Old Jul 20, 2012, 12:56 PM
malden86 is offline
Find More Posts by malden86
malden86's Avatar
San Antonio, TX.
Joined Feb 2009
Thank for the reply Rich.
malden86 is offline Find More Posts by malden86
Old Jul 27, 2012, 01:34 AM
KF6BBL is online now
Find More Posts by KF6BBL
Techenstein
La Mesa, CA
Joined Mar 2010
Hello my Skyfun friends,
I'm reposting this since I found the wrong thread before..
Hello people!
I didn't see a better thread to discuss the HK Skyfun Jet, and it looks like it was previously discussed in this thread. I figured I would share my setup and ask a question.
So I've got a few upgrades on my Skyfun as you can see in the pix.
Power:
Turnigy 2836 2350KV outrunner
6x4e APC pusher prop
Turnigy Sentry 60A ESC
Up to recently I've run a 3S2000, but now I'm running 4S2350 and 4S2800
Airframe:
Added carbon tube spars, each about 10", all gorilla glued in when I assembled the wings.
Balsa Elevons
Top mounted the servos and control horns
Hitec 65MG karbonite servos
Fixed landing gear - based on some eflite wheels and bent wire. I think the steerable nose wheel was a dubro kit or something.
Motor mount reinforced with a belly panel about 5" long. The actual metal mount on the top was drilled and tapped to accept #6-32 machine thread. The bottom panel is epoxied down giving a solid motor attachement.
Various other wood seen in the photos are more or less braces added after crashes to hold it all together.
Canopy is held on by a small dowel in the front, plus four magnets. None of the original plastic clips worked out of the box.
So with the 3S, I had measured by doppler about 80MPH. Last weekend I ran the 4S and borrowed a GPS logger, and got it up to 120MPH, although that includes slight dives.
One of my questions I've always had with this thing is where should CG be? Following the factory guidlines, the thing flew but was unstable, and lead to spins and high speed stalls. Now I have the CG pretty far forward. Currently I run it 2.5" back along the seam of wing and fuselage. That is about 1" in front of the root of the vertical stab. The way it flies now is a lot more manageable, but I always feel like I should be getting more elevon authority from it.
Anyhow, that's the rig. I'll have to get some video together for it soon.
KF6BBL is online now Find More Posts by KF6BBL
Old Jul 27, 2012, 07:52 AM
idletime is offline
Find More Posts by idletime
idletime's Avatar
Canada, ON, Toronto
Joined Apr 2011
Well I'm super confused now about the Proper CG - which (if I'm not mistaken is supposed to be at the front of the finger holes).
But there is no way you that can happen if you mount the battery like kf6bbl has done (photo in above post) - way up at the front of the cockpit.
My battery would have to be placed directly in front of the ESC in his photo above - which barely fits as the canopy has no clearance at the back.
Where are other running the CG?
idletime is offline Find More Posts by idletime
Old Jul 27, 2012, 07:53 AM
m_ark is offline
Find More Posts by m_ark
Gravity sucks.
Australia, QLD, Toowoomba
Joined Mar 2011
Hello people!
Power:
Airframe:
Balsa Elevons
cg is located in the forward end of the finger holes - i put landing gear like you've pictured on mine, but couldn't get it off the ground because my back wheels were too far behind the CG - meaning the plane couldn't rotate for takeoff - so, try moving those back wheels forward (to just behind the finger grips), and balancing the CG at the finger grips underneath. - your configuration looks like it may work better if you swap the location of the battery with the front wheel/steering combination.
m_ark is offline Find More Posts by m_ark
Old Jul 27, 2012, 09:19 AM
IFlyRCs is offline
Find More Posts by IFlyRCs
ICrashRCs
United States, TN, Memphis
Joined Jun 2011
I would say you're running a light motor?
Or the battery is too large...
Do what you have to do to balance torward the front of the finger holes.
The battery should be pretty far forward.
IFlyRCs is offline Find More Posts by IFlyRCs
Old Jul 28, 2012, 11:46 PM
Fox-composites is offline
Find More Posts by Fox-composites
Thailand
Joined Aug 2010
I am amazed that the manufacturers of many Chinese models go to all the effort and expense of making the moulds and then give little or no information on CG, surface throws etc etc. It makes me wonder if they ever get flight tested at all?
I have never had one so I am only commenting from observing the many SkyFun models at our flying field.
This is a very long running thread but is that because the model is so bad or so good? It seems to need endless modifications.
Jim
Fox-composites is offline Find More Posts by Fox-composites
Old Jul 28, 2012, 11:58 PM
idletime is offline
idletime's Avatar
Canada, ON, Toronto
Joined Apr 2011
Jim
Skyfun flies fantastically (IMHO) once you get the CG right.
I moved up from (1) 3S_2200 to (2) 3S_2200 in parallel at first because my older batteries could not provide enough juice - then I switched to 4S_2200 which is a much heavier battery. Flew it once and never seemed to get the CG right after that. Crashed on takeoff the next two times and is kinda totaled.
Deciding if to try to rebuild or order another one. Or build one from scratch like the Prime Jet8
Old Jul 29, 2012, 01:00 AM
IFlyRCs is offline
ICrashRCs
Joined Jun 2011
You should have just gotten a better 3s or an 1800 4s.
To me that's a happy weight for this airframe in a rather go-fast config.
It also flys nicely on 1000 mah with a slower/lighter motor.
Old Aug 06, 2012, 02:27 AM
mgbolts is offline
Find More Posts by mgbolts
Joined Apr 2012
Motor Mount
Hi There.
I am looking to upgrade by Skyfun specs again. Using a HK 2836 3700 with 6x4 running at around 800W. Sensational fun but needs strong servos. Upgraded to a high C battery (3S) which made a big difference.
http://www.rcgroups.com/forums/showp...&postcount=786
Anyway, seems about the time to push the envelope again. I have a Turnigy H3126 Brushless outrunner 1300KV (1500W) with 6S to install.
http://www.hobbyking.com/hobbyking/s...dProduct=11182
I dont really want to custom build a motor mount. Does anyone know of an off the shelf large motor mount that might work?
Cheers
mgbolts is offline Find More Posts by mgbolts
Old Aug 06, 2012, 04:26 PM
IFlyRCs is offline
ICrashRCs
Joined Jun 2011
I think it was in this thread a few pages back someone had put ply on the bottom and screwed through into the motor mount. That would add a lot of support.
Don't know of a commercial mount available.
Old Aug 06, 2012, 08:11 PM
Kennyglide is offline
Find More Posts by Kennyglide
Southern Darling Downs Qld, Australia
Joined Sep 2010
Perfect Skyfun 2836 Set Up.......3648 Mount Wanted,
Hi , i have had a Skyfun running Turnigy 2836, 2350 kv,60amp plush, 6x4 prop , 4s 40c 2200 mah lipo. and it seems to be the perfect set up ( i have strenghtened a few things) flys beautifully. The performance is almost the same as my Stryker Q so i have decided to fit the Skyfun with a Turnigy 3648 ,1400kv 1600w motor and 6s lipo.and bigger esc. just to see what happens I was wondering if anyone could suggest a suitable mounting for this motor ... is there a suitable after market universal mount available ? Cheers Ken
Kennyglide is offline Find More Posts by Kennyglide
Old Aug 07, 2012, 05:21 AM
mgbolts is offline
Joined Apr 2012
Motor Mount
I have used this one on my skyfun but its to small for the new motor.
http://www.hobbyking.com/hobbyking/s...43_42mm_.htmlo
Old Aug 16, 2012, 03:12 PM
SilentStatic is offline
Find More Posts by SilentStatic
The Netherlands, DR, Erica
Joined May 2012
Hi Guys i thought i jump in and tell you my current specs of the skyfun! After owning it for 2 years(first one which never crashed) ive had 4 upgrades.
After starting with a turnigy on 3s i quikly moved to 4s with a little larger motor.
Then a little bigger 3200kv motor on 4s.
And finally ik running a turnigy fandrive on 6s with a 200 amp esc, and its a beast!
Hitting 300km/h, it screams like a cat in heat!
Also ive got more then 3 meters of led lights for nightflying!(havent done that on 6s tho)
Im using small but very powerfull digital metalgeared servo's from hobbyking which have never let me down!
I always got my cg right in front of the 2 holes, (so not in them) and its always spot on
I love the plane and thinking of downgrading now to use it for fpv!
SilentStatic is offline Find More Posts by SilentStatic
Old Aug 16, 2012, 03:34 PM
TheCure is offline
Find More Posts by TheCure
Wats the worst that can happen
TheCure's Avatar
Canada, BC, Surrey
Joined Jan 2009
How do you launch your 300km/h Skyfun?
TheCure is offline Find More Posts by TheCure
Old Aug 17, 2012, 09:08 AM
3d astronaut is offline
Find More Posts by 3d astronaut
3d astronaut's Avatar
United States, MI, Kalamazoo
Joined Sep 2011
Man every time I check this thread I get upset that I ever sold my skyfun the mods and the creativity in here is just awesome. I think I might have to order another one of these as my "funfighters" have brought that speed twitch back
3d astronaut is offline Find More Posts by 3d astronaut
Discussion Vendo Rádio Hobby King 4ch + Receptor 6ch (2.4GHz) Amazon Brazil 0 Dec 02, 2009 07:52 AM
Discussion Hobby King 40mmx5mm folding spinners @ ~450 Watts? Owen Hedger Power Systems 3 Dec 01, 2009 02:46 PM
Discussion Hobby City/ Hobby King FPV setup- thoughts? Smokescreen38 FPV Talk 6 Oct 23, 2009 04:27 AM
Discussion Hobby King Hobby City MIG 15 7car7 Foamy EDFs 5 Oct 15, 2009 06:43 PM
Question hobby king speed controller question? qtturner1 Power Systems 3 Jul 08, 2009 11:17 PM
