ Hobby King FPV setup- thoughts? Smokescreen38 FPV Talk 6 Oct 23, 2009 04:27 AM
Discussion Hobby King Hobby City MIG 15 7car7 Foamy EDFs 5 Oct 15, 2009 06:43 PM
Question hobby king speed controller question? qtturner1 Power Systems 3 Jul 08, 2009 11:17 PM
