Old Dec 21, 2009, 10:44 AM
coosbaylumber is offline
Find More Posts by coosbaylumber
Joined Jul 2005
Metric measurements versus fractional
I often get a plan from my eastern European friend that was done in metric units of centimeters or MM. For it to be avaialblein USA I then have to convert a few things over to fractional sizes.
I have been using the Paperspace option (with the XP sub-option) for this in Autocad before I get going to a plot then. Involves a few K in size but works easy enough for me.
Do other users here have another routine to convert metric to fractional?
Wm.
coosbaylumber is offline Find More Posts by coosbaylumber
Old Dec 21, 2009, 12:06 PM
jcpatrick is offline
Find More Posts by jcpatrick
Jim C Patrick
jcpatrick's Avatar
United States, VA, Basye
Scale the drawing and set the units to inches. Alternatively, you could set the units to inches and scale the drawing. ;-)
jcpatrick is offline Find More Posts by jcpatrick
Old Dec 21, 2009, 12:18 PM
Guz is offline
Guz
Find More Posts by Guz
Guz
Gutless wonder
Guz's Avatar
Tempe, AZ
Joined Dec 2005
Personally, I would just leave it alone. The US is one of three countries that still hold on to the old system.
Ever since I bailed and started using the metric side of my rulers, it's been so much easier to build things. The only hurdle that was somewhat difficult to overcome was drill bits, but I since finally broke down and ordered a set of metric drill bits life has been good.
Guz is offline Find More Posts by Guz
Old Dec 21, 2009, 04:22 PM
BMatthews is offline
Find More Posts by BMatthews
B for Bruce
BMatthews's Avatar
The 'Wack, BC, Canada
Joined Oct 2002
I'd LOVE to use the metric system. It's so much easier overall. Sadly though since our balsawood supplies come from "that last bastion of Imperial measurements" (USA) I just go with the flow and stick with inches.
Canada went officially metric quite a while ago but there's still lots of imperial tools and supplies. Drill bit sets, for example, are still all fractional at most stores. You have to ASK for metric and at the smaller hardware stores there's no guarantee they have them. There's pleanty of other similar examples as well like screws, nuts and bolts. There's a metric section for them but it's seldom as big or well stocked as the fractional size area.
BMatthews is offline Find More Posts by BMatthews
Old Dec 21, 2009, 04:59 PM
philba is offline
Find More Posts by philba
Prop Buster Extraordinaire
philba's Avatar
Seattle
Joined Aug 2009
I was born and raised on the imperial system but have gotten to the point where I am comfortable with both metric and imperial. If something started metric, I just use it that way. Same for imperial. When I start a new design, a lot depends on the material I'm going to use. If it's foam, I use metric but if I'm using, for example, wood from the local lumber store then I'll use imperial. Metric is easier to use, though. When using imperial, I try to leave fractional inches as decimal - makes it a lot easier calculating a mid point for example.
I have memorized a number of conversions - 25.4 mm is 1 inch, 3/8 inch is a shade less than 1 cm. That helps speed things along.
For drill bits, I made up a chart, printed it out and refer to it all the time. I also use my electronic calipers on bits pretty frequently.
philba is offline Find More Posts by philba
Old Dec 21, 2009, 05:00 PM
rick.benjamin is offline
Find More Posts by rick.benjamin
Reduce the drama...
rick.benjamin's Avatar
USA, OR, Damascus
Joined Apr 2004
I keep a three column "cheat sheet" nearby.
Fraction, Decimal, metric.
rick.benjamin is offline Find More Posts by rick.benjamin
Old Dec 21, 2009, 05:54 PM
Reduce the drama...
USA, OR, Damascus
Joined Apr 2004
an online conversion chart
http://www.advantagefabricatedmetals...sionchart.html
Old Dec 21, 2009, 10:57 PM
Joe'n Kody is offline
Find More Posts by Joe'n Kody
Joe'n Kody's Avatar
Yeppoon Queensland
Joined Oct 2009
I hate and detest metric and I used to teach metric when I worked at college for 14 years!
To use millimeters for measuring lengths is only just ok and should be the proper unit for doing so up to 50 m. Centimeters is a load of rubbish! Meters are too big for small engineering drawings 'cos the decimal point is a nightmare.
Balsa that's made in "metric" is a pain. 3mm is often too small to replace 1/8". 6mm is the same, too small, its .014" undersize. 8mm is ok as 5/16". 9mm is not 3/8", nor is 10mm. 9.5mm equals .374", the only close conversion to any metric unit along with 0.8mm which is .031" or 1/32". You cant buy balsa in the proper sizes anymore. even the lengths are wrong, 1200mm is 3/4" short of 4'.
What I really hate is trying to understand the infernal units. eg, What's a pascal? Whats a megapascal? How does it compare to pounds? What about newtons? how many newtons does your plane exert? NO WAY. I hate metric. Kids at school have been deprived of the ability to "think" and work things out. I might be an old fuddy duddy but my brain is as sharp as a tack! Don't get me started on metric threads! or Liters for volume
When Australia went metric the conversion was litteraly overnight. This change almost sent the country broke. If any idiotic politition wants to change to metric in the US, take him (or her) out the back and help him change his mind using the leg bone from a roo or an emu.
So to work with a metric drawing, the best way as already suggested is to change the units of the drawing. This is easy to do by drawing a short line about 30mm long. Draw a verticle line near one end and then copy the line spaced 25.4mm away. Set the units to this measurement and call it "1.000". The zeros' aren't necessary but it looks better. All the dimensions will now be in the correct units, ie. Inches!!
Sometimes I will copy a drawing I see in a magazine and reproduce it on my Cad program. To do this I use my vernier calipers (I wish I had a digital set) but measure everything in mm's. This is the only time I use metric. Its because the eyes don't read the thous on the inch side of the vernier like they used to. I reproduce the drawing then change the units to inches as above. I then change the units to the actual dimensions I want and then print out the full size drawing. This works really great (for me anyway). My next projects will be the drawings for the sailplane "Paragon" and the fabulous .049 powered "TD Special". Doing this preserves the original drawing as best as I am able.
Hey Kody! What do you think of metrics?
Her reply ........
Joe
Joe'n Kody is offline Find More Posts by Joe'n Kody
Old Dec 22, 2009, 06:13 AM
Mode One is offline
Find More Posts by Mode One
Closed Account
Joined Dec 2006
Metric measurements versus fractional The fractional measuring system is O.K. when your assembling things with a hammer. However, for other then material sizes and working in fractions less then 1/16th of an inch, I convert to decimals. Been working with the decimal system for a long time and it is just easier for me to think in this way.
As someone has said; converting is a simple equation and there are nice charts available for quick reference.
Mode One is offline Find More Posts by Mode One
Old Dec 22, 2009, 07:29 AM
Rodney is online now
Find More Posts by Rodney
Florida
Joined Aug 2004
Fractional?? Every thing has fractions including metrics. I do not believe "fractional" is a defined method of measurements, are you confusing it with Imperial or some other definition of measurements? i.e. a 1/4 inch is fractional, a 1/10 gallon is fractional, 1/8 meter is fractional but a foot, an inch, a yard etc. is not fractional.
Rodney is online now Find More Posts by Rodney
Old Dec 22, 2009, 08:13 AM
Mode One is offline
Closed Account
Joined Dec 2006
Fractional is most certainly a "Defined method of measurement" What is 22' 5 & 5/8", if not a fractional method of measurement? The inch is divided into fractions: 1/2, 1/4, 1/8, 1/16, 1/32, 1/64, etc. The foot is divided into 12ths, the yard dived into 1/3rds and 1/36ths! The meter is divided into 1/10ths, 1/100ths, 1/1000ths, etc.
You lost me Rodney, I don't understand where your coming from!
Old Dec 22, 2009, 12:57 PM
slipstick is online now
Find More Posts by slipstick
Staffs, UK
Joined Nov 2003
No, metric is a system of measurement based on meters, grams etc., imperial is a system of measurement based on feet, pounds etc.
Fractional is just a notational scheme equally applicable to either. 17.563 miles is as meaningful as 17.563 mm. One and five sixteenths of an inch is no more meaningful than one and five sixteenths of a metre.
Decimal notation is most common in any engineering situation these days whether the base units are metric or imperial. Fractional notation is only still retained where, for some perverse reason, materials are still made in historical sizes.
Converting a drawing from metric to imperial will not generally automatically produce fractional notation. A line 300 mm long will become 11.8110 inches not 11 and 13/16ths (give or take a bit) .
Steve
slipstick is online now Find More Posts by slipstick
Old Dec 22, 2009, 01:10 PM
Buran is offline
Find More Posts by Buran
Buran's Avatar
Huntington Beach
Joined Aug 2000
The metric system is far superior. It doesn’t get any simpler than base ten. What the heck do inches, feet, yards, ounces, and pounds relate to? When you study the sciences and advanced math, you WILL appreciate the metric system. I don’t see the U.S. changing anytime soon; we’re simply too lazy.
Buran is offline Find More Posts by Buran
Old Dec 22, 2009, 02:34 PM
richg99 is offline
Find More Posts by richg99
houston tx
Joined Aug 2007
Yep, every time I .....CAN... use metric, I do. Lots easier for this 70 year old mind to use than 1/32nds; 3/64ths; 5/8ths... etc.
No logic at all to stay with imperial and most countries have already seen the light..... Rich
richg99 is offline Find More Posts by richg99
Old Dec 22, 2009, 03:33 PM
Mode One is offline
Closed Account
Joined Dec 2006
The reason the U.S. hasn't converted to metric, is the cost of measuring equipment, not laziness. A lot of money has been invested in the inch. The fact that the machine trades are in the "toilet" during this recession and also that most new mics and calipers and other measuring equipment and automobiles can be converted to metric measurement by pressing a button should make the conversion a simple matter. Why it hasn't taken place is a good question, I think it was supposed to have happened in 1989! Maybe it's because your gov't doesn't want to spend your tax dollars on speed limit and distance signs. My guess would be this would be a significant cost!
Buran, could you explain to me the significance of the length of a meter and why this length is so much better then the length of a foot? Yes, working in multiples of tens is a better system, without doubt. However, now we are overlooking the nautical mile, which is a universal measurement equaling one minute of arc of latitude along any meridian. Certainly the metric system does not fit this system, which is used to describe where on Earth you are. 360 degrees doesn't make sense, either. Go out into space and now you have astronomical units and light years. You can go on and on with this stuff!
Discussion renny II metric wing joiner sir_moto Electric Sailplanes 2 Dec 14, 2009 07:44 AM
Help! small metric nylon bolts charlesbair Thermal 10 Oct 19, 2009 10:50 PM
Discussion Need Quick EP-8 measurements. (added: Results using measurements.) HankF Electric Heli Talk 2 Sep 22, 2006 05:51 PM
balsa metric/standard measurements derailed Electric Ducted Fan Jet Talk 8 Aug 17, 2005 03:44 PM
