Dec 22, 2009, 10:45 PM
United States, MI, Livonia
Joined Apr 2009
Originally Posted by RichTJ99
Hi,
So I went to the hobby shop today to check out the MCX, MSR & a Losi High Roller (which they didnt have). I have a CX2 & am decent with it (it is pretty easy after all). They ran the MSR & I got a little nervous & decided to stick with the MCX.
It is Soooooo easy to fly & I am pretty impressed with it but there is 0 fear factor which does make it a little less than exciting but my son loves watching it fly (and so do I).
My big issue is that it goes up & down fast enough but the right control switches (forward, back, left, right) are very very slow. I would say that with the throttle going forward on full it doesnt go fast. I dont mean just that its a slow heli, but with full throttle it barely moves.
My CX2 if I went forward, it would take a little while but the momentum would kick in & it would go quickly, or at least quick enough that I would have to full reverse the throttle to keep from hitting the wall, this doesnt do that.
I called the LHS & they said with the rear of the heli facing me, I should loosen the right handed linkage two full turns. I did that & its still beyond slow. Did I go the wrong direction?
The other wierd thing is that if you put it in "slow mode" with the flashing controller it doesnt seem to go slower (I cant really tell as its pretty slow).
Did I outgrow this thing within 10 minutes?
Rich
You got some bad information you want to shorten the link from the right servo 3 full turns so now you have to do 5 FULL turns.. It will go a little faster now.. But it will not ever go fast for far as it will slow down after about 10 feet unless you keep moving the stick a little.. Best way to go fast is push the right stick all the way forward and at same time feed it more power.. After it gets moving a ways start a turn with it.. it will move around at a good clip for a bit while doing this..... Next week give it to your son and go buy yourself a mSR for New Years..
