Old Nov 24, 2011, 12:37 AM
Rich in ILM is offline
Find More Posts by Rich in ILM
Retired in NC
Rich in ILM's Avatar
USA, NC, Wilmington
Joined Sep 2010
Originally Posted by wizzard363 View Post
Does anyone have the programing info for the stock esc ? I want to get rid of that stupid music it plays .
No way will I power up this model at a flying field playing that tune.
I have a turnigy trust card but I dont think that will work with this esc
The Turnigy Trust Card is the correct programming card for the ESC,
Rich in ILM is offline Find More Posts by Rich in ILM
Old Nov 24, 2011, 12:54 AM
IFlyRCs is offline
Find More Posts by IFlyRCs
ICrashRCs
United States, TN, Memphis
Joined Jun 2011
There is a SkyArtec card too. I have one I used for the music on my Cessna.
You can Google search skyartec esc programming card
IFlyRCs is offline Find More Posts by IFlyRCs
Old Nov 26, 2011, 06:14 AM
wizzard363 is offline
Find More Posts by wizzard363
flying or crashing into air?
wizzard363's Avatar
Australia, VIC, Langwarrin
Joined Feb 2011
Build finished
A couple of pics of the finished model.
Got to say there were a few changes made.
Replaced the servos with HXT900's and mounted them on top of the wing.
One of the stock clevises broke so I replaced the control rods with larger ones of 1.8mm and fitted larger clevises.
Swapped the stock motor for the 2200Kv 2212-6.
I removed the hinge tape on the elevons and replaced that with plastic hinges , 10 on each side . There might be better ways of hinging but this is what I had in my spares box
http://www.hobbyking.com/hobbyking/s..._5_10pcs_.html
I used a length of 2mm CF rod to stiffen the elevons
Gave the underside a high vis paint job.
I added a few extra magnets to the back of the canopy . In the front I glued a plastic hook as far forward inside the fuselage as I could and then glued a 45mm long piece of CF rod inside the front of the canopy so only about 10mm
sticks out so I can use a rubber band to hold down the front of the canopy.
The angle the rubber band is at pulls the canopy forward as well as down , it acts like a spring loaded hinge and if you lift up the back of the canopy it will spring down when let go.
I have not flight tested this yet but I think it should keep the canopy in place very well.
This is an awesome looking plane and I cant wait for the maiden
wizzard363 is offline Find More Posts by wizzard363
Old Dec 03, 2011, 02:43 AM
Ken_Jungles is offline
Find More Posts by Ken_Jungles
Ken_Jungles's Avatar
Australia, ACT, Canberra
Joined Aug 2011
Nice visible paintjob. They get small real fast.
Here's what I did with my replacement after a couple of successful flights:
Ken_Jungles is offline Find More Posts by Ken_Jungles
Old Dec 07, 2011, 08:59 AM
Banjofrog is offline
Find More Posts by Banjofrog
Geez That's A Big Fly
Banjofrog's Avatar
Australia, WA, Parkerville
Joined Sep 2011
Hi Guys,
I maidened my Skyfun two weekends ago, I did not use a stock set up to start with I had a 2825-1950kv motor here with a 30amp Plush esc and 2200mah 40c 3s and 6x4 APC prop (very flyable ,good to learn with), Performance was ok and it let me sort out the CG and trim with out any hassles.
Power was measured with "watts up" static 291w and 19amp @wot.
Now for the upgrade I got a 2836-2350 with HK60amp esc (sweet bronze looking one) and APC 6x4E static measured is 3s 2200mah Turnigy 40c battery, 488w 40.8 amp @WOT runs cool
4s 2200mah Turnigy Battery APC 6x4E 890w 60.2amp static @WOT did not check temp due to amp draw.
Does these figures sound right?
Also the motor hesitates and grounches as you start to open the throttle for a milli second then sings away very happy with no problems is there a problem?
I am looking forward to testing this weekend
Shaun.
Banjofrog is offline Find More Posts by Banjofrog
Old Dec 07, 2011, 09:49 AM
IFlyRCs is offline
ICrashRCs
Joined Jun 2011
Maidened my 2nd SkyFun in full stock ARF form. Had a beginner with me and wanted him to see how it flew out of the box.
He wants one ;o)
It's a very capable flyer stock, which I doubted it would be.
Running 1000mah 3s it flies great. Plenty of flight time.
After 2 batts I really craved a bit more power.
I'm going to match it up with my 2836 3200 Stryker and do a head to head comparison.
Anxious to see how that turns out.
The SkyFun is fun and crisp and floaty. Like it a lot.
Old Dec 07, 2011, 08:05 PM
AndyInKent is offline
Find More Posts by AndyInKent
AndyInKent's Avatar
United Kingdom, England, Royal Tunbridge Wells
Joined Mar 2011
Hi again all
Update on my "flying brick" of a modified skyfun, I am getting 144mph/231kph(ish) with the current setup
ASBO RC PLANE. (3 min 59 sec)
Build pics etc @ www.rcgroups.com/forums/showthread.php?t=1416163
AndyInKent is offline Find More Posts by AndyInKent
Old Dec 12, 2011, 06:47 PM
K.Jones is offline
Find More Posts by K.Jones
United States, MO, Maryland Heights
Joined Oct 2010
Looking for ideas to add ventilation to the cockpit. I read it can cause the canopy
to come off in flight. I'm using rare earth magnets on my canopy. Thanks for any input.
K.Jones is offline Find More Posts by K.Jones
Old Dec 12, 2011, 10:07 PM
andrewp7 is offline
Find More Posts by andrewp7
I tell her that RC is cheap
andrewp7's Avatar
Australia, New South Wales, Hurlstone Park
Joined Mar 2011
Originally Posted by AndyInKent View Post
Hi again all
Thats proper rapid.
Love it.
andrewp7 is offline Find More Posts by andrewp7
Old Dec 15, 2011, 02:48 AM
graeme_robinson is offline
Find More Posts by graeme_robinson
Australia, New South Wales, Sydney
Joined Jan 2011
Originally Posted by Atx_Heli View Post
my only issue is that when I sign up for email notice for backordered arrival items, I can never cancel the notices....they expire on the fourth restock, but its maddening and they haven't been able to help me....they don't show in my account where they are supposed to...no biggie however...
click on wishlist from your account page - there's a checkbox to enable or disable email notifications for each item in your wishlist.
graeme_robinson is offline Find More Posts by graeme_robinson
Old Dec 15, 2011, 03:14 AM
IFlyRCs is offline
ICrashRCs
Joined Jun 2011
But it's not wish list items.
It's out of stock items where you drop in your email on the product page to receive in stock notices.
I don't know of a way to stop them either but he says it stops after the 4th restock.
Old Dec 15, 2011, 07:36 AM
Atx_Heli is offline
Find More Posts by Atx_Heli
Austin, TX
Joined Jan 2009
Its maddening to me also....it USED to show up in account settings under EMAIL notifications...that stopped about a year ago....just have to put up with the repeating notices...HobbyKing is no help...they say look in your account under email notices and disable the individual notices...but they don't appear there any more...
Atx_Heli is offline Find More Posts by Atx_Heli
Old Dec 19, 2011, 06:45 PM
wizzard363's Avatar
Joined Feb 2011
Maidened mine this morning and it flys great .
A lot easier than I thought it was going to be , it just seems to float around the sky .
Did a couple of circuits on the maiden just to get the feel of it then had a bit more of a play on the second flight .
The third flight was ended after I got a bit casual with my launch and the prop hit my finger , a couple of cuts but not too bad.
I will launch this by holding the wing from now on and not use the finger holes under the fuse.
After flying the AXN clouds fly for a few weeks I found it easy to fly the Skyfun and it could now be my favorite of the two (even though it bit me )
Old Dec 20, 2011, 03:42 AM
WitnessOnly is offline
Find More Posts by WitnessOnly
Cleared for take off...
WitnessOnly's Avatar
Australia, VIC, Melbourne
Joined Jan 2010
Nice work Wizard, now there's no going back
Sounds like I should make sure to pack mine next time
WitnessOnly is offline Find More Posts by WitnessOnly
Old Dec 20, 2011, 03:48 PM
wizzard363's Avatar
Joined Feb 2011
Yours is faster than mine lol
Discussion Vendo Rádio Hobby King 4ch + Receptor 6ch (2.4GHz) Amazon Brazil 0 Dec 02, 2009 07:52 AM
Discussion Hobby King 40mmx5mm folding spinners @ ~450 Watts? Owen Hedger Power Systems 3 Dec 01, 2009 02:46 PM
Discussion Hobby City/ Hobby King FPV setup- thoughts? Smokescreen38 FPV Talk 6 Oct 23, 2009 04:27 AM
Discussion Hobby King Hobby City MIG 15 7car7 Foamy EDFs 5 Oct 15, 2009 06:43 PM
Question hobby king speed controller question? qtturner1 Power Systems 3 Jul 08, 2009 11:17 PM
