Old Jul 14, 2010, 03:58 PM
jjjasesino is offline
Find More Posts by jjjasesino
Joined Jul 2010
I think the bottom of the wing has to be straight / flat because all the models I've tried flat wings have flown better than those who had curbed.ex1
Wing also in the back has to be completely horizontal so that when you leave the water to drain completely and not only part and the other miss aire.ex2
Also, in some models of very low rate lipisch flight along the trailing edge of the wing to an upward curve for air and then unzip the wing hit the ground as it occurs along the wing maintains all on the ground although some models can not be achieved. ex3
jjjasesino is offline Find More Posts by jjjasesino
Old Jul 15, 2010, 01:28 PM
hoverman is offline
Find More Posts by hoverman
hoverman's Avatar
Netherlands
Joined Sep 2006
Hey,
I know that flat undersides work a bit better, however till now I have found that the shape of the underside doesn't change the performance a lot.
But, the idea of using a symmetrical profile, was to test if the pitching problems, encountered on WIGs, can be solved by using these profiles.
And, as we have found in the other thread, flat profiles and maybe even the thicker symmetrical ones, do improve the handling a lot(just not the performance)
So, the curved symmetrical profile without a flat bottom actually had its reason, but as RDsG, Derk and me have found in the General Ekranoplan Topic, it is possible to build stable WIG models with curved profiles as well, and you're right, they do perform better
Marijn
hoverman is offline Find More Posts by hoverman
Old Sep 11, 2010, 05:36 PM
hoverman is offline
hoverman's Avatar
Netherlands
Joined Sep 2006
So...it has been a long while since I last touched this model, but I had promised it will fly again. Anyway, as can be found in the General Ekranoplan Topic, I made quite some progress on other WIG models since I built this one, and I must say that I learned quite a lot about CP movements, but also on directional aquaplaning stability.
So..Either, I would someday build a totally new ekranoplan, or I would adjust this one.
One thing was certain, the whole bottom of the model had to be replaced, as it was generally wrong. It had two hullsteps, one lying far behind the CG, the other one lying alltheway under the nose. As the model rises on step, it won't just ride on the rear step(because of it's location), but also on the front one, allthough that one wasn't meant to do that. The result is that it becomes directionally unstable.
The new bottom had to future 1 large step, located infront of the CG(but not too far), to give the model a slightly nose up attitude. Buy using a keel behing the CG, it will still be directionally stable.
Blabla, hard to describe, I will show a quick drawing: (look at the bottom)
The other change is, it will feature 3 engines this time, allthree located in such positions and angles, that alltogether they cancell out the moments, thus not interferring with pitch stability. They are placed in such a fashion that the front two motors will permanently provide PAR.
Anyway, I don't have the slightest idea when I will have time to finish this, as I allready have only 2 days for the next weeks, and I also have to test the Heliferry model. But still, here are some photo's of today:
This really hurt:
Then I started on the flaps:
Next step: sanding the bottom!
Marijn
Old Sep 13, 2010, 02:16 PM
Joined Jul 2010
hello, sorry for the delay, I had a very bad problem with internet.
The model is interesting but maybe two servos to control the flaps are better than leaving the flaps fixed.
Old Sep 15, 2010, 01:58 AM
hoverman is offline
hoverman's Avatar
Netherlands
Joined Sep 2006
Well, the point is that I Messed up the position and angle of the main wing when building this model, so I would either cut off the wings and build new ones, or try this. Flat wings provide better Longitudinal stability, but with the large stabiliser on this model, I figured it should be possible to make this thing stable, even with very strongly curved wings.
So, I added flaps, to curve the wings and correct for the positioning error, and at the same time, create a better cavity for the PAR. As I am not going to make the engines rotatable, I am just going to mount them fixed in an upward position, the model is always in "Take off Mode".
Alltogether, I decided to fix the flaps in this position, because I can't figure out what the real advantage would be if I could move them, except for the model going a bit faster. It's just proof of concept
Marijn
Old Sep 19, 2010, 02:02 AM
hoverman is offline
hoverman's Avatar
Netherlands
Joined Sep 2006
Anyway, there was way too much wind to test the heliferry, plus I had to finish painting the pushboat, so I had some time to continue on the Spasatel. I finished the bottom by sanding it into shape, then using acryl base paint(and sanding in between) I smoothened it out, and then covered it with cray acryllic laquer.
I also added some windows, and the two front PAR engines. The one on the tail will follow soon!
Marijn
Old Sep 19, 2010, 07:45 AM
hoverman is offline
hoverman's Avatar
Netherlands
Joined Sep 2006
So..the progress of today, the 3d engine has been fitted, pointing slightly upwards, wchich allowed me to set the front engines more upward too.
Then the soldering began..about 2 hours Never had so many cables in one model! Anyway, everything is finished now. The controll layout:
Throttle = all 3 engines
Yaw = rudder
pitch = Elevons up&down
roll = Elevons differential
Looking good
Old Sep 19, 2010, 01:20 PM
hoverman is offline
hoverman's Avatar
Netherlands
Joined Sep 2006
Well guys, be prepared to be overwhelmed with a bunch of photo's, I just can't post enough of them to show my enthousiasm!
From this you can conclude that the testing was a succes
I tested it twice today, Once you power up, to nose of the model rises steeply, because the bottom side of the hull below the tail really gets sucked into the water. Anyway, this was an easy fix, I added a small foam block behind the second step, to create a sort of third step.
On the second test, it shows that if you power up quickly, the nose still rises steeply, but then comes down again, afterwhich the model immediately planes on step, and Takes off after just a few meters.
What about flying? Well, all the controlls work, Rudder, roll and elevator, but I found that playing around with the elevator too much often results in "crash" landings. If you apply only a bit UP elevator, and keep your finger steady, it can really fly up to about 20-30 cm's, and you can make real banked turns, whitch the sponson skimming the surface!
Enough talking, just watch!
Overenthousiastic Take Off
Than flying:
Than real flying:
Banked turns, No problem!
& Landing:
How cool is that
Haha sorry, I am just too glad that it works!
Marijn
Old Sep 19, 2010, 01:44 PM
Joined Jul 2010
woooooooooooooooooooooooooooooooooooooooowwwwwwwww www
this is legendary
is realy beautiful
congratulations
im waiting the eliferri
Old Sep 20, 2010, 04:07 AM
hoverman is offline
hoverman's Avatar
Netherlands
Joined Sep 2006
Haha cool isn't it!
Never thought it would work so well, straight away, without any big changes. I didn't even have to change the CG
About the heliferry, the current model has been put on hold, I am first going to build a more conventional model without surface piercing hulls, to test some features, before I am sending the Helicopter to it's death
But first I'm going to enjoy this model a bit more
Marijn
Old Sep 20, 2010, 10:36 AM
RdsG is offline
Find More Posts by RdsG
RdsG's Avatar
Hungary
Joined Jul 2009
Congratulations Marijn!
It looks really cool!
Gabriel
RdsG is offline Find More Posts by RdsG
Old Sep 20, 2010, 11:57 PM
derk is offline
Find More Posts by derk
TheyreComingToTakeMeAway!
derk's Avatar
USA, ID, Coeur D'Alene
Joined Dec 2003
awesome, glad to see it worked so well
so are you going to try for a larger one with MORE motors?
derk is offline Find More Posts by derk
Old Sep 21, 2010, 02:51 AM
hoverman is offline
hoverman's Avatar
Netherlands
Joined Sep 2006
Thanks Gabrial, I couldn't be more happy about the results
Haha now that would be cool wouldn't it I had thought about it, allready with this motor setup this model is vastly overpowered. I can easily Take off using 60% throttle But allready, it is quite large, this one is 1.5 meters long, with the wings stuck to it in one piece, so I can hardly fit it up the stairs.
But building a 2,5 meter long model of "The" Caspian Sea monster, the KM..hmm
Maybe after the heliferry
Marijn
Old Sep 23, 2010, 02:34 PM
aymeric is offline
Find More Posts by aymeric
Bagatelle Flyer
France, Ile-de-France, Paris
Joined Aug 2009
Nice job Marijn!
Aymeric.
aymeric is offline Find More Posts by aymeric
Old Sep 24, 2010, 05:37 PM
hoverman is offline
hoverman's Avatar
Netherlands
Joined Sep 2006
Thanks, nice to see you here too! Looking forward to the model you guys built actually skimming the wavetops
Marijn
Ekranoplan indoorff Scratchbuilt Indoor and Micro Models 35 Aug 18, 2008 06:13 PM
Speed 400 Ekranoplan model ChrisP Life, The Universe, and Politics 5 Aug 05, 2006 03:26 AM
Discussion Looking for pilot input on boats/ekranoplan? Tram Electric Plane Talk 3 Aug 04, 2006 03:04 PM
Ekranoplan Doc Data Life, The Universe, and Politics 17 Dec 19, 2005 09:04 PM
ekranoplan a-90 orljonok riddick Fuel Jet Talk 1 Dec 11, 2004 10:23 PM
