Old Dec 22, 2009, 06:11 PM
GreenAce92 is offline
Find More Posts by GreenAce92
Physics hate's my ideas
GreenAce92's Avatar
USA, NY, Dunkirk
Joined May 2007
CG on positive stagger biplane.. 3D biplane
Got a bird coming up here pretty soon, in design stages but anyhow, for starters, imagine lets say a spitfires' wings, top wing is farther ahead than the other, say that the TE of the top wing is at the middle of the chord of the bottom wing. Where would the CG be?
GreenAce92 is offline Find More Posts by GreenAce92
Old Dec 22, 2009, 07:49 PM
spots25 is offline
Find More Posts by spots25
Joined Sep 2009
it depends on the pitching moment of the airfoil you're using, but probably between 1/4 and 1/3 chord... also, put the upper wing 1.25 chord up, and 1/4 forward
spots25 is offline Find More Posts by spots25
Old Dec 23, 2009, 12:06 AM
GreenAce92's Avatar
USA, NY, Dunkirk
Joined May 2007
So a flat plate basically say 2 rectangles uhh say 8x30 30being the span so top wing is ontop and bottom wing is mounted with leading edge halfway back from top wing's chord or the le of bottom wing is 4in back from the le of top wing
Old Dec 23, 2009, 12:44 AM
Montag DP is offline
Find More Posts by Montag DP
Sink stinks
Montag DP's Avatar
United States, GA, Atlanta
Joined Apr 2005
It depends mostly on the tail size and location actually. Doesn't depend on the airfoil.
Montag DP is offline Find More Posts by Montag DP
Old Dec 23, 2009, 12:57 AM
Butch777 is offline
Find More Posts by Butch777
Livermore, CA
Joined Sep 2004
You first figure the C/G on both wings.
The lets say the top wing is 2"s ahead of the bottom wing.
Then the C/G would be 1" back from the top wing C/G.
And 1" forward of the bottom wing C/G.
Butch777 is offline Find More Posts by Butch777
Old Dec 23, 2009, 04:18 AM
Azarr is offline
Find More Posts by Azarr
RIP Azarr - "Old age is not for sissies"
Azarr's Avatar
Dayton Intl, Ohio, United States
Joined Jan 2000
Assuming rectangular wings as you mention in post 3, I just use the measurement from the leading edge of the top wing to the trailing edge of the bottom wing and then set the CG at around 30% of that width. It's always worked for me as a ball park CG.
Azarr
Azarr is offline Find More Posts by Azarr
Old Dec 23, 2009, 10:20 AM
LesUyeda is offline
Find More Posts by LesUyeda
LesUyeda's Avatar
San Diego, California
Joined Dec 2004
From Lennon On Bipes. Has always worked for me.
Les
LesUyeda is offline Find More Posts by LesUyeda
Old Dec 23, 2009, 01:32 PM
robin andrew is offline
Find More Posts by robin andrew
Joined Feb 2004
bipe cg
if normal model power wing sections are being used, its just in front of
1/2 way across the front wing, as a starting point, Robin Andrew,UK
robin andrew is offline Find More Posts by robin andrew
Old Dec 23, 2009, 05:41 PM
GreenAce92's Avatar
USA, NY, Dunkirk
Joined May 2007
Ooo! Great diagram! thanks!
Help! Need CG help with GP Reactor 3D (the smaller one) helifryer 3D Flying 7 Dec 06, 2009 08:22 AM
Wanted Stagger Bee CG Tom Smith Aircraft - Electric - Airplanes (FS/W) 4 Nov 12, 2009 12:48 AM
Discussion Hanger 9 Twist 60 Biplane wing gap and stagger? Barry_DVRC The Builders Workshop 5 Aug 17, 2009 02:16 AM
Build Log Stagger Wing Twin Boom Biplane (SWTB) jconwell Foamies (Scratchbuilt) 7 Feb 22, 2008 05:11 PM
Cool What's the purpose of Biplane "STAGGER" JonB Modeling Science 6 Jan 29, 2004 06:25 PM
