Old Dec 22, 2009, 09:27 AM
sg sailing is offline
Find More Posts by sg sailing
sg sailing's Avatar
Carlisle UK
Joined Sep 2007
E Logger V3 RPM with CSM Revlock 10 sensor not working
I have the E-Logger V3 150A and I think it is a great piece of kit esp. for Heli's. I have searched this board for info regarding the CSM Revlock engine RPM govenor but could only find info on the Futaba Gv1...
I read that the power to the sensor must come from the origional source ie Revlock and tht,s how my lead is configured...
I also read that despite the colour coding on the data logger the sensor wire's may have to be swapped over am i correct here as I would not like to damage the V3 or the sensor?
Interestingly I looked at photo's or your own sensors and the signal wire is on the tabbed end of the plug as are the sensor wires to the Revlock sensor.
but the temp sensor wires are both red and are connected middle pin to opposite end of plug to the tab.
regards Steve
sg sailing is offline Find More Posts by sg sailing
Old Dec 24, 2009, 04:40 PM
billpa is offline
Find More Posts by billpa
billpa's Avatar
Joined Nov 2003
Hi Steve,
The pinout of our RPM port, in terms of a futaba servo wire, is:
red = ground
black = power
white = signal (0-5ish volt pulses)
If you can determine what the revlock is outputting re signal, if it's a simple square wave pulse, you should be able to connect the white and red wires to signal and ground of the revlock, as a simple test (but, alas, at your own risk).
Regards,
Bill, for Eagle Tree
billpa is offline Find More Posts by billpa
Site Sponsor
Old Dec 28, 2009, 05:34 PM
sg sailing's Avatar
Carlisle UK
Joined Sep 2007
Many thanks Bill. I will look at Revlock and report back with my findings. I know the Revlock pinouts are identifiable so we may be in luck.
Edit
Photo of revlock pinouts (sensor input on lower left)
Steve
Old Jan 04, 2010, 01:18 PM
sg sailing's Avatar
Carlisle UK
Joined Sep 2007
Bill
Further examination and testing has produced the following info....
Any attempt at tapping into the Revlocks input signal will stop the revlock from seeing the pulses from the sensor. This will in effect disable it...
The supply from the revlock to the sensor is 3.8v when the supply voltage is 4.8v This falls to 2v when the revlocks sensor is plugged in.
The pulse output from the sensor 1.9v rising to 2.2v when magnet passes.
Maybe there are two solutions
simply use one of your sensors or use a transistor curcuit to create correct pulses for input to data logger. I suspect the data logger will need to see positive voltage pulses at 4-5v........... only viable if its worth time and effort involved or for those who like such a challenge.
All ineteresting stuff
Regards Steve
Old Jan 05, 2010, 06:01 PM
billpa is offline
billpa's Avatar
Joined Nov 2003
Hi Steve,
Sounds like the Revlock's output is very current limited.
A transistor buffer might work (or even our brushless RPM sensor) but as you say it may not be worth the effort.
Regards,
Site Sponsor
Old Jan 08, 2010, 05:13 PM
sg sailing's Avatar
Carlisle UK
Joined Sep 2007
Bill
I geussed the same and have gone the easy way and purchased one of your sensors. Testing with the existing magnet the Datalogger works fine.
I just need to make a mount for the sensor.
Many thanks for your help
Steve
For Sale NIP Eagletree e-logger v3 150amp w/LCD display & airspeed sensor dusmmdb34 Aircraft - General - Miscellaneous (FS/W) 1 Dec 20, 2009 02:36 PM
Sold Eagle Tree E-logger V3 with brushless rpm sensor $50 shipped xeispen Aircraft - Electric - Helis (FS/W) 3 Nov 29, 2009 05:48 PM
Sold Eagle Tree V3 Data Logger, Power Panel, Brushless Motor RPM Sensor BoysToys Aircraft - General - Radio Equipment (FS/W) 0 Oct 24, 2009 01:23 PM
Sold E-Logger V3,Micro Temp Sensor and 2 Motor RPM Sensor Ultralight Aircraft - General - Miscellaneous (FS/W) 1 Oct 30, 2008 02:48 PM
Idea Eagle Tree e-Logger v3, RPM sensor, TEMP sensor Dr Kiwi Power Systems 36 Jan 05, 2008 11:18 PM
