Old Dec 20, 2009, 09:45 PM
huckleberg is offline
Find More Posts by huckleberg
Paddle faster - I hear banjos!
huckleberg's Avatar
USA, VA, Fairfax
Joined Mar 2008
Electrifly Flylite ARF Building & Flying Thread!!!
( There is an earlier thread that seemed to be in the wrong category so I am starting a fresh one http://www.rcgroups.com/forums/showthread.php?t=1143320 )
SPECIFICATIONS
GPMA1107
Wingspan:
35 in (890 mm)
Wing Area: 261 in² (16.8 dm²)
Weight: 7.2-8 oz (205-225 g)
Wing Loading: 4.0-4.4 oz/ft² (12-13 g/dm²)
Length: 29.5 in (750 mm)
Looks like a decent beginner EP foamy, let's dig in!
huckleberg is offline Find More Posts by huckleberg
Old Dec 20, 2009, 09:54 PM
huckleberg's Avatar
USA, VA, Fairfax
Joined Mar 2008
My build plan
So here is my build plan:
The plane (of course);
Motor - http://www.hobbypartz.com/alpha-300-...ess-motor.html
ESC - http://www.hobbypartz.com/vose10abresc.html
Battery - http://www.hobbypartz.com/71810clireba.html
Servos not sure yet, these are what the manual calls for but they are pricey - http://www3.towerhobbies.com/cgi-bin...1p?&I=GPMM1200
Using a cheap 2.4g tx/rx setup.
I noticed that the motor mount fits kinda tight into the cowling on the front of the plane. I may have to trim some away in order to screw the mount into the firewall. Will also have to trim some of the battery tray away as well to make room for the shaft.
Should I use the spinner included with the motor or should i use a prop saver?
Old Dec 21, 2009, 12:34 AM
Xpress.. is offline
Find More Posts by Xpress..
Team Hitec, Customer Support
Xpress..'s Avatar
United States, CA, Poway
Joined Oct 2007
Someone needs to go with the recommended equipment, I like to see how the plane performs when setup using the recommended equipment before I drop in a 12513984256193465:1 power to weight system
Xpress.. is offline Find More Posts by Xpress..
Old Dec 21, 2009, 02:53 AM
huckleberg's Avatar
USA, VA, Fairfax
Joined Mar 2008
you sayin' i be overpowered?
Old Jan 20, 2010, 08:12 PM
bighank13 is offline
Find More Posts by bighank13
Ahsville (just south of Columbus), OH
Joined May 2007
Hey....would it be possible to use a standard-sized receiver. I can shed some weight with battery selection and take the outside receiver case off? THANKS
bighank13 is offline Find More Posts by bighank13
Old Jan 24, 2010, 08:11 PM
huckleberg's Avatar
USA, VA, Fairfax
Joined Mar 2008
a regular receiver has plenty of room inside
Old Jan 25, 2010, 08:54 AM
Joined May 2007
THANKS BROTHER! Hank
Old Jan 28, 2010, 10:29 PM
huckleberg's Avatar
USA, VA, Fairfax
Joined Mar 2008
you got it!
Old Mar 04, 2010, 10:41 AM
kois31 is offline
Find More Posts by kois31
fly until you die!!!! :)
kois31's Avatar
Joined Feb 2010
i have all the recomended power sys. on mine and she fly great with tons of power
i have like 19 to 25 flights on mine and i can tell you the recomended set up is more that you need now to make ailerons
fly lite
Motor: rimfire 250
esc: Silver Series 8A
Batt: 2S 7.4V 300mAh 20C Competition
Servos: s3114
kois31 is offline Find More Posts by kois31
Old Jun 29, 2010, 08:42 PM
huckleberg's Avatar
USA, VA, Fairfax
Joined Mar 2008
Maidened this plane today after 6 months. Man it is easy to fly! It just floats, like it or not ... the hardest part was getting the plane down out of the air ... you have to nose down and give throttle to bring it in!
Plane is so so light ... in fact I am getting heavier higher mah batteries to both increase flight time and to weight down the nose a bit ...
Old Jun 29, 2010, 08:55 PM
Wrend is offline
Find More Posts by Wrend
どうもありがとうミスターロボット
Wrend's Avatar
United States, IL
Joined Jul 2009
Have you tried just floating it down without throttle? Keep it balanced between stalling and gliding, and it sounds like it'll float down nice and easy.
Wrend is offline Find More Posts by Wrend
Old Jun 29, 2010, 10:37 PM
huckleberg's Avatar
USA, VA, Fairfax
Joined Mar 2008
oh yea, dead stick flight is easy with this ... but i honestly think the plane was thermalling a bit - it would spontaneously rise up a few feet at a time ... the field was just starting to heat up early in the morning ...
Old Jun 30, 2010, 01:18 AM
Wrend is offline
どうもありがとうミスターロボット
Wrend's Avatar
United States, IL
Joined Jul 2009
Ah, I see. Yeah, that wing loading on it is kind of nuts.
I'm used to planes a little bigger that typically have higher wing loading. But for it's size, this plane still sounds really light.
Old Jul 01, 2010, 03:32 AM
huckleberg's Avatar
USA, VA, Fairfax
Joined Mar 2008
Yeah I think I am going to get a much heavier battery, about 600 - 800mah, to keep the nose weight up and get some more flight time ...
Old Jul 01, 2010, 10:10 PM
Joined May 2007
My 5th grade students and I built seven of these. We used the Power-Up 800mAh packs from headsuprc.com. They balanced spot on with those. I also know several who are flying TP 1320s with no problem, although they had to carve out a bit of the foam to fit.
Article Electrifly Flylite Slow Flyer EP ARF 35" Review 78dave Parkflyers 183 Dec 26, 2014 12:16 AM
Article Great Planes Electrifly Mini Slinger Flying Wing ARF Review gwh Electric Plane Talk 51 Aug 22, 2011 01:31 PM
New Product New from ElectriFly FlyLite indoor/outdoor slo-fly RAFguy Scratchbuilt Indoor and Micro Models 21 May 18, 2011 04:47 AM
Article Great Planes Electrifly XPD-8 EDF Flying Wing Brushed Electric Ducted Fan ARF Review Mitch G Flying Wings 27 Jul 25, 2010 12:59 AM
