Joined Jul 2009
F-101 Voodoo *PLANS*, Final Pics RF-101, *VIDEO* added
Hello all,
This one has been kicked around a bit. I finally broke down and put my mind to figuring out sketchup a little and came up with some plans to share. These are "builders" plans so there are not a bunch of details. If you have built a Jetset44 style plane or other parkjet you will be able to figure this one out. The airframe is all there though... and a built up way of developing the inlets and nacelles. I can scale the plans to whatever you like or I'll post the .skp file and you can modify to your hearts content! I'd like feedback on the plans, just bear in mind this is my first whack at developing them. FMD. F-101 voodoo, RF-101 easy mod to nose cone Span 20" Length about 35" AUW 8.1 oz. my version I'm thinking Ailerons and elevator 24g outrunner 600 mah 3s prop 6x4 or 7x6 sf any questions drop me a line. Hope to see some successful builds! Thanks.
Joined Jul 2009
David, I was thinking about some depron for the wings. I have not cut the slot for them yet and I have some 3mm I could use. I was going for economy! I may yet use the depron with a 3mm flat carbon spar. |
David |
Edmonton, Alberta, Canada
Joined Dec 2004
for color schemes look up CF101 in google images, we used the jets in Canada from the early 60's till 84 when the F-18's took over. We have two here in Edmonton at the Alberta Avaiation Museum, one of which is on a neat pedestal like the old testors model. There were some show color schemes do on some of the demonstrator aircraft over the years. The CAF damn near flew the wings off of them before they retired them.
http://www.roadsideattractions.ca/po...ontoncf101.htm |
Joined Jul 2009
Looks like they had a long history with Canada. Are you gonna build one? Mine is coming along at a pretty fast clip. Check out this aptly named variant.
The electric voodoo it was called. Also interesting how the Genie nuclear missiles were managed between US and Canada. |
Joined Dec 2004
I would like to do one , maybe this spring
Back in 1974 I lived in North Bay Ontario, and was in the Royal Canadian Air Cadets and was on the end of the runway in front of the 5 minute alert hangers assembling a cadet glider when 2 101's took off going back to thier base in Quebec. The pilots saw us and did a 180 turn and came back over the hanger and did a tailstand right above us. They were so low that the jet blast damn near riped the wing of the glider out of my hands. After the first one left, the second one did the same thing. I can still remember the glow of the afterburners! They couldn't have been more than 50 feet above that hanger
| Thread Tools | |
| Help! F-101 Voodoo plan | Spike223 | Fuel Jet Talk | 0 | May 04, 2009 07:45 PM |
| Discussion F-101 Voodoo | flyguide7 | Pusher Prop Jet Models | 54 | Sep 22, 2008 09:02 AM |
| Jet design contest F 101 Voodoo. | Andy McCowan | Electric Ducted Fan Jet Talk | 12 | Oct 31, 2004 01:32 AM |
| Yak 54 beta plans/build | DesertRC | Foamies (Kits) | 237 | Jan 15, 2004 10:39 AM |
| Documentation for CF/F-101 Voodoo | knight of Ni | Scale Electric Planes | 15 | Sep 15, 2002 01:43 AM |
