Old Nov 06, 2012, 04:45 PM
Rich in ILM is offline
Find More Posts by Rich in ILM
Retired in NC
Rich in ILM's Avatar
USA, NC, Wilmington
Joined Sep 2010
Originally Posted by Znybar View Post
I just used plastic flat hinges because they'd be easier to mount into the balsa than other hinge types, and I don't trust hinge tape for faster models.
I've always thought just the opposite. 3M Blenderm is great stuff. It provides a continous bond so the load is spread over the entire area. It, also, completely seals the crack between the control suface and main body. Not sure who is correct on the right solution. Just my experience.
Rich in ILM is offline Find More Posts by Rich in ILM
Old Nov 06, 2012, 07:27 PM
Znybar is offline
Find More Posts by Znybar
Joined Sep 2012
The issue with tape is that it's flexible. Hinges give a more stable pivot point, and if you make them correctly I don't think you lose out on control surface separation. That said, each his own. In my experience tape hasn't worked well, and may have been exacerbated by the hot weather in OZ that makes adhesives not stick so well!
Znybar is offline Find More Posts by Znybar
Old Nov 06, 2012, 09:11 PM
Retired in NC
USA, NC, Wilmington
Joined Sep 2010
It also may be that you haven't had access to 3M Blenderm hinge tape? It's awfully good.
Old Nov 06, 2012, 09:16 PM
Znybar is offline
Joined Sep 2012
I've only ever used 3M tape for my planes because its the toughest/stickiest stuff, but I avoid using it for hinges. Call it habit? I like the mechanical function of proper hinges, they inspire more confidence for me than tape (especially when the stock tape hinges proved problematic for me).
Old Nov 06, 2012, 09:20 PM
Retired in NC
USA, NC, Wilmington
Joined Sep 2010
I am speaking of Blenderm. It's a totally different tape from regular 3M. It's available from their medical supply business.
Old Nov 06, 2012, 10:19 PM
Znybar is offline
Joined Sep 2012
Well in that case hinges are simply easier to get a hand on, I can just get them at my LHS. Not sure you'd be able to get 3M's medical supplies down here in OZ.
Old Nov 14, 2012, 02:34 PM
timtimtim is offline
Find More Posts by timtimtim
Joined Apr 2012
what glue do you guys use? will ca foam safe do the work?
timtimtim is offline Find More Posts by timtimtim
Old Nov 14, 2012, 06:46 PM
WitnessOnly is offline
Find More Posts by WitnessOnly
Cleared for take off...
WitnessOnly's Avatar
Australia, VIC, Melbourne
Joined Jan 2010
Hot glue or epoxy, I find CA is too brittle
WitnessOnly is offline Find More Posts by WitnessOnly
Old Nov 14, 2012, 06:52 PM
Retired in NC
USA, NC, Wilmington
Joined Sep 2010
I have had very good luck with hot glue. You need a fair amount of flexibility when working with foam.
Old Nov 14, 2012, 07:27 PM
eckace1 is offline
Find More Posts by eckace1
OFF TOPIC POSTER
Des Moines IA
Joined Dec 2005
My friend and I just mounted a MD 2505-2800 on his bird and man was it fast.
Unlimited vertical and guessing around 100mph.
I tried to vid the maiden flight I hope he will post it soon.
eckace1 is offline Find More Posts by eckace1
THESANDMAN is offline
Find More Posts by THESANDMAN
THESANDMAN's Avatar
United States, NY, New York
Joined Oct 2010
i just started to use Foam Tac . that glue is amazing you need to do a search as see some of the results of pilots using this glue.
before i used foam tac i used to use gorilla glue . that is the storngest bond ive seen on foam . . i learned the hard way not to use hot glue . . that stuff gets soft in hot weather. and i only use epoxy on motor mounts for scratch built planes .
THESANDMAN is offline Find More Posts by THESANDMAN
Old Nov 14, 2012, 08:12 PM
Joined Apr 2012
Can i use the 5 min a+b glue that comes with the kit version of skyfun? Or this? Also whats the difference between the minutes?
Old Nov 14, 2012, 09:09 PM
THESANDMAN's Avatar
Joined Oct 2010
the longer it take the epoxy to cure the stronger it is, so basically 30min epoxy has a stronger bond than a 5min epoxy , the reason alot of people perfer the 5min epoxy is cause they dont want to wait that long for a bond .
that glue they supply you with in the plane is pure garbage . i lost a plane because of that glue when i first got into rc planes . keep in mind the low price you save on the plane comes from them putting cheap stuff along with the plane. just my opinion.
Old Nov 14, 2012, 09:20 PM
Joined Apr 2012
Thats what i was thinking too... So in your opinion should I go for the 6 or 30 min epoxy? I will add cf rods to the fuselage later
Old Nov 14, 2012, 10:16 PM
scottdearinger is offline
Find More Posts by scottdearinger
Gravity? No, the Earth sucks
scottdearinger's Avatar
United States, IA, Des Moines
Joined Apr 2011
ok ok i will get to editing and posting soon... But let me say this- that was the fastest thing I have ever flown times 2... man oh man ... cant wait to stick a cam or two on it this weekend.. yes you have hooked me on speed now- although- I am not sure I want to go any faster- that damn plane was fast fast fast... i think 30 seconds would take it way out of range? lets see 100mph = 1.66 miles per minute- nope I guess it wouldn't be out of range- just too far too see well
The plane actually accelerated while climbing 90 degrees vertical faster than it used to do in a dive with stock motor-- It seemed I was flying an Estes rocket...I like this little jet..
scottdearinger is offline Find More Posts by scottdearinger
Discussion Vendo Rádio Hobby King 4ch + Receptor 6ch (2.4GHz) Amazon Brazil 0 Dec 02, 2009 08:52 AM
Discussion Hobby King 40mmx5mm folding spinners @ ~450 Watts? Owen Hedger Power Systems 3 Dec 01, 2009 03:46 PM
Discussion Hobby City/ Hobby King FPV setup- thoughts? Smokescreen38 FPV Talk 6 Oct 23, 2009 05:27 AM
Discussion Hobby King Hobby City MIG 15 7car7 Foamy EDFs 5 Oct 15, 2009 07:43 PM
Question hobby king speed controller question? qtturner1 Power Systems 3 Jul 09, 2009 12:17 AM
