Hello all, I have just completed a complete covering of fibre glass on a bare kit for a new super powerful Skyfun
![]() I used very thin Glassfibre cloth 48g ( http://www.ecfibreglasssupplies.co.u...27mm-wide.aspx ), and did 3 complete coats ![]() It now weighs in at 560grams but it tough as old boots ![]() Just looking for advice on what setups I could use to power this monster, I have a normal skyfun with 60amp esc, Turnigy2836 brushless Outrunner 2350kv, 6x4 prop and 4 cell nano tech 2200 bat, and that flys very nice. I want to at least double the thrust of the normal one, maybe even push to 3 times 8) So I recon a 120amp esc, ext ubec and 2 x 3cell 2200 so far Anyone know what type of motor and prop combo I could use for this power? |
That shouldnt be an issue as I have friends at a local car and bike mechanics who can mig weld any shapes I give em
![]() I will sort that out as soon as I work out after all the power requirments and motor etc... I will grab a couple of shots of it in a while and post so you can see her in her new coat ![]() EDIT: Put the pics on this thred http://www.rcgroups.com/forums/showp...82&postcount=3 |
Melbourne, Australia
Joined Mar 2009
I used a turnigy outrunner H3126 but you're way better off with a scorpion. Buying junk isnt good economy ![]() A quality inrunner would be even better still. Ian |
Joined Mar 2009
Joined Aug 2010
My SkyFun finally had her maiden flight today with one of our best pilots flying and me launching. It flew very smoothly and had plenty of thrust and a lot of speed at 1/2 throttle. Absolutely no loss of altitude on the hand launch, but I did chuck it pretty hard.
Required almost full right trim, which may be the torque of the larger prop. Roll rate to the left was about 3x the roll rate to the right after trimming. I have to adjust the clevis out a turn or two. Was also faster than I expected at full throttle but was quiet and really stable through various maneuvers. Landing was very slick with a blip or two of the throttle to leave the prop level with the ground then gliding for the last 40 feet. Slid for about 20 more feet on the freshly mowed landing strip. I need to add more cooling vents for the new ESC that is now under the end of the hatch. Then practice, practice and more practice before I add a higher KV motor and a smaller prop to start advancing the top speed. |
Joined Aug 2010
She flew again Sunday but this time with an 808 keyfob camera mounted flat on the right shoulder just inside the fin. This didn't effect trim much but I could tell she didn't hold enough energy when going vertical.
The video was less than a full success because the high thin bright overcast would blow out everything, even the canopy and fuselage would white-out, when the ground wasn't in view. This is the opposite of what should happen, the camera should underexpose the visible parts of the aircraft when pointed at the bright overcast but apparently it was just too much. So the exposure when banking, diving, or inverted is great as the nice green scenary is perfectly lit. But the majority of the 5 minute flight is an almost entirely white screen in level flight with the camera pointing a couple of degrees up. I've already ordered a much higher speed motor and larger ESC. Should be here in a few days. I'm also deciding on a new camera but haven't ordered anything yet. |
"Moderate" Skyfun
I have 3 Skyfuns which are just over 100+ to 90+ and a new '"moderate" Skyfun. I really wanted something that took advantage of Skyfun's great speed envelope, toughness, and no landing gear to break. I, also like it's ability to fly in high winds which the stock design didn't have enough power to do. Anyway I came up with this motor http://www.hobbypartz.com/86ma07-2215-1950kv.html
With a 6x4 prop and 3s battery. Like all Exceed motors I think it is more than the 1950Kv rating. My watt meeter says 28 amps and just over 300 watts. That translates into a plane that is just over 200 watts per pound and will fly in the low 80 MPH bracket. It flies great! I took it off this morning in 15+ winds and it did everything well. While it isn't psycho fast like the the other 2 it is still quite fast and will fly into the wind where the stock Skyfun would give up. It, also, flies well at low throttle settings and is very easy to land with just a touch of throttle. So if you want a great every day flier (Trainer?) that is quite a bit quieter but will still do 80+. This is not a bad deal for $16.00 (motor). One final thing. This motor will only fit the Skyfun's vertical motor mount holes instead of the horizontal. This means the vertical holes have to be drilled a very small amount to accept the screws. After that everything fits fine and you can use the stock 25 amp ESC. This is how the plane should of come from the factory! |
| Thread Tools | |
| Discussion Vendo Rádio Hobby King 4ch + Receptor 6ch (2.4GHz) | Amazon | Brazil | 0 | Dec 02, 2009 07:52 AM |
| Discussion Hobby King 40mmx5mm folding spinners @ ~450 Watts? | Owen Hedger | Power Systems | 3 | Dec 01, 2009 02:46 PM |
| Discussion Hobby City/ Hobby King FPV setup- thoughts? | Smokescreen38 | Video Piloting (FPV/RPV) | 6 | Oct 23, 2009 04:27 AM |
| Discussion Hobby King Hobby City MIG 15 | 7car7 | Foamy EDFs | 5 | Oct 15, 2009 06:43 PM |
| Question hobby king speed controller question? | qtturner1 | Power Systems | 3 | Jul 08, 2009 11:17 PM |
