Old Apr 23, 2010, 12:00 AM
jcaywood is offline
Find More Posts by jcaywood
United States, NY, Saugerties
Joined Jun 2005
Hi Nico, thanks for the posts and videos (and replying to video comments). I love this plane so far as a cheap foamy. I ordered two because I knew I would destroy one of them in some unfortunate overpowering incident.
The launcher is a great tip and modified concept. I've seen rail launchers for high speed turbines, but obviously such an expensive setup isn't required for these
jcaywood is offline Find More Posts by jcaywood
Old Apr 29, 2010, 07:10 AM
NinetySix is offline
Find More Posts by NinetySix
Melbourne, Australia
Joined Mar 2009
Received my skyfun on the weekend (gottta love EMS, they deliver on sundays!) and tore out all the stock electrics.... put in HXT900's, turnigy plush 40A esc, turnigy 2826-2350 (2800kv) motor and turnigy 4s 1800mah 40c lipos.
Started out with a 4.75x4.25E apc prop, and once I got the CoG right she flew very nicely. Controls were way too sensitive, giving it full elevator would stall it straight to the ground in a flat spin.... actually have to point the nose down to save it! The control surfaces are on minimum throw and I've had to set the end points to 75% and 50% expo and its a lot better.... still gotta be careful not to stall it though!
Now I've got a 5.5x4.5E apc prop on, drawing 52A/790W... Very fast! Can't believe how well she glides either, better than my AXN floaterjet... and its a glider!
AUW is 750g/26.5oz
NinetySix is offline Find More Posts by NinetySix
Old Apr 30, 2010, 03:35 AM
Joined Mar 2009
Repost of my test data from todays flight as posted in the stryker turnigy 28xx motor thread.
Originally Posted by NinetySix View Post
drivecalc stats for 2350kv with 5.5x4.5 are:
52A, 789w, 1510g static thrust, 107mph Vopt at 69% efficiency.
How is this for freaky.... took the skyfun out today with my HowFast air speed meter taped on, 5mph wind....
with a fresh battery she did 107mph!
Tried a few props out - all with a fresh lipo. results are:
  • 5.5x4.5E APC - 107mph
  • 5.25x4.75E APC - 103mph
  • 5x5E APC - 97mph
  • 5x5E TGS - 100mph
All props drew nearly the same current, the 5.5x4.5 drawing slightly more though. The 5.5x4.5 certainly is the pick of the lot, fastest, quietest and best vertical.... very surprised by the TGS 5x5E though, as noisy as it is... Did not expect the APC 5x5E to work very well, but worth a shot.
Only the batteries were slightly warm after a hard flight.
Old Jun 13, 2010, 02:32 PM
tehblizz is offline
Find More Posts by tehblizz
Italy
Joined Jan 2010
What do you guys think about this setup?
TR_P60A - TURNIGY Plush 60amp Speed Controller
T2836-2350 - Turnigy2836 brushless Outrunner 2350kv
R1850-40-4 - Rhino 1850mAh 4S 14.8v 40C Lipoly Pack
TGS6x4E - TGS Sport 6x4E Precision propeller
Thank you
tehblizz is offline Find More Posts by tehblizz
Old Jun 13, 2010, 07:25 PM
Joined Mar 2009
go with a bigger prop, apc 6x4 sport. Otherwise a fine setup
check out this thread for more info on that motor
Old Jun 14, 2010, 02:34 AM
tehblizz is offline
Italy
Joined Jan 2010
Thanks, I'll go with both the 6x4 and the 5x5, they cost 1.5$ each
Old Jun 14, 2010, 03:07 AM
Joined Mar 2009
I said APC sport 6x4, not TGS cost a few bucks more (and not from HK) but you will have much better results, especially when you're talking about 800w+
These guys ship worldwide.
I wouldn't bother with the 5x5e, very inefficient and hard to launch due to the lower static thrust
Old Jun 14, 2010, 05:56 AM
tehblizz is offline
Italy
Joined Jan 2010
Perfect, thanks a lot!
Old Jul 28, 2010, 03:04 PM
Batch1 is offline
Find More Posts by Batch1
Canada, Quebec, Mercier
Joined Dec 2008
Johnson show us how he retain is battery
Could other people show how they do it
Batch1 is offline Find More Posts by Batch1
Old Jul 28, 2010, 03:10 PM
Joined Mar 2009
I use this on pretty much all of my planes & lipos... Very strong.
Old Jul 28, 2010, 07:20 PM
Batch1 is offline
Joined Dec 2008
I have it and it is strong but if I crash is it strong enough ?
Old Jul 29, 2010, 05:32 AM
Joined Mar 2009
Im sure if you destroyed the plane you would find a lipo with a piece of foam still velcroed to it
Old Jul 31, 2010, 04:56 PM
Batch1 is offline
Joined Dec 2008
I know I will crash, hope I won't destroyed the plane
Old Aug 02, 2010, 02:22 AM
Patrick_W is offline
Find More Posts by Patrick_W
Joined Mar 2009
What would be a nice fast 3s setup for this plane? I know that I could get a 2826-2350 and run it on 4s like some others have, but all my battery chargers only go up to 3s and I'm too cheap to buy a new one!
Patrick_W is offline Find More Posts by Patrick_W
Old Aug 05, 2010, 12:25 PM
Batch1 is offline
Joined Dec 2008
In the tech note : They are "tractor" (not "pusher") props.
Isn't more efficient to use a pusher prop ?
Do you know where I can buy a 6X4 pusher prop like the original one. I only have around 200W power
Discussion Vendo Rádio Hobby King 4ch + Receptor 6ch (2.4GHz) Amazon Brazil 0 Dec 02, 2009 07:52 AM
Discussion Hobby King 40mmx5mm folding spinners @ ~450 Watts? Owen Hedger Power Systems 3 Dec 01, 2009 02:46 PM
Discussion Hobby City/ Hobby King FPV setup- thoughts? Smokescreen38 FPV Talk 6 Oct 23, 2009 04:27 AM
Discussion Hobby King Hobby City MIG 15 7car7 Foamy EDFs 5 Oct 15, 2009 06:43 PM
Question hobby king speed controller question? qtturner1 Power Systems 3 Jul 08, 2009 11:17 PM
