Joined Sep 2012
I'm using a 5.5x4.5 sport prop and an NTM 2700kv 2836 motor on a 3S2200mah 45-90C nano-tech. From memory I think it pulled around 550W and around 45A.
Larger lipos have higher possible discharge rates, which theoretically means more amps/watts. Basically, if your lipo is limiting the power output in any way (which is more than possible on a small 2200), a larger lipo should give you more power. In the case of speed, more weight means better air penetration and inertia (i.e. speed coming out from a dive will be much greater than something very light). |
I think he just wants to see me hit the ground at 130mph !!! I need a few more flights with 3s and some more 90mph practice before I up my game- it is just a little different kind of flight from the Radian sailplane i love- but fast is fun too...and anyone that knows me just a bit- knows i am not afraid of a crash or two-or ten..
Des Moines IA
Joined Dec 2005
I would love to see a wattmeter of that for sure as your motor is running about 120% efficient.
I have run a few motors in my day and lets look at mine via a wattmeter. 4s1800 lipo 206 grams compared to almost 400 grams for a 3s1p3300. My MD 2505-2800 motor 2800kv runs at 14.6 volts under load at about 730 watts and 48amps. Running the same motor with 3s gives me 32amps at 11v and 350 watts. Not saying your figures are wrong but unless you run a wattmeter its just a guess. So if you look at voltsxkv there is a difference in rpm that translates to pitch speed |
Des Moines IA
Joined Dec 2005
Then when you become comfortable at that then start to increase the throws. |
Des Moines IA
Joined Dec 2005
http://www.hobbyking.com/hobbyking/s...00KV_595W.html
Hk specks tell somthing diffrent |
Joined Sep 2012
Regarding your lipo weights, I clearly stated a 22004s vs a 30003s. A turnigy nano 3300 3s is 357g and the equivalent 4S 2200 is 295g. That's less than a 20% difference. So a 3000mah 10% smaller than the 3300 would be roughly the same weight. |
Joined Sep 2012
Actually I don't even have to. The HK specs completely agree with what I said: the 5.5x4.5 prop is for all intents very similar to a 6x4 but faster RPM. HK specs for that are 6x4 - 11.1V / 520W / 46.8A / 1.2kg thrust, which is along the lines of what I stated initially. The current and wattage you draw at 3S is so much lower because you've obviously got a high-rpm prop that's not adapted to 3S. |
Des Moines IA
Joined Dec 2005
Please tell me what prop I should use then. please be specific. |
Joined Sep 2012
Well what prop are you currently using?
If ultimate speed is what you want you should stay 4S. If you want to use 3S you'll likely need a bigger prop to compensate for the lower voltage. And seriously? Pic over a vid? What, I would photoshop one to lie about the wattage? That has to be a troll. |
United States, SC, Greenville
Joined Jun 2011
![]() Quote:
Norm |
Joined Sep 2012
Mounted an Eflight 80mm ducted fan on my Skyfun, maidened it today. Crashed bad.
Cause: I think the FY30a. Too much vibration. After perfect launch it kept wanting to flip onto its back. Then it would flip back upright again, hold that position for a second then flip over again. Nosed into pavement. In the process of putting it back together. Any experience with vibration induced FY-30a problems? |
| Thread Tools | |
| Discussion Vendo Rádio Hobby King 4ch + Receptor 6ch (2.4GHz) | Amazon | Brazil | 0 | Dec 02, 2009 07:52 AM |
| Discussion Hobby King 40mmx5mm folding spinners @ ~450 Watts? | Owen Hedger | Power Systems | 3 | Dec 01, 2009 02:46 PM |
| Discussion Hobby City/ Hobby King FPV setup- thoughts? | Smokescreen38 | Video Piloting (FPV/RPV) | 6 | Oct 23, 2009 04:27 AM |
| Discussion Hobby King Hobby City MIG 15 | 7car7 | Foamy EDFs | 5 | Oct 15, 2009 06:43 PM |
| Question hobby king speed controller question? | qtturner1 | Power Systems | 3 | Jul 08, 2009 11:17 PM |
