Old Aug 05, 2010, 02:37 PM
NinetySix is offline
Find More Posts by NinetySix
Melbourne, Australia
Joined Mar 2009
oops
NinetySix is offline Find More Posts by NinetySix
Old Aug 05, 2010, 02:40 PM
Joined Mar 2009
Originally Posted by Batch1 View Post
In the tech note : They are "tractor" (not "pusher") props.
Isn't more efficient to use a pusher prop ?
Do you know where I can buy a 6X4 pusher prop like the original one. I only have around 200W power
There is no difference, as long as the prop is facing the right way and spinning the right way then it will do its job. A 6x4E might do a better job at that power level... but then it might not
Old Aug 06, 2010, 04:46 AM
Joined Mar 2009
Originally Posted by Patrick_W View Post
What would be a nice fast 3s setup for this plane? I know that I could get a 2826-2350 and run it on 4s like some others have, but all my battery chargers only go up to 3s and I'm too cheap to buy a new one!
oops sorry see this thread. 3S 2836-3200 and 6x4 works great, 100mph+ but make sure your esc and lipo can do 60A+
Old Aug 16, 2010, 05:36 PM
Batch1 is offline
Find More Posts by Batch1
Canada, Quebec, Mercier
Joined Dec 2008
I made some test with this motor : http://www.hobbycity.com/hobbycity/s...idProduct=2110
Measurement taken with a WATT'S UP meter
Original prop. 14A 11V 154W
6X4 prop 12.85A 11.15V 144W
6X5 prop 13.16A 11.1V 146W
Original motor with original prop
Pusher 7.28A 11.23V 82W
The letters on the prop are facing the nose of the plane and motor turn CW view from the rear of the plane . On original prop number 2 is facing back
Batch1 is offline Find More Posts by Batch1
Old Oct 04, 2010, 04:41 AM
ed_khan is offline
Find More Posts by ed_khan
ed_khan's Avatar
USA, WA, Bellevue
Joined Dec 2002
Hi guys.
Do you think this plane needs further structural reinforcements? for higher speeds. And should it be glassed? I see that there is a groove underneath the wing, is it for a carbon spar?
What is the fastest equipment (motor, prop, Lipos) you got
ed_khan is offline Find More Posts by ed_khan
Old Oct 13, 2010, 10:15 AM
aaron_gx is offline
Find More Posts by aaron_gx
Flying FPV from the lab.
aaron_gx's Avatar
Canada, AB, Lethbridge
Joined Jun 2008
Here is my skyfun in action:
Playing Chicken with a Wind Turbine FPV (2 min 37 sec)
The Best... Revision B (4 min 58 sec)
This is an FPV plane, completely piloted through video goggles.
Personally, and with the amount of times i've crashed/landed rough and otherwise just ratbagged this plane, I dont think any structural improvements are needed. Replace the motor mount. Replace the wing servos, motor and esc. I've been flying this setup for over a year. It has been one of the most reliable fun planes I've ever had.
aaron_gx is offline Find More Posts by aaron_gx
Old Oct 14, 2010, 12:24 AM
mark hitchman is offline
Find More Posts by mark hitchman
Zephyr 66" Blunt
mark hitchman's Avatar
New Zealand
Joined Sep 2009
What motor and prop and battery? How long a flight time are you getting? I just changed my 2200 mah for a 5000 mah and want to get long flight times, I use a 9 X 4.5 so I want suggestions on how to prop it. The motor is a turnigy 35-30-1700.
Mark
mark hitchman is offline Find More Posts by mark hitchman
Old Oct 14, 2010, 09:57 AM
aaron_gx is offline
aaron_gx's Avatar
Joined Jun 2008
originally setup with a 2826-6 2200kv motor from ebay, 11.1 2450mah 35c lipo and 6x5e prop. Now I've changed things around a bit. I run a 3000mah 7.4c 35c lipo, same 2826-6 2200kv and 8x6APC prop. Same thrust, a bit less speed, but wayyyy more efficient. I can come in from a full throttle run, with motor and esc barely warm. This allows me to carry a 11.1v 1000mah battery to power my video gear separately from motor battery. Less video noise this way.
Old Dec 29, 2010, 09:28 PM
Joined Mar 2009
I guess this is the skyfun thread so I'll post here...
What kind of AUW is everybody getting with their skyfuns? I dusted mine off for some windy slope flying... and the bare airframe with coro elevons, hxt900's, 3mm carbon in the wing grooves, Rx and no engine mount all comes to 400g / 14oz. plan to run rhino 1250 3s 30c, 30a esc, ubec, rctimer 2826-6 and 6x4 sport and all that is another 260g / 9oz.
I used hot glue on the elevons and servos but otherwise it seems a lot heavier than a stryker. I know its a skyartec not a parkzone but does that sound right?
Old Dec 30, 2010, 01:48 AM
ed_khan is offline
ed_khan's Avatar
USA, WA, Bellevue
Joined Dec 2002
my "project" :D
I have this come in from HK few weeks ago. and am working on this project. reading Funjet thread as well.
1. How is this plane different as compared to Funjet?
2. I plan to fly it stock first, but also following these threads for any improvements.
3. Question: If i do move to 2836 with 4.5x4.5 prop; would i need a bungee to launch, also is it a good move?
So far I love the videos that you guys have posted. Can you describe your video setup as well. thanx!
Old Dec 30, 2010, 02:26 AM
Joined Mar 2009
1. It's nothing like a multiplex funjet, but a lot like a parkzone stryker.
3. Definitely need a bungee on a 4.5" prop, not enough thrust! Use at least a 6x4 prop for the skyfun... 7" props even better. for 6x4, 2836-3200 for 3s or 2836-2350 for 4s. 100mph+
Old Dec 30, 2010, 01:56 PM
aaron_gx is offline
aaron_gx's Avatar
Joined Jun 2008
Here is information about my skyfun, power setup and camera setup.
http://www.rcgroups.com/forums/showt...1240968&page=3
Old Jan 06, 2011, 01:37 AM
Joined Mar 2009
Well I got bored of the RCtimer 2826-6... so I went a little silly on the skyfun today!
Going to run a 36mm outrunner, turnigy H3126. Have 1300kv & 1600kv to try, with either 4S 3600 40C or 6S 2200 40C and 6.5x5.0, 6.5x6.0, 6.5x6.5 pylon, 7x6, 7x7, 7x8 sport props... Im sure there will be a few good combos in there.
6mm round cf tube from nose to tail, 4mm round cf tube in the leading edges, 6mm square cf across the wingspan, and 6mm square cf in the trailing edges. Couple 4mm tubes across the battery compartment too, and 4mm round tube in the verts - might switch to wood verts though.
Used CA glue to hold all the CF together, and I'm making a ghetto engine mount from 6mm plywood with the trailing edge CF and span CF all linked to it.
Its solid as a rock just need to sort out some elevons. hxt900's will be swapped with turnigy 15gram metal gear servos. Will hit the bottom and verts with finishing epoxy for a little extra strength
Old Jan 14, 2011, 05:08 PM
oly_rcer is offline
Find More Posts by oly_rcer
what ya mean i have to land?
DesMoines,Wa
Joined Feb 2008
thats an awful low kv motor to use,prop would be a prob,need something in at least 2200+ range like the 2836-3200 with a 5.5 prop or the 2836 2250 with a 6x4 sport(not e) prop.if you want to go really fast try a mega 16/15/3 or 16/15/2 they are kinda pricey but run well when propped right.i have a mega 22/30/2 going in a stryker i hope to see 140+ out of.i'm told it should do it,also you need a good esc for speed,i have a 200a in mine also lots of carbon rods from wing tip to wing tip for support.the faster you go the more work the frame needs
oly_rcer is offline Find More Posts by oly_rcer
Old Jan 14, 2011, 05:25 PM
Joined Mar 2009
I'm gonna try the 1600kv motor (which might be 1700kv+ knowing turnigy) on 6s with 6.5x5.0 ... haven't spun it like this yet but that could easily pull around 1600w, which is about the limit for my whole power system. If not - prop up!
Almost ready for a testflight, but can't find any good balsa for elevons! not at huge hardware stores, LHS etc...its all too soft, not much better than foam or 3mm ply... might just use some oak or something real hard... hmmm, alum?
Discussion Vendo Rádio Hobby King 4ch + Receptor 6ch (2.4GHz) Amazon Brazil 0 Dec 02, 2009 07:52 AM
Discussion Hobby King 40mmx5mm folding spinners @ ~450 Watts? Owen Hedger Power Systems 3 Dec 01, 2009 02:46 PM
Discussion Hobby City/ Hobby King FPV setup- thoughts? Smokescreen38 FPV Talk 6 Oct 23, 2009 04:27 AM
Discussion Hobby King Hobby City MIG 15 7car7 Foamy EDFs 5 Oct 15, 2009 06:43 PM
Question hobby king speed controller question? qtturner1 Power Systems 3 Jul 08, 2009 11:17 PM
