Old May 09, 2003, 04:01 AM
paulcook
paulcook
Guest
n/a Posts
Can I use any RX with my JR Max 6 FM TX
Hi,
I am new to rc flying, I don't even have a plane yet!
I have picked up a JR Max 6 FM TX and that's it.
My questions are will any receiver work with this model.
Will any 35mhz crystal work with the TX & RX.
Will any servos work with any RX.
Sorry for the stupid questions but I have not got a clue yet.
Cheers
Paul
John Privett
John Privett
Guest
n/a Posts
Re: Can I use any RX with my JR Max 6 FM TX
paulcook wrote:
> Hi,
On 35MHz any make of receiver should be OK. This is as long as you're not
using PCM - and I don't think the JR Max 6 is capable of PCM. You may get
replies that JR & Futaba use a different shift and are incompatible. This
is true on the American 72MHz frequencies, but not on 35MHz. (You could
post to uk.rec.models.radio-control.air for UK-specific questions.
rec.models.rc.air is a global group.)
For crystals stick with the same brand of crystal as the item it's used in.
So use a JR crystal in a JR Tx, but use a Futaba crystals in a Futaba Rx.
Servos are compatible with a couple of points to note. Sanwa used to use a
different plug configuration so avoid old Sanwa servos. Futaba plugs have
an extra 'ridge' to make sure they are plugged-in the right way round.
Other manufacturers don't bother with this. If you have a Futaba Rx then
any servo will plug into it, but to plug a Futaba servo into (say) a JR Rx
will need the little ridge on the plug to be shaved off.
Have a look around some of the UK websites for more info, eg.
www.bmfa.org
www.flyingsites.co.uk
John P. - who flies on Epsom Downs, UK.
http://www.flyrc.org.uk/
I'm sick of spam, so replace 'nojunkthanks' with 'john' if you want me
to read any e-mailed reply!
Outgoing mail is certified Virus Free.
Checked by AVG anti-virus system (http://www.grisoft.com).
Version: 6.0.478 / Virus Database: 275 - Release Date: 06-May-03
Discussion Can i use any balancer with my orbit pocketlader? tann200 Batteries and Chargers 9 Jul 05, 2007 06:39 AM
Discussion Can I use a Triton charger with my TP-205V balancer MailOrderGuy Batteries and Chargers 13 Feb 05, 2007 04:28 PM
Discussion Can I use a different ESC with my jeti phasor 30/3? pbjones81 Electric Plane Talk 9 Dec 03, 2006 07:31 PM
Discussion Can I use this rx on my Corona ? yaremchl Electric Heli Talk 2 Jun 14, 2006 08:59 PM
Can I use a R1000DS Rx with PCM 10S? henke Electric Plane Talk 0 Nov 25, 2002 06:36 PM
